    MagicMirror stutters and doesn't run smoothly
    25 Posts 3 Posters 12.3k Views 3 Watching
      sdetweil @drx1984
      @drx1984 well, you tried before enabling the GPU on linux so I still think the best approach is to test with one module at a time… globe alone, rain alone. see what they do
      then enable the other…
      • bheplerB Offline
        bhepler Module Developer @drx1984
        @drx1984 said in MagicMirror stutters and doesn't run smoothly:
        the IntelNuc is powerful enough, right?
        I don’t think so. It’s the MMM-Globe module. It’s pure javascript and doesn’t make use of the graphics hardware at all. You might get away with turning off the MMM-Rain and running just the globe module. Might.
        I really should get around to rewriting it.
          drx1984 @bhepler
          @bhepler
          Good morning, I have now deactivated MMM Rain. The Globle module is still shaking/stuttering a bit.
          I have already set the parameter “export ELECTRON_ENABLE_GPU=1” in the mm.sh file.
          But yes then the Globle module should also have GPU support.
          Can you fix that?
          • bheplerB Offline
            @drx1984 - Yeah, I can. It’s on the list of projects. I don’t know when I’ll get to it. For you I’ll bump it up the priority list a bit. But I don’t have an estimate.
              drx1984 @bhepler
              @bhepler said in MagicMirror stutters and doesn't run smoothly:
              Good morning,
              aha ok, thank you very much, yes that would be very good.
              • 3 / 3
