    MMM-SimpleBackgroundSlideshow
    5 Posts 4 Posters 1.3k Views 4 Watching
      muhammedsaidckr
      MMM-SimpleBackgroundSlideshow is a module for MagicMirror² that allows you to display a simple, customizable background slideshow on your MagicMirror². This module is designed to be lightweight and easy to configure, making it the perfect addition to any MagicMirror² setup.
      1. Navigate to your MagicMirror’s modules directory and clone this repository:
        git clone https://github.com/muhammedsaidckr/MMM-SimpleBackgroundSlideshow.git
      2. Configure the module in your config.js file.
      Usage
              module: "MMM-SimpleBackgroundSlideshow",
              position: "fullscreen_below", // This can be any of the regions that support background content.
      Configuration Options
      urls => Array: List of image URLs to be displayed in the slideshow.
      Contributing
      Contributions are welcome! Please read the contributing guidelines before getting started.
      License
      MMM-SimpleBackgroundSlideshow is licensed under the MIT License.
      KristjanESPERANTOK 1 Reply Last reply Reply Quote 1
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @muhammedsaidckr
        Nice! :smiley: Don’t forget to add it to the module list.
          muhammedsaidckr @KristjanESPERANTO
          @KristjanESPERANTO Alright. Thank you :)
          • G Offline
            greedyvegan
            can I add a flash drive and use that as a source of images?
              sdetweil @greedyvegan
              @greedyvegan yes, just use a link to map the mounted usb stick to where the module expects the images to be.
              I do that with a file server mount for
              MMM-ImagesPhotos
              see the ln command
