    Default Weather Module Icon Position
    38 Posts 4 Posters 15.7k Views 4 Watching
      svenpisa
      Hey guys, me again. I’m currently trying to soak up everything in the forum but can’t quite get any further.
      I’ve already worked through the forum entry https://forum.magicmirror.builders/topic/7227/changing-icons-of-the-modules-current-weather-and-weather-forecast/24?page=3 but I’m making a mistake somewhere.
      An entry in Config.js looks like this:
      			module: "weather",
      			//  classes: "forecast",
      			header: "Wettervorschau",
      				type: "forecast",
      				locationID: "29112xx", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				apiKey: "c64bb3321848fe4e7616335xxxxxxx"
      			module: "weather",
      			//  classes: "wetter",
      			position: "top_center",
      				type: "current",
      Additionally my entries in the Custom.css
      .weather .weathericon {
      position: absolute;	// absolute
      z-index: 0;
      height: 200px;
      right: 180px;
      margin-top: -65px;
      padding-left: 60px;
      padding-top: 30px;
      height: 50px;
      .weather .wi-day-sunny {
      content: url("/css/icons/day.svg");
      .weather .wi-day-cloudy {
      content: url("/css/icons/cloudy-day-1.svg");
      .weather .wi-rain {
      content: url("/css/icons/rainy-6.svg");
      .weather .wi-night-clear {
      content: url("/css/icons/night.svg");
      .weather .wi-night-cloudy {
      content: url("/css/icons/cloudy-night-2.svg");
      padding-right: 15px;
      padding-top: 10px;
      .weather .wi-cloudy {
      content: url("/css/icons/cloudy.svg");
      .weather .wi-showers {
      content: url("/css/icons/rainy-7.svg");
      .weather .wi-thunderstorm {
      content: url("/css/icons/thunder.svg");
      .weather .wi-snow {
      content: url("/css/icons/snowy-6.svg");
      .weather .wi-cloudy-windy {
      content: url("/css/icons/cloudy-day-3.svg");
      .weather .wi-night-rain {
      .weather .wi-night-snow {
      .weather .wi-night-thunderstorm {
      .weather .wi-night-showers {
      .weather .wi-fog {
      .weather .wi-night-alt-cloudy-windy {
      content: url("/css/icons/cloudy-night-1.svg");
      /* Aenderungen Wettervorhersage */
      position: absolute;	/absolute
      left: 35px;
      z-index: 1;
      margin-top: -30px;
      padding-left: 6px;
      padding-top: 5px;
      height: 50px;
      .weather .wi-rain {
      padding-left: 8px;
      padding-top: 5px;
      height: 45px;
      height: 50px;
      padding-left: 5px;
      padding-top: 7px;
      .weather .wi-snow {
      height: 45px;
      padding-left: 8px;
      padding-top: 7px;
      padding-left: 8px;
      padding-top: 5px;
      height: 45px;
      .weather .wi-fog {
      height: 50px;
      padding-left: 5px;
      padding-top: 7px;
      I mean that I customized the icons in wether.css (I don’t think you’re supposed to do that, are you?)
      1. what do I have to change so that the icons are nicely arranged in the right row and exactly in the middle between the days and the temperature? (and for “Current” nice beside temperature)
        1. how can I separate the Forecast and Current icons? So what should the entry in Custom.css look like?
      2. I would have guessed the following
      .weather .current .weathericon
      (is not currently entered in the css)
      1. and I would also like the icon size of “Current” to be larger than that of “forecast”
        I would be happy if you could take me by the hand and help me here
      And last question: I started the developer mode as described in the documentation https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works
      How can I close this developer mode again so that the MM is displayed on my external monitor?
      For information: I have the MM with a Raspi on an external monitor and access it via remote desktop. If I start the developer mode and then just close it I have the MM on my laptop monitor. But I would like to have it on my external monitor again…
      Phew… so many questions…
        sdetweil @svenpisa
        @svenpisa last question
        to close the dev console is the same keyboard as opening ctrl-shift-i, it’s a toggle…
        also if u can see it, there is a close button top right on the developers window
        never modify the module or mm files. it will break updates…
        so, now separate the css changes back into custom.css,
        and then restore the original file
        cd ~/MagicMirror
        git checkout modules/default/weather/weather.css
        you need some unique identifier. was easy when the modules were different names…but still easy
        you can Assign an arbitrary string to be associated with a module, by using the classes property.
