    Show calendar based on IP Address accessed
    68 Posts 3 Posters 27.4k Views 3 Watching
      Spinster @MMRIZE
      @MMRIZE Browser as of now.
      I also tried using express ipfilter, but the problem is I don’t know how to use it in module.js, it is throwing error saying ipfilter not known etc
        sdetweil @Spinster
        @Spinster well, here is a working example, in addition to the other code already
        watch out if using address AND MM host system not included. as it won’t show either…
        one could make the ipaddress in cal a list (of ip addresses) similar to what @MMRIZE does…
        I don’t like adding the extra block,
        just add the var to the thing that matters…
        see later post
          MMRIZE @Spinster
          @Spinster
          With getip of @sdetweil and MMM-ModuleMonkeyPatch, I did it. (You don’t have to modify the original source code for future-proof.)
          Example.
          Server is running on 192.168.178.63 and I run 2 clients on 192.168.178.22 and 192.168.178.63.
          Both 2 clients can show different set of calendars.
          	module: "MMM-ModuleMonkeyPatch",
          		patches: [
          				method: "socketNotificationReceived",
          				patch: async function (original, args) {
          					const [ notification, payload ] = args
          					if (notification === "CALENDAR_EVENTS") {
          						const calendarName = this.config.calendars.find((cal) => cal.url === payload?.url)?.name
          						const r = await fetch('http://192.168.178.63:8080/modules/getip')
          						const ip = JSON.parse(await r.text())?.[ 'address' ] ?? null
          						if (!this.config.clientMap?.[ ip ]?.includes(calendarName)) {
          							return original(notification, { ...payload, events: [] })
          					return original(notification, payload)
          	module: "getip",
          	header: "US Holidays",
          		clientMap: {
          			"192.168.178.63": [ "cal1", "cal2", "cal3" ],
          			"192.168.178.22": ["cal3", "cal4", "cal5"]
          				url: "...",
          				url: "...",
          				url: "...",
          				url: "...",
          				url: "...",
          TO Improve
          Whenever notification CALENDAR_EVENTS coming, getip is called. After first execution, to store IP on the localStorage or cookie would be better.
          S S 2 Replies Last reply Reply Quote 0
            Spinster @sdetweil
            @sdetweil will express ipfilter be useful? Similar to whitelist, can we try something
              sdetweil @Spinster
              @Spinster no… as its in the wrong place… (inside node_helper…) we NEED the ip address to compare with
              just get it and return . one time
                sdetweil @MMRIZE
                @MMRIZE said in Show calendar based on IP Address accessed:
                BUT you are fetching cal for system not going to use it… SOME cals are 1000’s of entries especially old
                that have to be processed… this is a bad waste of resources…
                and this exposes a cal problem, as if u fetch http://xyz on client 1 and client 2 and client 3, we fetch it 3 times. also bad
                this could also lead to different clients showing different data between fetchIntervals…
                  MMRIZE @sdetweil
                  @sdetweil said in Show calendar based on IP Address accessed:
                  I Can’t understand your point.
                  My code is just small injection that does filtering out calendars by condition on socketNotificationReceived. No additional fetching is needed.
                    MMRIZE @sdetweil
                    Well, if that is the issue, we need a new “calendar” module that can ignore duplicated feed on addCalendar.
                    Regardless of my code, the original calendar module will fetch a same feed multiply on multi clients. It’s MM’s limitation.
                      sdetweil @MMRIZE
                      @MMRIZE yes
                      @Spinster
                      see later post
                        sdetweil @MMRIZE
                        AFTER fetching… so throw away data, which we fetched , knowing we wouldn’t use it…
                        • 6
                        • 7
                        • 3 / 7
