    MagicMirror stutters and doesn't run smoothly
    25 Posts 3 Posters 12.6k Views 3 Watching
      drx1984 @sdetweil
      @sdetweil what do you mean by LSR? what does that mean?
      I have now done this:
      Of course, with “npm run server” it runs in the browser.
      but how do I do it natively on the computer itself? When I enter the command “npm run start” there is an error in the cmd, something with the display.
      I wonder if I did everything correctly, as you described it.
        sdetweil
        @drx1984 DISPLAY… you didn’t follow all the instructions …
        see https://docs.magicmirror.builders/getting-started/installation.html#other-operating-systems
        LSR (you can install the linux system runtime under windows too) …
          sdetweil @drx1984
          @drx1984 said in MagicMirror stutters and doesn't run smoothly:
          i don’t understand your question…
          MM is a browser app.
          it runs in Electron, (default), Chromium, Firefox, Edge, Safari, Midori, …
            drx1984 @sdetweil
            @sdetweil oh yes sry, I saw it, ok now I have adapted the Package.jason and it is now running.
            Did I do that correctly with the mm.cmd file so that the GPU is active? It still stutters or the clock module is also lagging behind :-(
            Do you speak German too?
              sdetweil @drx1984
              @drx1984 I don’t speak German, but can use translators to read/reply.
              I mislead you, for Windows to set the env variable you have to use set
              set ELECTRON_ENABLE_GPU=1
                drx1984 @sdetweil
                @sdetweil So you mean?
                …unbelievable does it require so much power? of the stottort anyway.
                the IntelNuc is powerful enough, right?
                S bheplerB 2 Replies Last reply Reply Quote 0
                  sdetweil @drx1984
                  @drx1984 yes, set ELECTRON_ENABLE_GPU=1
                  powerful enough? I do not know…
                  drawing lots of things on the screen takes lots of power. the screen is very slow compared to the processor…
                  I don’t run either of those module.
                    drx1984 @sdetweil
                    @sdetweil yes certainly more than a Raspi 4 or 5.
                    then are the script and path correct?
                    I don’t notice any difference and it still stutters.
                      sdetweil @drx1984
                      @drx1984 yes, looks OK.
                      I would try to run one module at a time
                      to disable the other, add
                      disabled: true,
                      after the module: line
                      so you don’t have to redo config.js
                      we don’t officially support Windows, so I don’t know if you have to do something else to enable gpu for electron.
                      you could try running under edge, at
                      http://localhost:8080
                        drx1984 @sdetweil
                        @sdetweil yes, I have already tried the exact same configuration under Linux. > unfortunately it stutters there too.
                        That’s why I thought I’d try it on Windows level.
                        I will probably install Ubuntu on the Intelnuc again >because Windwos is not official, as you say.
                        But I don’t think it will stutter anymore, unfortunately.
                        • 2 / 3