        module: "...",
        classes:"current",
        classes is a space separated list of tokens that will be added to the class setting for the module content, and then you can use that in custom.css
        .current  /* note the dot meaning class */
          sdetweil @svenpisa
          @svenpisa developers window.
          you can only close it on the browser it is showing on.
          so, don’t start mm w it open
          you don’t need to remote desktop in, just use a browser to the IP address and port
          use developers window there til you get what you want in custom.css on that browser (just refresh the browser page after editing the file)
          then restart the mm system so it’s page will show the updates
          to get remote browser to work, need to allow remote systems to connect
          in config.js
          address:"0.0.0.0",
          ipWhitelist:[],
          by default mm is setup to be on the wall, self contained, no external incoming access.
            svenpisa @sdetweil
            I have reset the weather.css again. Fits so far.
            I think I have also understood the module and classes.
            So if I have the following
            			module: "weather",
            then I would have to enter it in the custom.css as follows?
            .weather .forecast
            Unfortunately, I have not yet understood how to access it via browser.
            Exactly! The MM should hang on the wall, but if I want to make changes, I want to access the Raspi / MM via WLAN and make the changes via my laptop and since I am not a programmer and like to have everything visually, I would like to mirror the MM or the OS on my laptop screen and preferably make the changes via the “Geany” tool.
            How exactly should I enter it in the browser?
            I have tried it with IP and port, but only get an error message. I have also tried with the WLAN IP and port, but also without success.
            	address: "0.0.0.0",
            	port: 8080,
            Thanks in advance
            S 3 Replies Last reply Reply Quote 0
              sdetweil @svenpisa
              @svenpisa said in Default Weather Module Icon Position:
              .weather .forecast
              no… just
              .forecast
              that overrides .weather
                sdetweil @svenpisa
                address: “0.0.0.0”,
                port: 8080,
                ok, and ipWhitelist:[], too, right?? this restricts incoming request to JUST the addresses listed… by default this was JUST the loopback address (localhost), again ONLY inside this machine…
                so, the first two mean,
                listen for incoming connections on all network interfaces (image ethernet and wifi active, you can restrict to just one by using the actual ip address assigned, OR allow connections on BOTH without having to know the assigned addresses)…
                and the the port 8080…
                you used remote connection to the PI… use the same address in the browser
                http://pi_ip_address(or name):8080
                on my current mac connecting to raspberry pi 5
                I can use
                http://raspberrypi5:8080
                or
                http://192.168.12.121:8080
                  sdetweil @svenpisa
                  i strongly recommend installing Winscp or Bitvise ssh clients on your windows machine. (both free)
                  these will give you BOTH the ssh window (for commands, installing updates and modules) AND a file manager window over the PI files (for editing files). Then you can double click to edit ON YOUR PC, with your PC EDITOR, and auto save back to the pi…
                  bitvise ALSO provides a window for drag/drop to copy files in either direction
                  great for copying log files from the pi…
                  i use notepad++ on my windows machine for editing but you can use visual studio code or whatever text editor you like… they don’t know the file is over ssh…
                  I NEVER edit ON the pi itself… only over ssh, and use one of the visual tools when I need to …
                    svenpisa @sdetweil
                    Thanks @sdetweil
                    It works… Was my mistake… i took a / instead of : between ip and port…
                    Looks great now.
                    Last question for that… Have you got a link for a tutorial how to use the developer mode?
                      svenpisa @sdetweil
                      @sdetweil i installed Bitvise now. The first view looks good… i will try it the next days!
                        sdetweil @svenpisa
                        @svenpisa learn developers window
                        see
                        https://forum.magicmirror.builders/post/90135
                        and a little here
                        https://forum.magicmirror.builders/topic/7227/changing-icons-of-the-modules-current-weather-and-weather-forecast/290?_=1707252488912
                        • Z Offline
                          ZiggidyZ
                          Personally I use putty and do everything over command line. On my PC I use Notepad++ for working on files as well, then will copy and paste over to the ssh session.
                            sdetweil @ZiggidyZ
                            @ZiggidyZ yeh, I used to do that too.
                            then I have 10 systems I work on, got to be too much copying.
                              svenpisa
                              Thank you guys for your tips and help. Now I only have one issue left.
                              How do I get the icons in the right place?
