    MagicMirror does not start in full screen
    42 Posts 2 Posters 26.0k Views 2 Watching
      drx1984 @sdetweil
      @sdetweil Can’t you tell me exactly which line?
      I have now entered it as shown in the picture but unfortunately it doesn’t work.
        sdetweil @drx1984
        @drx1984 in between ANY line in that group… js is a name/value pair, so it doesn’t matter the order…
        BUT you have the wrong values in portrait mode…
        height is 1920, width is 1080
        is it correct on the physical screen?
        from the eletron doc
        https://www.electronjs.org/docs/latest/api/browser-window
        new BrowserWindow([options])
        options BrowserWindowConstructorOptions (optional)
        width Integer (optional) - Window's width in pixels. Default is 800.
        height Integer (optional) - Window's height in pixels. Default is 600.
        x Integer (optional) - (required if y is used) Window's left offset from screen. Default is to center the window.
        y Integer (optional) - (required if x is used) Window's top offset from screen. Default is to center the window.
        useContentSize boolean (optional) - The width and height would be used as web page's size, which means the actual window's size will include window frame's size and be slightly larger. Default is false.
        center boolean (optional) - Show window in the center of the screen. Default is false.
        minWidth Integer (optional) - Window's minimum width. Default is 0.
        minHeight Integer (optional) - Window's minimum height. Default is 0.
          drx1984 @sdetweil
          @sdetweil yes, the resolution is as follows under system settings:
          The monitor is a 24 inch/full HD and is set to portrait format.
          then the values should be correct 1920x1080 right?
            sdetweil @drx1984
            @drx1984 wider than taller (1920x1080) (w,h) is landscape mode
            taller than wider (1080x1920) (w,h) is portrait mode
            are you trying to do both at the same time?
            landscape on physical screen and portrait over connection?
            can’t do that, physical screen wins
              drx1984 @sdetweil
              Good morning,
              So even if I set physical landscape format and restart the system, the MagicMirror doesn’t appear in full screen >> look at the photo I took on my cell phone without Anydesk access.
              And I uploaded a video clip to YouTube: https://www.youtube.com/watch?v=gjiYQ21SoKI
              And I entered the entry with: electronOptions:{width:xxxx, height:yyyy}:
              Where else can the problem be?
              Thanks for your help.
                sdetweil @drx1984
                @drx1984 in the electronOptions add at the end
                ,fullScreen:true
                note the leading comma, as this will be after the height:1080
                  drx1984 @sdetweil
                  @sdetweil Is that what you mean>> electronOptions:{width:1920, height:1080, fullScreen:true}, ?
                  unfortunately nothing came of it
                    sdetweil @drx1984
                    @drx1984 yes…
                    what OS is this
                    show results of
                    lsb_release -a
                    uname -a
                    also, stop MagicMirror and then delete the .config for Electron as before
                    then restart MagicMirror
                      drx1984 @sdetweil
                      @sdetweil Unfortunately I have to leave now sry, I’ll get back to you tomorrow.
                      There is an Ubuntu 22.04.4 installed on an IntelNuc.
                      I have another YouTube video >you can see how it is briefly in full screen at the start and then the full screen goes away again. Watch the video clip until the end: https://www.youtube.com/watch?v=5fRf2pJuET8
                      thanks
                        sdetweil @drx1984
                        @drx1984 ok, how are u launching mm?
                        show results of
                        pm2 status
                        • 2 / 5
