    MMM-GoogleKeep config.js
    18 Posts 3 Posters 6.6k Views 3 Watching
      svenpisa @sdetweil
      @sdetweil What? I thought you were the God Father of Magic Mirror Modules!!! ;-)
      No problem, maybe there is someone who has used this module before and it works for him to tell me what to do… I would be very happy anyway!!!
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @sdetweil
        I have tried to get the module to run, but have also failed. It seems to me that there is a problem with gkeepapi. A simple query with gkeepapi already fails.
        There seems to be a workaround with docker (see https://github.com/kiwiz/gkeepapi/issues/81), but I didn’t tested that. In the issue discussion the maintainer of gkeepapi mentioned waiting for a new release of gpsoauth. Then MMM-GoogleKeep might work again without any tinkering 🙂
          svenpisa @KristjanESPERANTO
          @KristjanESPERANTO Thank you very much. Do I understand correctly that I may only have to wait until the module works or do I have to make additional settings? Can I see the status somewhere when it should work again?
            sdetweil @svenpisa
            @svenpisa well I can fix most install problems.
              KristjanESPERANTO Module Developer @svenpisa
              I haven’t looked at the code in detail, but that could be possible, yes. Of course, it may still be the case that something needs to be adjusted in gkeepapi and/or MMM-GoogleKeep.
              The best thing would probably be to look at alternatives.
              If a gpsoauth version newer than 1.0.4 appears here, we can try again. You can also follow this discussion: https://github.com/kiwiz/gkeepapi/issues/81.
                Hi @KristjanESPERANTO I have seen that something has happened in the issue. But I didn’t understand what was changed and what was adjusted. May I come back to your help? If you have time, could you take a look at the issue on GitHub?
                Thank you very much and best regards
                  I still can’t see a new version of gpsoauth or gkeepapi. In the issue they seem only talking about a workaround.
                    @KristjanESPERANTO ah ok, then I took it the wrong way. Sorry and thanks
