    Easy setup not so easy?
    17 Posts 2 Posters 4.7k Views 2 Watching
    • 1 Offline
      1lolo94 @sdetweil
      @sdetweil that’s correct… I had to manually shut down the unit because it was stuck on the white screen
        sdetweil @1lolo94
        @1lolo94 first thing is to get default cal to display events
        dont use pm2 while changing config
        1 1 Reply Last reply Reply Quote 0
        • 1 Offline
          1lolo94 @sdetweil
          @sdetweil just an update… i sent my model 3 back because it was unusable, even with a SSD USB installed.
          I am currently using a 4 model and holy cow what a difference. I plan on installing tonight - stay tuned!
          1 1 Reply Last reply Reply Quote 2
          • 1 Offline
            1lolo94 @1lolo94
            @sdetweil - finally got the base setup and getting this error when loading.
            Is something wrong with my 64 bit install?
            [6012:0209/160437.091430:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
              sdetweil @1lolo94
              @1lolo94 noise nothing we can do
              • 1 Offline
                1lolo94 @sdetweil
                @sdetweil thanks! I got everything up and running. Can you provide a good calendar module that i can link with my google calendar?
                  sdetweil @1lolo94
                  @1lolo94 what is good? there is one built in.
                  if u want a wall cal type, then
                  MMM-CalendarExt3
                  or
                  MMM-MonthlyCalendar
                  both take events sent from the default calendar module…
