    Show calendar based on IP Address accessed
    68 Posts 3 Posters 21.4k Views 3 Watching
      @Spinster ok, here is the final
      in calendar.js
      add these variables
      		updateOnFetch: true,
      		useIPAddress: false     // add config var
      	timerHandle:null,                 // add this
      	ourIPAddress:null,              // add this
      	requiresVersion: "2.1.0",
      change this
      	// Override start method.
      	start () {
      to
      this
      	startup () {
      add this code
      			let ip_match = false;
      			if(this.config.useIPAddress){
      			 const client_ip_for_this_calendar = this.getCalendarProperty(calendar.url, "ipaddress", null)
      			 if(this.ourIPAddress)
      			 	  ip_match = client_ip_for_this_calendar.includes(this.ourIPAddress)
      			if(this.config.useIPAddress == false || ip_match==true)
      			  this.addCalendar(calendar.url, calendar.auth, calendarConfig);   // old original   line
      and add this routine somewhere
        notificationReceived(notification,payload){
        	if(notification === 'ALL_MODULES_STARTED'){
        		// if we are using ip address checking
        			// loop thru all the modules
        			let m = MM.getModules().withClass("getip");
        			if(m.length){
        				// if getip is configured and not disabled
        				if((m[0].disabled== undefined || (m[0].disabled != undefined && m[0].disabled == false)) ){
        					// start a timer to wait for getip to finish
        					this.timerHandle = setInterval(()=>{
        						// get its dom content
        						let client_ip = document.getElementById("getip_address")
        						// if we found id
        						if(client_ip !== null){
        							// stop the timer
        							clearInterval(this.timerHandle)
        							// save our IP address, only need to look it up once
        							this.ourIPAddress=client_ip.innerText
        							// call startup
        							this.startup()
        					}, 500)
        			// thru the loop, didn't start a timer, module not found
      			  if(this.timerHandle === null){
      					// didn't find getip
      					// module not found, can't do this later either
      					this.config.useIPAddress = false;
      					this.startup()
        		// use default
        		else
        			this.startup()
        	else if (notification === "FETCH_CALENDAR") {
      			this.sendSocketNotification(notification, { url: payload.url, id: this.identifier+(this.ourIPAddress?'_'+this.ourIPAddress:'') });
      and in the socketNotificationReceived routine
      change this
      	socketNotificationReceived (notification, payload) {
      			this.sendSocketNotification(notification, { url: payload.url, id: this.identifier });
      		if (this.identifier !== payload.id) {
      			return;
      to this
      		if (this.identifier+(this.ourIPAddress?'_'+this.ourIPAddress:'') !== payload.id) {
      			return;
      and in the addCalendar routine
      change this
      to this
      to use
      add the getip module to config.js, anywhere
      add property to calendar above the calendars list (but still inside the config:{}{ section)
      useIPAddress:true,
      in any cal url block you want to be sensitive to IP address add property
          ipaddress:"xxx yyy zzz",  // space separated list of client ipaddresses this calendar can be displayed on
      andhow
        Spinster @MMRIZE
        @MMRIZE
        After installing MonkeyPatch and adding the patch you have mentioned, I get the following error message when I run , npm run config:check
        [2024-05-07 23:32:55.179] [INFO] Checking file… /home/vjkings/MagicMirror/config/config.js
        [2024-05-07 23:32:55.222] [ERROR] Your configuration file contains syntax errors :(
        [2024-05-07 23:32:55.223] [ERROR] Line 56 column 20: Parsing error: Unexpected token function
        As per config.js, Line 56 is this
        patch: async function (original, args) {
        Whole section of patch as follows
        const [ notification, payload ] = args
        if (notification === “CALENDAR_EVENTS”) {
        const calendarName = this.config.calendars.find((cal) => cal.url === payload?.url)?.name
        const r = await fetch(‘http://192.168.1.4:8080/modules/getip’)
        const ip = JSON.parse(await r.text())?.[ ‘address’ ] ?? null
        if (!this.config.clientMap?.[ ip ]?.includes(calendarName)) {
        return original(notification, { …payload, events: [] })
        return original(notification, payload)
        If I ignore the error and run the server, I don’t get any calendar and it just says Loading… in the mirror page
        What is the reason for the error. Please advice
          Spinster @sdetweil
          Wow, Clear, will try it and provide feedback please.
