MagicMirror does not start in full screen
@sdetweil OK then I did it right. received now?
@drx1984 yes, just arrived…
@sdetweil OK, great
@drx1984 sadly it looks perfect.
do this
edit~/MagicMirror/installers/mm.sh
insert a new line 2
sleep 10
then reboot
@sdetweil that’s what she means?
@drx1984 yes it will sleep 10 seconds before starting MagicMirror
Hello, hey, it actually works with “sleep 10” Thank you very much. Can you explain to me what “sleep 10” does? Is it normal to make this entry?Can I also add this entry for GPU (export ELECTRON_ENABLE_GPU=1) ?
Like in the picture: -
@drx1984 great news. some timing problem.
yes you can add to the script like that
you can try reducing the sleep to 5 seconds as well
OK, I will do that, thank you very much for your help -
Good morning, you can now mark the topic as “solved”. Thank you
