    Easy setup not so easy?
    17 Posts 2 Posters 7.0k Views 2 Watching
      sdetweil @1lolo94
      @1lolo94 loading is the default message while the module waits for data.
      weather for openweather is a pain in the rear.
      they have changed key types, called version.
      the module requires a new Parm
      apiVersion:"3.0",
      none are free anymore… openweathermap requires a credit card. altho low usage can be free of charges.
      and most modules don’t handle errors well
      1 1 Reply Last reply
        1lolo94 @sdetweil
        @sdetweil would you or anyone recommend any calendar (that works with Google calendar) or weather modules that work as of today?
        Not trying to be a pain, just frustrated 😔
          sdetweil @1lolo94
          @1lolo94 they work, just have to get the right API key
          calendar, what is wrong w the default?
          then there are others that display like a wall calendar
          MMM-MonthlyCalendar
          MMM-CalendarExt3
          both get their info from the default calendar
          you may need to install the older parser
          cd~/MagicMirror
          npm install node-ical@0.16.1
            1lolo94 @sdetweil
            @sdetweil Thanks for the response. I would like integrate our shared google calendar - i will look at these again and report back.
              sdetweil @1lolo94
              @1lolo94 the owner/creator of the calendar has to provide the url.
                1lolo94 @sdetweil
                @sdetweil gotcha! I have that and tried the MMM-CalendarExt3 - filled everything out correctly and it’s sitting on a white screen doing nothing for 5 min now :(
                  sdetweil @1lolo94
                  @1lolo94 it gets its events from the default calendar. so you configure the url over there, right?
                    1lolo94 @sdetweil
                    @sdetweil that’s correct… I had to manually shut down the unit because it was stuck on the white screen
                      sdetweil @1lolo94
                      @1lolo94 first thing is to get default cal to display events
                      dont use pm2 while changing config
                        1lolo94 @sdetweil
                        @sdetweil just an update… i sent my model 3 back because it was unusable, even with a SSD USB installed.
                        I am currently using a 4 model and holy cow what a difference. I plan on installing tonight - stay tuned!
                        Reply Quote 2
                          1lolo94 @1lolo94
                          @sdetweil - finally got the base setup and getting this error when loading.
                          Is something wrong with my 64 bit install?
                          [6012:0209/160437.091430:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                            sdetweil @1lolo94
                            @1lolo94 noise nothing we can do
                              1lolo94 @sdetweil
                              @sdetweil thanks! I got everything up and running. Can you provide a good calendar module that i can link with my google calendar?
                                sdetweil @1lolo94
                                @1lolo94 what is good? there is one built in.
                                if u want a wall cal type, then
                                MMM-CalendarExt3
                                or
                                MMM-MonthlyCalendar
                                both take events sent from the default calendar module…
