    mmm-netatmo
    7 Posts 5 Posters 1.7k Views 6 Watching
      anton2023
      Re: MMM-Netatmo does not load
      same issue here, it seems to loose the refresh token each day:
      i have to re create a refresh token , and copy it to the config, js, the module works.
      the following morning after the pi shutdown, the module isn,t working, need to re create a refresh token for it works…
      • mumblebajM Offline
        mumblebaj Module Developer @anton2023
        @anton2023 Can you please explain
        @anton2023 said in mmm-netatmo:
        Are you switching off the PI completely? have you tried running the PI through the evening?
        If I read the code correctly, it fetches the new token after the refresh interval. But if the PI was shutdown, it requires a valid token to start working again. If the PI is not shutdown, the module should run fine, fetching the new token if the old one has expired as it would do throughout the day.
          anton2023
          yes i turn off the pi during the night
          so when is the refresh interval?
          thx for your answer
            sdetweil @anton2023
            @anton2023 the doc for the module shows
              anton2023
              i thought the refresh interval was only for temperature, pressure… update,
              not also for the token
              so for the module works the pi have to be on all the time which is seem odd to me
              bugsounetB 1 Reply Last reply Reply Quote 0
              • bugsounetB Offline
                bugsounet Banned @anton2023
                Hi, I just fix it in my MMM-NetatmoThermostat module (same API … so same Issue)
                See there
                Author of this module have to do some changes
                My Change in GitHub, if can help it
                @bugsounet
                • W Offline
                  winniepunk
                  I have the same problem with mmm netatmo and refresh token
                  Did you find a solution?
                  Thank you