            Spinster @sdetweil
            I made all the changes you have mentioned, it is working!!!. Thank you so much for the efforts.
            However, following are the observation,
            When I add the config.js with useIPAddress: true (calendar.js has the entry of useIPAddress:false in its default), there is no effect, however in calendar.js if I set the useIPAddress: true, it is working, I don’t understand why the configuration settings are not taken.
            I clearly added the useIPAddress: true before the calendars declared as part of the module configuration. Please advice how to fix this.
            I also have doubt on when we override the start to startup, how the notificationreceived is called. What happens when there is no start in the module.
            In fact this is the first time, I have added code without understanding of anything :).
            Please help me with configuration settings (config.js) to get it effected than hardcoding it to calendar.js
              sdetweil @Spinster
              @Spinster can you show the calendar config, you can leave out the calendars:[] list entries
              start is optional. but only called once
              getip has not placed its content yet.
              the notification ALL_MODULES_STARTED is sent be the system when all the
              modules start methods have been called
              from the module development doc
                Spinster @sdetweil
                Thank you for the details.
                As required, my calendar config as follows
                		module: "getip",
                		position:"bottom_left"
                		useIPAddress: true,
                		header: "My Calendars",
                					fetchInterval: 5 * 60 * 1000,
                					symbol: "calendar-check",
                					url: "https://mycalendar/xEzboFt7Kr3Yfiys?export",
                					ipaddress: "10.5.18.252 127.0.0.1 10.5.14.104",
                					fetchInterval: 10 * 60 * 1000,
                					//useIPAddress: true,
                					url: "https://mycalendar/4aK7xZPQkGKz6nCZ?export",
                					ipaddress: "10.5.11.5",
                Please let me know if I have done any mistake
                  sdetweil @Spinster
                  @Spinster yes, it has to be inside the
                  config:{} section
                  everything outside config are MagicMirror properties about a module
                  see
                  https://docs.magicmirror.builders/modules/configuration.html#example
                  config is properties FOR the module and override what is defined in the module defaults:{} object
                    Spinster @sdetweil
                    I made the change and it first showed correctly, but when I refresh any one of the client, the other client is getting both the calendars. What is wrong? Here is my updated calendar.js as suggested by you.
                    /* global CalendarUtils */
                    Module.register("calendar", {
                    	// Define module defaults
                    	defaults: {
                    		maximumEntries: 10, // Total Maximum Entries
                    		maximumNumberOfDays: 365,
                    		limitDays: 0, // Limit the number of days shown, 0 = no limit
                    		pastDaysCount: 0,
                    		displaySymbol: true,
                    		defaultSymbol: "calendar-alt", // Fontawesome Symbol see https://fontawesome.com/cheatsheet?from=io
                    		defaultSymbolClassName: "fas fa-fw fa-",
                    		showLocation: false,
                    		displayRepeatingCountTitle: false,
                    		defaultRepeatingCountTitle: "",
                    		maxTitleLength: 25,
                    		maxLocationTitleLength: 25,
                    		wrapEvents: false, // Wrap events to multiple lines breaking at maxTitleLength
                    		wrapLocationEvents: false,
                    		maxTitleLines: 3,
                    		maxEventTitleLines: 3,
                    		fetchInterval: 60 * 60 * 1000, // Update every hour
                    		animationSpeed: 2000,
                    		fade: true,
                    		fadePoint: 0.25, // Start on 1/4th of the list.
