    Easy setup not so easy?
    17 Posts 2 Posters 7.0k Views 2 Watching
      1lolo94 @sdetweil
      @sdetweil I have tried multiple weather ones along with calendar ones - same issue of stuck on loading for both.
      Maybe I am doing something wrong so that is why i am reaching out for some recommendations on the 3 people are using that actually work.
      Thanks for the reply.
        sdetweil @1lolo94
        @1lolo94 loading is the default message while the module waits for data.
        weather for openweather is a pain in the rear.
        they have changed key types, called version.
        the module requires a new Parm
        apiVersion:"3.0",
        none are free anymore… openweathermap requires a credit card. altho low usage can be free of charges.
        and most modules don’t handle errors well
        1 1 Reply Last reply
          1lolo94 @sdetweil
          @sdetweil would you or anyone recommend any calendar (that works with Google calendar) or weather modules that work as of today?
          Not trying to be a pain, just frustrated 😔
            sdetweil @1lolo94
            @1lolo94 they work, just have to get the right API key
            calendar, what is wrong w the default?
            then there are others that display like a wall calendar
            MMM-MonthlyCalendar
            MMM-CalendarExt3
            both get their info from the default calendar
            you may need to install the older parser
            cd~/MagicMirror
            npm install node-ical@0.16.1
              1lolo94 @sdetweil
              @sdetweil Thanks for the response. I would like integrate our shared google calendar - i will look at these again and report back.
                sdetweil @1lolo94
                @1lolo94 the owner/creator of the calendar has to provide the url.
                  1lolo94 @sdetweil
                  @sdetweil gotcha! I have that and tried the MMM-CalendarExt3 - filled everything out correctly and it’s sitting on a white screen doing nothing for 5 min now :(
                    sdetweil @1lolo94
                    @1lolo94 it gets its events from the default calendar. so you configure the url over there, right?
                      1lolo94 @sdetweil
                      @sdetweil that’s correct… I had to manually shut down the unit because it was stuck on the white screen
                        sdetweil @1lolo94
                        @1lolo94 first thing is to get default cal to display events
                        dont use pm2 while changing config
                          1lolo94 @sdetweil
                          @sdetweil just an update… i sent my model 3 back because it was unusable, even with a SSD USB installed.
                          I am currently using a 4 model and holy cow what a difference. I plan on installing tonight - stay tuned!
                          Reply Quote 2
                            1lolo94 @1lolo94
                            @sdetweil - finally got the base setup and getting this error when loading.
                            Is something wrong with my 64 bit install?
                            [6012:0209/160437.091430:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                              sdetweil @1lolo94
                              @1lolo94 noise nothing we can do
                                1lolo94 @sdetweil
                                @sdetweil thanks! I got everything up and running. Can you provide a good calendar module that i can link with my google calendar?
                                  sdetweil @1lolo94
                                  @1lolo94 what is good? there is one built in.
                                  if u want a wall cal type, then
                                  MMM-CalendarExt3
                                  or
                                  MMM-MonthlyCalendar
                                  both take events sent from the default calendar module…
