Error by install MMM-Swipe
Hello im new in this forum. My name is Axel and im from Germany so my english ist not the yellow from the egg :-) i hope u can understand me. first of all, a really great thanks for the boys who create the magic mirror, its really unbelievable, respect!!!
i installed already the magic mirror 2 and same modules witch work really nice and everything is good but today i tried to install the model Swipe and i get a error, this one:
pi@Magic-Mirror:~/MagicMirror/modules/MMM-Swipe $ npm install > MMM-Swipe@1.1.1 postinstall /home/pi/MagicMirror/modules/MMM-Swipe > electron-rebuild -e ../../node_modules/electron-prebuilt An unhandled error occurred inside electron-rebuild Unable to find electron-prebuilt's version number, either install it or specify an explicit version Error: Unable to find electron-prebuilt's version number, either install it or specify an explicit version at _callee$ (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/electron-rebuild/lib/cli.js:74:17) at tryCatch (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:63:40) at GeneratorFunctionPrototype.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:337:22) at GeneratorFunctionPrototype.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:96:21) at GeneratorFunctionPrototype.tryCatcher (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/bluebird/js/release/util.js:16:23) at PromiseSpawn._promiseFulfilled (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/bluebird/js/release/generators.js:97:49) at /home/pi/MagicMirror/modules/MMM-Swipe/node_modules/bluebird/js/release/generators.js:201:15 at Object. (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/electron-rebuild/lib/cli.js:197:4) at Module._compile (module.js:570:32) at Object.Module._extensions..js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) at Function.Module._load (module.js:438:3) at Module.runMain (module.js:604:10) at run (bootstrap_node.js:394:7) at startup (bootstrap_node.js:149:9) npm ERR! Linux 4.4.38-v7+ npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" npm ERR! node v6.10.0 npm ERR! npm v3.10.10 npm ERR! code ELIFECYCLE npm ERR! MMM-Swipe@1.1.1 postinstall: `electron-rebuild -e ../../node_modules/electron-prebuilt` npm ERR! Exit status 255 npm ERR! npm ERR! Failed at the MMM-Swipe@1.1.1 postinstall script 'electron-rebuild -e ../../node_modules/electron-prebuilt'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the MMM-Swipe package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! electron-rebuild -e ../../node_modules/electron-prebuilt npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs MMM-Swipe npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls MMM-Swipe npm ERR! There is likely additional logging output above. npm ERR! Please include the following file with any support request: npm ERR! /home/pi/MagicMirror/modules/MMM-Swipe/npm-debug.logsomeone a idea? i hope someone can help me.
thank u very much!!!
@fischi87 did you read and follow the instructions correctly for MMM-swipe?
I e did you run
npm installin the MMM-swipe folder? -
yes of course, u don’t see it in the code?
@fischi87 to me it looks like the dependecies isn’t installed at all
? and what i have to do right now?
when i run
sudo npm starti get back
pi@Magic-Mirror:~/MagicMirror/modules/MMM-Swipe $ sudo npm start npm ERR! Linux 4.4.38-v7+ npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start" npm ERR! node v6.10.0 npm ERR! npm v3.10.10 npm ERR! missing script: start npm ERR! npm ERR! If you need help, you may report this error at: npm ERR! <https://github.com/npm/npm/issues> npm ERR! Please include the following file with any support request: npm ERR! /home/pi/MagicMirror/modules/MMM-Swipe/npm-debug.logwhat is here wrong?!
You are in the wrong folder if you want to start the mirror with
sudo npm start -
@broberg
i get the same in the MagicMirror folderpi@Magic-Mirror:~/MagicMirror $ sudo npm start > magicmirror@2.1.0 start /home/pi/MagicMirror > electron js/electron.js npm ERR! Linux 4.4.38-v7+ npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start" npm ERR! node v6.10.0 npm ERR! npm v3.10.10 npm ERR! code ELIFECYCLE npm ERR! magicmirror@2.1.0 start: `electron js/electron.js` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the magicmirror package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! electron js/electron.js npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs magicmirror npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls magicmirror npm ERR! There is likely additional logging output above. npm ERR! Please include the following file with any support request: npm ERR! /home/pi/MagicMirror/npm-debug.log pi@Magic-Mirror:~/MagicMirror $