                    		urgency: 7,
                    		timeFormat: "relative",
                    		dateFormat: "MMM Do",
                    		dateEndFormat: "LT",
                    		fullDayEventDateFormat: "MMM Do",
                    		showEnd: false,
                    		getRelative: 6,
                    		hidePrivate: false,
                    		hideOngoing: false,
                    		hideTime: false,
                    		hideDuplicates: true,
                    		showTimeToday: false,
                    		colored: false,
                    		forceUseCurrentTime: false,
                    		tableClass: "small",
                    				symbol: "calendar-alt",
                    				url: "https://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                    		customEvents: [
                    			// Array of {keyword: "", symbol: "", color: "", eventClass: ""} where Keyword is a regexp and symbol/color/eventClass are to be applied for matched
                    			{ keyword: ".*", transform: { search: "De verjaardag van ", replace: "" } },
                    			{ keyword: ".*", transform: { search: "'s birthday", replace: "" } }
                    		locationTitleReplace: {
                    			"street ": ""
                    		broadcastEvents: true,
                    		excludedEvents: [],
                    		sliceMultiDayEvents: false,
                    		broadcastPastEvents: false,
                    		nextDaysRelative: false,
                    		selfSignedCert: false,
                    		coloredText: false,
                    		coloredBorder: false,
                    		coloredSymbol: false,
                    		coloredBackground: false,
                    		limitDaysNeverSkip: false,
                    		flipDateHeaderTitle: false,
                    		useIPAddress: false,// add config var
                    	// Define required scripts.
                    	getStyles () {
                    		return ["calendar.css", "font-awesome.css"];
                    	getScripts () {
                    		return ["calendarutils.js", "moment.js"];
                    	// Define required translations.
                    	getTranslations () {
                    		// The translations for the default modules are defined in the core translation files.
                    		// Therefore we can just return false. Otherwise we should have returned a dictionary.
                    		// If you're trying to build your own module including translations, check out the documentation.
                    		return false;
                    	startup () {
                    		//const ip = settings.detectIp(req)
                    		Log.info(`Starting module: ${this.name}`);
                    		Log.info(`Vijay starup Starting module: ${this.name}`);
                    		if (this.config.colored) {
                    			Log.warn("Your are using the deprecated config values 'colored'. Please switch to 'coloredSymbol' & 'coloredText'!");
                    			this.config.coloredText = true;
                    			this.config.coloredSymbol = true;
                    		if (this.config.coloredSymbolOnly) {
                    			Log.warn("Your are using the deprecated config values 'coloredSymbolOnly'. Please switch to 'coloredSymbol' & 'coloredText'!");
                    			this.config.coloredText = false;
                    		// Set locale.
                    		moment.updateLocale(config.language, CalendarUtils.getLocaleSpecification(config.timeFormat));
                    		// clear data holder before start
                    		this.calendarData = {};
                    		// indicate no data available yet
                    		this.loaded = false;
                    		// data holder of calendar url. Avoid fade out/in on updateDom (one for each calendar update)
                    		this.calendarDisplayer = {};
                    		this.config.calendars.forEach((calendar) => {
                    			calendar.url = calendar.url.replace("webcal://", "http://");
                    			const calendarConfig = {
                    				maximumEntries: calendar.maximumEntries,
                    				maximumNumberOfDays: calendar.maximumNumberOfDays,
                    				pastDaysCount: calendar.pastDaysCount,
                    				broadcastPastEvents: calendar.broadcastPastEvents,
                    				selfSignedCert: calendar.selfSignedCert,
                    				excludedEvents: calendar.excludedEvents,
                    				fetchInterval: calendar.fetchInterval
                    			if (typeof calendar.symbolClass === "undefined" || calendar.symbolClass === null) {
                    				calendarConfig.symbolClass = "";
                    			if (typeof calendar.titleClass === "undefined" || calendar.titleClass === null) {
                    				calendarConfig.titleClass = "";
                    			if (typeof calendar.timeClass === "undefined" || calendar.timeClass === null) {
                    				calendarConfig.timeClass = "";
                    			// we check user and password here for backwards compatibility with old configs
                    			if (calendar.user && calendar.pass) {
                    				Log.warn("Deprecation warning: Please update your calendar authentication configuration.");
                    				Log.warn("https://docs.magicmirror.builders/modules/calendar.html#configuration-options");
                    				calendar.auth = {
                    					user: calendar.user,
                    					pass: calendar.pass
                    			//this.addCalendar(calendar.url, calendar.auth, calendarConfig);
                    		// for backward compatibility titleReplace
                    		if (typeof this.config.titleReplace !== "undefined") {
                    			Log.warn("Deprecation warning: Please consider upgrading your calendar titleReplace configuration to customEvents.");
                    			for (const [titlesearchstr, titlereplacestr] of Object.entries(this.config.titleReplace)) {
                    				this.config.customEvents.push({ keyword: ".*", transform: { search: titlesearchstr, replace: titlereplacestr } });
                    		this.selfUpdate();
                    	// Override socket notification handler.
