    Open weather Api 3.0
    16 Posts 4 Posters 9.3k Views 5 Watching
    • P Offline
      Peter
      Can somebody help this noob?
      I use the default weather module with Open weather provider.
      Somewhere on this forum I read that Api 2.5 will end in June, so I subscribed to Api 3.0.
      Is this free?
      They asked for creditcard numbers, I still hope this is free.
      And can somebody help me with my config; Api 3.0, lat, long , no idea how to put it in my config.
      An example of a working config with Api 3.0 would help me a lot.
      Greetings,
      Peter
        sdetweil @Peter
        @Peter the same config.js has entries for weather (Openweather is the default provider)
        just add the property
        apiVersion: ‘3.0’,
        and replace the other property values with yours
        the doc for weather is here
        https://docs.magicmirror.builders/modules/weather.html
        you do not need to specify anything that is the same as the doc indicates (like provider)
        as the design is your config.js overrides the defaults for a module.
        read the two links in my signature below. I didn’t write them, they are very helpful
          sdetweil @Peter
          @Peter free for limited number of calls per day
          P 2 Replies Last reply Reply Quote 0
          • P Offline
            Peter @sdetweil
            @sdetweil after adding the version to my config, the weather module does not start.
            module: “weather”,
            position: “top_right”,
            weatherProvider: “openweathermap”,
            apiVersion: ‘3.0’,
            type: “current”,
            locationID: “2759705”, //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
            apiKey: “xxxxxxxxxxxxxxxxxxxxxxxxxxkey removed”
            It works fine with Api 2.5, but do I need lat, lon instead of Location and Locatio ID?
            It is confusing.
            Peter
            • P Offline
              Peter @sdetweil
              @sdetweil what does this limited number mean?
              If I use the default settings do I stay under the limit?
              Peter
                sdetweil @Peter
                @Peter there are multiple providers under weather, some need locationId, some need location name, some need lat/lon
                the top section of the doc applies to all providers, and further down is specifics for each provider
                if it works, then it works.
                limited calls per day 1000 I think., so their doc says
                divide seconds per day by 1000
                stay under that rate.
                we will next release fixes July 1, every 90 days
                • P Offline
                  Peter @sdetweil
                  @sdetweil thanks for your help but I cannot get it working.
                  Maybe somebody else has an idea how to get it working?
                  Peter
                    sdetweil @Peter
                    @Peter I took the sample
                    and added my 3.0 api key… no other changes, I commented out provider as openweather is the default
                    my 2.5 key did not work
                          module: "weather",
                          header: "Weather Forecast",
                            //weatherProvider: "openweathermap",
                            type: "forecast",
                            locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                            apiKey: "mykey"
                            module: "weather",
                            config: {  // type:"current is default"
                              apiKey: "mykey",
                    sorry, had some funky icons in test…
                    also had three instances, picked wrong 2… forecast first, current second
                    • P Offline
                      Peter @sdetweil
                      @sdetweil ok, I did the same, so I removed apiVersion:‘3.0’, now it works.
                      But how can I see if it works on version 2.5 or version 3.0?
                      And how do I recognise a version 3.0 Api key?
                      On the site of Openweather I have several Api keys, but how to recognise a version 3.0?
                      Peter
                        sdetweil @Peter
                        @Peter they don’t tell you. I have many as well.
                        they will tell you to try it… not much use
                        version 3 is only one endpoint, onecall
                        I don’t know how to force the module like that, it changes the endpoint based on the type (current, forecast…)
                        • P Offline
                          Peter @sdetweil
                          @sdetweil ok, I will see what happens when 2.5 stops working.
                          Have a nice day.
                          Peter
                          • N Offline
                            nkc @Peter
                            Hi Just to clarify - I just need to change the api version number from 2.5 to 3.0 or Do I need to subscribe again for api version 3.0. ?
                            Thanks,
                            Neel.
                              sdetweil @nkc
                              @nkc as I understand it yes. 3.0 requires a payment if you exceed the free limit so you must provide a credit card up front.
                                aaronaxvig
                                I found this thread when my usage of the openweathermap.org API stopped working a few days ago. I guess they actually did cut off the API 2.5 users now? Anyways, I have it working using the 3.0 API now. A few comments to help anyone:
                                • I did add my credit card info on my account but I am not 100% sure this was necessary.
                                • I am using the same API key as before.
                                • The locationID value does not appear to work any more. So I have replaced the locationID config lines with lat and lon lines.
                                • The timezone was getting appended to the header so I had to start setting appendLocationNameToHeader to false.
                                Before example:
                                    module: "weather",
                                    header: "Hollywood, FL",
                                        type: "current",
                                        locationID: "4158928",
                                        apiKey: "xxxxxxxxxxxxxxxxxxxxxx",
                                        roundTemp: true
                                After example:
                                    module: "weather",
                                    header: "Mandan, ND",
                                        type: "current",
                                        lat: "46.8258",
                                        lon: "-100.88875",
                                        apiVersion: "3.0",
                                        appendLocationNameToHeader: false,
                                        weatherEndpoint: "/onecall",
                                        roundTemp: true
                                  sdetweil @aaronaxvig
                                  @aaronaxvig yes, thanks for articulating that all in one post.
                                    aaronaxvig @sdetweil
                                    @sdetweil You’re welcome! I saw afterwards that there is another thread with similar info but this is the one the search engine led me to.
                                    After a few days of use I can see on the OpenWeatherMap.org website Billing section that I am running somewhere around 600 API calls per day. This is with four weather modules in place (for four different locations). So about 150 calls per day per module. The default updateInterval value is 10 minutes which would be 144 per day in theory. I’m going to bump my non-local ones to a 30 minute setting (careful to specify milliseconds i.e. 1,800,000 but without commas of course).