                                sdetweil @svenpisa
                                @svenpisa I don’t understand. you have mmm-wallpaoer selected, but weather icons in class list
                                  svenpisa @sdetweil
                                  @sdetweil I had taken the section to see the Custom.css and weather.css on the right side. Shouldn’t the wallpaper actually be displayed?
                                    sdetweil @svenpisa
                                    @svenpisa as I said, confused.
                                    in custom.css do
                                    html {
                                       cursor: default;
                                    to turn on the mouse pointer over the mm content
                                    then easier to see to select correct content
                                      svenpisa @sdetweil
                                      @sdetweil said in Default Weather Module Icon Position:
                                      html {
                                      cursor: default;
                                      Is the screenshot better?
                                        sdetweil @svenpisa
                                        @svenpisa yes, better.
                                        so that stuff for .weathericon from custom.css, I would click off each and see the effect.
                                        as you mouse over the settings in the right column a checkbox will appear, that u can check to disable a setting
                                        note .weather-icon applies to ALL of the icons.
                                        the css selector clause (stuff before the {) WILL ALWAYS match every such item on the page. you can make it more specific to get fewer elements.
                                          svenpisa
                                          Thank you very much for your help.
                                          I first had to read through your messages at my leisure and at the same time I tried to understand the messages parallel to the developer tool.
                                          And lo and behold, it worked.
                                          I have now split the weather module into two classes.
                                          			module: "weather",
                                          				type: "forecast",
                                          				locationID: "2911xxx", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                          				apiKey: "c64bb3321848fe4e76163xxxxxxxxxc"
                                          			module: "weather",
                                          			classes: "wetter",
                                          				type: "current",
                                          				apiKey: "c64bb3321848fe4e76163xxxxxxxxx"
                                          You could then play around really well with each class in the developer tool and then find the right position.
                                          For those who are interested. I have now made the following entries in the Custom.css so that it looks like this:
                                          .forecast .weathericon {
                                          position:absolute;	// absolute
                                          z-index: 0;
                                          height: 200px;
                                          right: 120px;
                                          margin-top: -65px;
                                          padding-left: 60px;
                                          padding-top: 50px;
                                          height: 35px;
                                          .forecast .wi-day-sunny {
                                          .forecast .wi-day-cloudy {
                                          .forecast .wi-rain {
                                          forecast .wi-night-clear {
                                          .forecast .wi-night-cloudy {
                                          padding-top: 10px;
                                          .forecast .wi-cloudy {
                                          .forecast .wi-showers {
                                          .forecast .wi-thunderstorm {
                                          .forecast .wi-snow {
                                          .forecast .wi-cloudy-windy {
                                          .forescast.wi-night-rain {
                                          .forecast .wi-night-snow {
                                          .forecast .wi-night-thunderstorm {
                                          .forecast .wi-night-showers {
                                          .forecast .wi-fog {
                                          .forecast .wi-night-alt-cloudy-windy {
                                          .wetter .weathericon {
                                          position: absolute;
                                          z-index: 1;
                                          margin-top: -33px;
                                          padding-top: 20px;
                                          left: 60px;
                                          .wetter .wi-day-sunny {
                                          padding-left: 6px;
                                          padding-top: 5px;
                                          height: 50px;
                                          .wetter .wi-day-cloudy {
                                          .wetter .wi-rain {
                                          padding-left: 8px;
                                          padding-top: 5px;
                                          height: 45px;
                                          .wetter .wi-night-clear {
                                          .wetter .wi-night-cloudy {
                                          height: 50px;
                                          padding-left: 5px;
                                          padding-top: 7px;
                                          .wetter .wi-cloudy {
                                          .wetter .wi-showers {
                                          .wetter .wi-thunderstorm {
                                          .wetter .wi-snow {
                                          .wetter .wi-cloudy-windy {
                                          height: 45px;
                                          padding-left: 8px;
                                          padding-top: 7px;
                                          .wetter .wi-night-rain {
                                          padding-left: 8px;
                                          padding-top: 5px;
                                          height: 45px;
                                          .wetter .wi-night-snow {
                                          .wetter .wi-night-thunderstorm {
                                          .wetter .wi-night-showers {
                                          .wetter .wi-fog {
                                          .wetter .wi-night-alt-cloudy-windy {
                                          height: 50px;
                                          padding-left: 5px;
                                          padding-top: 7px;
                                          We can therefore close the entry here
                                          Thanks all again
                                            sdetweil @svenpisa
                                            @svenpisa awesome! thanks for the feedback.