                    			return;
                    		if (notification === "CALENDAR_EVENTS") {
                    			Log.warn("Calendar Events called Vijay");
                    			if (this.hasCalendarURL(payload.url)) {
                    				this.calendarData[payload.url] = payload.events;
                    				this.error = null;
                    				this.loaded = true;
                    				if (this.config.broadcastEvents) {
                    					this.broadcastEvents();
                    				if (!this.config.updateOnFetch) {
                    					if (this.calendarDisplayer[payload.url] === undefined) {
                    						// calendar will never displayed, so display it
                    						this.updateDom(this.config.animationSpeed);
                    						// set this calendar as displayed
                    						this.calendarDisplayer[payload.url] = true;
                    					} else {
                    						Log.debug("[Calendar] DOM not updated waiting self update()");
                    					return;
                    		} else if (notification === "CALENDAR_ERROR") {
                    			let error_message = this.translate(payload.error_type);
                    			this.error = this.translate("MODULE_CONFIG_ERROR", { MODULE_NAME: this.name, ERROR: error_message });
                    			this.loaded = true;
                    	eventEndingWithinNextFullTimeUnit (event, ONE_DAY) {
                    		const now = new Date();
                    		return event.endDate - now <= ONE_DAY;
                    		if(notification === 'ALL_MODULES_STARTED') {
                    			Log.info(`Vijay Calling : ${this.name}`);
                    			console.log("Vijay : Calendar notificationReceived called");
                    				console.log("Vijay : Calendar Using IP Address");
                    				// find our dependent module in config.js, returns an array []
                    				if(m.length){
                    					// if getip is not disabled
                    					if((m[0].disabled == undefined || (m[0].disabled != undefined && m[0].disabled == false)) ){
                    							// if we found id
                    								// stop the timer
                    								// call startup
                    								this.startup()
                    						}, 500)
                    				// didn't start a timer, module not found
                    						// turn off address checking
                    						// start fetching calendars
                    						Log.info(`Vijay No timer, useIP set to false: ${this.name}`);
                    						this.startup()
                    			// use old approach
                    			else{
                    				Log.info(`Vijay timer available :  ${this.name}`);
                    				this.startup()
                    Please let me know if I have to do something about this.
                      sdetweil @Spinster
                      @Spinster sorry, explain
                      the other client
                      on refresh, everything is the same in the module.
                      each module has a unique id assigned, based on its placement in config.js
                      calendar sends its id down to its helper
                      and the helper sends the id back on response. as the response mechanism is a broadcast to all connected clients.
                      the clients then check to see if this response is for their request.
                      from code posted
                      also, please start using code block wrapper for all config, code and error postings
                      paste text into the message editor
                      empty line above and below
                      select that pasted text
                      hit the editor button </>
                        Spinster @sdetweil
                        Sorry for not explaining it clearly.
                        I have two clients, one from a browser using http://ip:8080 and another the native client.
                        upon using pm2 start MagicMirror, I get the out put in native client and the browser properly showing their respective calendar.
                        If I hit refresh button on browser, browser is showing only its own calendar however the native client is displaying both the calendars (ie. its own and the one which is supposed to be shown in browser), If I hit Ctr-R on the native client, then browser is showing both the calendars while the native client is showing only its own calendar.
                        Also I don’t understand the following instructions, please explain what should I do
                        • 6
                        • 7
                        • 5 / 7
