    Easy setup not so easy?
    17 Posts 2 Posters 7.0k Views 2 Watching
      sdetweil @1lolo94
      @1lolo94 the owner/creator of the calendar has to provide the url.
      1 1 Reply Last reply
        1lolo94 @sdetweil
        @sdetweil gotcha! I have that and tried the MMM-CalendarExt3 - filled everything out correctly and it’s sitting on a white screen doing nothing for 5 min now :(
          sdetweil @1lolo94
          @1lolo94 it gets its events from the default calendar. so you configure the url over there, right?
            1lolo94 @sdetweil
            @sdetweil that’s correct… I had to manually shut down the unit because it was stuck on the white screen
              sdetweil @1lolo94
              @1lolo94 first thing is to get default cal to display events
              dont use pm2 while changing config
                1lolo94 @sdetweil
                @sdetweil just an update… i sent my model 3 back because it was unusable, even with a SSD USB installed.
                I am currently using a 4 model and holy cow what a difference. I plan on installing tonight - stay tuned!
                Reply Quote 2
                  1lolo94 @1lolo94
                  @sdetweil - finally got the base setup and getting this error when loading.
                  Is something wrong with my 64 bit install?
                  [6012:0209/160437.091430:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                    sdetweil @1lolo94
                    @1lolo94 noise nothing we can do
                      1lolo94 @sdetweil
                      @sdetweil thanks! I got everything up and running. Can you provide a good calendar module that i can link with my google calendar?
                        sdetweil @1lolo94
                        @1lolo94 what is good? there is one built in.
                        if u want a wall cal type, then
                        MMM-CalendarExt3
                        or
                        MMM-MonthlyCalendar
                        both take events sent from the default calendar module…
