MMM-PIR since update not working.
Ive just installed the latest update and now the PIR sensor value is not resetting. I have to mouse click to get the screen to recover once blanked.
Touchmode 0 disabled
Mode 4 -
MMM-PIR didn’t get an update since 2020. Are you talking about MMM-Pir from @bugsounet?
@KristjanESPERANTO
Yes apologies, thats the one. -
A Patch will come soon with a new feature
Actually it’s coded for Rpi5 (not really tested on 3b+ and 4)With this new patch, you will able to choice your detection script.
I will deploy it tomorrow ;) -
@bugsounet
I reverted back to the Rpi4 to see if the screen blanking issue worked better?
Moving forward I think perhaps ill go back to the pi5 then. -
Just Released v1.5.0
check new ReadMe
ChangeLog:
Fix: * Increase limit for GPIO number (@outlying) Add: * New feature added pir_mode: * `pir_mode: 0` - use onoff library (For Raspberry Pi 3b+ and 4) * `pir_mode: 1` - use python script with RPI.GPIO library (For Raspberry Pi 3b+ and 4) * `pir_mode: 2` - use python script with gpiozero library (For Raspberry Pi 5, not tested on other Raspberry Pi) -
Many thanks, works a treat.
only outstanding issue is the screen back-light remains on with a glow at night, otherwise all working great.
thank you
