    Show calendar based on IP Address accessed
    68 Posts 3 Posters 27.4k Views 3 Watching
      sdetweil @Spinster
      @Spinster said in Show calendar based on IP Address accessed:
      don’t understand the following instructions, please explain what should I do
      when creating a message here on the forum, if you are inserting code, config, or error text (like you did when u pasted the whole calendar.js, or the part of the module config)
      do the instructions I gave
        @Spinster I rejected your post (AND a second time) . I already fixed the prior
        AND you left your unique info in the module info…
        anyhow…
        found the issue… the ‘identifier’ is based on placement in config.js SO, it will be the SAME on both browsers… oops…
        here are the two lines to fix
        1. in the socketNotificationReceived function
          change this
        		if (this.identifier !== payload.id) {
        			return;
        to this
        		if (this.identifier+(this.ourIPAddress?'_'+this.ourIPAddress:'') !== payload.id) {
        			return;
        and 2.
        in the addCalendar routine
        change this
        to this
          Spinster @sdetweil
          You did it! Excellent, I really appreciate your versatility and quick response.
          Hope this shall become a feature for the calendar or any other modules if anyone has similar requirement and prefers it.
          Sincere Thanks to you and gratitude for your effort and time~
            sdetweil @Spinster
            @Spinster I don’t know if this will become a feature… but at least you know how to add it for your environment
            if it was a feature, I would recommend adding the getip rest api call to the base MM code.
            I updated the prior code changes to include these latest , so its all in one place
            it was a fun, thought provoking, exercise.
              @Spinster another conversation highlighted another change required
              and a bug
              I’ll update my code here later
              oh, and to help you, you could fork the MagicMirror repo
              and use it, adding this code,
              and saving to the repo, so next update
              you can sync the fork and git pull to your system
              sorry my new phone and thumb don’t agree where the keys are… lol and correction never gets it right
                Spinster @sdetweil
                I can’t thank you much for your sincerity in making it correct. Looking forward to the updated code.
                I will try to contribute too in future like you.
                Thank you once again.
                  sdetweil @Spinster
                  @Spinster
                  SO, the ‘bug’ is that this notification , added in pull request 2881 in
                  https://github.com/MagicMirrorOrg/MagicMirror/pull/2881
                  in August 2022
                  edit: I just opened issue 3443 for this problem
                  https://github.com/MagicMirrorOrg/MagicMirror/issues/3443
                  	socketNotificationReceived (notification, payload) {
                  		if (notification === "FETCH_CALENDAR") {
                  			this.sendSocketNotification(notification, { url: payload.url, id: this.identifier });
                  added the code in the WRONG place… socketNotificationReceived is ONLY triggered by the node_helper sendSocketNotification,
                  NOT by other modules doing sendNotification
                  NO OTHER module can force a sendSocketNotification from our helper
                  THAT is notificationReceived… (which we JUST added for the 1st time… oops)
                  So,
                  remove this
                  and move it to the notificationReceived() function
                  @sdetweil said in Show calendar based on IP Address accessed:
                     notificationReceived(notification,payload){
                   	if(notification === 'ALL_MODULES_STARTED'){
                          }  else  if (notification === "FETCH_CALENDAR") {
                  and THEN we need to change the this.identifier to account for the ip based ID, so if some OTHER module
                  asks THIS calendar instance to refresh ITS data, it asks for the correct content
                          	this.sendSocketNotification(notification, { url: payload.url, id: this.identifier+(this.ourIPAddress?'_'+this.ourIPAddress:'') });
                  I’ll add this to the other code, done … I’ll leave the explanation here
                    Spinster @sdetweil
                    Perfect, I did this. Thank you so much for your timely help.
                    Now I am trying to do the same thing in MMM-CalendarEtx2. Because, I want a proper Month Calendar, which is not provided by Calendar.
                    Is there any module which can display two month calendar, since I searched in modules and could not find.
                      sdetweil @Spinster
                      @Spinster ext2 is dead. use ext3, it uses the broadcast from the default calendar module which now is just those for this system
                      uh, hard to put up one wall cal view, 2 I don’t know.
                      remove position from default cal, it won’t display but will send it broadcast
                        Spinster @sdetweil
                        Oh I did not know, but ext3, I don’t see an option to view a month calendar (not month schedule). I am looking for something like MMM-CalendarExtMiniMonth. Please let me know if this option is available
                        • 6
                        • 7
                        • 6 / 7
