    Error EBADENGINE when installing MM v2.28.0
    28 Posts 2 Posters 11.0k Views 2 Watching
    • I
      Ix
      Hello!
      I have issues updating my MagicMirror to the current version 2.28.0.
      When I run npm install I get this error message:
      mirror@raspberrypi:~/MagicMirror $ sudo npm run install-mm
      > magicmirror@2.28.0 install-mm
      > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
      npm error code EBADENGINE
      npm error engine Unsupported engine
      npm error engine Not compatible with your version of node/npm: magicmirror@2.28.0
      npm error notsup Not compatible with your version of node/npm: magicmirror@2.28.0
      npm error notsup Required: {"node":">=20"}
      npm error notsup Actual:   {"npm":"10.8.1","node":"v18.17.1"}
      npm error A complete log of this run can be found in: /root/.npm/_logs/2024-08-04T16_49_26_116Z-debug-0.log
      seems easy to solve, but I absolutely fail to bring my node to the required version.
      using nvm current I get this answer:
      mirror@raspberrypi:~/MagicMirror $ nvm current
      v20.16.0
      Edit: this is what happens if I try and install node via n:
      mirror@raspberrypi:~ $ sudo n lts
        installing : node-v20.16.0
             mkdir : /usr/local/n/versions/node/20.16.0
             fetch : https://nodejs.org/dist/v20.16.0/node-v20.16.0-linux-arm64.tar.xz
           copying : node/20.16.0
      /usr/bin/n: Zeile 746: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
         installed :  (with npm 10.8.1)
      so it should work… PLEASE help!
        sdetweil @Ix
        @Ix ONE… NEVER EVER use sudo for MM commands, EVER…
        once you do that then you HAVE to use SUDO for a lot of things you don’t want to give root permissions
        note node and npm are not MM commands
        SO, you had to upgrade node and npm for this release BEFORE doing the upgrade
        see https://forum.magicmirror.builders/topic/18836/v2-28-0
        OR, you could have run the upgrade command from my scripts repo
        see https://github.com/sdetweil/MagicMirror_scripts
        for node version, check (not what nvm thinks)
        node -v
        my scripts use the tool n, which is nvm written in javascript…
        I 1 Reply Last reply
        • I
          Ix @sdetweil
          first: thanks for answering so fast!
          node -v gives this:
          mirror@raspberrypi:~ $ node -v
          v20.16.0
          this is also the version I installed via n
          nevertheless, the wrong version is recognized when trying npm i
            sdetweil @Ix
            @Ix how about npm -v
            • I
              Ix @sdetweil
              mirror@raspberrypi:~ $ npm -v
              10.8.1
                sdetweil @Ix
                @Ix ok, can u give the output of
                npm run install-mm
                now
                • I
                  Ix @sdetweil
                  @sdetweil said in Error EBADENGINE when installing MM v2.28.0:
                  npm run install-mm
                  mirror@raspberrypi:~/MagicMirror $ npm run install-mm
                  npm error A complete log of this run can be found in: /root/.npm/_logs/2024-08-04T17_53_51_013Z-debug-0.log
                    sdetweil @Ix
                    @Ix said in Error EBADENGINE when installing MM v2.28.0:
                    ok, it thinks you are running npm as root… probably cause of some sudo somwhere…
                    show results of
                    whoami
                    cd ~/MagicMirror
                    ls -laF
                    • I
                      Ix @sdetweil
                      whoami
                      mirror@raspberrypi:~/MagicMirror $ whoami
                      mirror
                      and ls in MM directory:
                      mirror@raspberrypi:~/MagicMirror $ ls -laF
                      insgesamt 688
                      drwxr-xr-x  18 mirror mirror   4096  4. Aug 17:48 ./
                      drwxr-xr-x  26 mirror mirror   4096  3. Jul 09:30 ../
                      -rw-r--r--   1 mirror mirror  83743  4. Aug 17:48 CHANGELOG.md
                      drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 clientonly/
                      -rw-r--r--   1 mirror mirror   1617  3. Apr 17:11 Collaboration.md
                      drwxr-xr-x   2 mirror mirror   4096  4. Aug 17:48 config/
                      drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 css/
                      -rw-r--r--   1 mirror mirror  10244  2. Jul 21:56 .DS_Store
                      -rw-r--r--   1 mirror mirror    238  2. Okt 2023  .editorconfig
                      -rw-r--r--   1 mirror mirror     27  3. Apr 17:11 .eslintignore
                      -rw-r--r--   1 mirror mirror   3020  3. Apr 17:11 .eslintrc.json
                      drwxr-xr-x   3 mirror mirror   4096  4. Aug 17:48 fonts/
                      drwxr-xr-x   8 mirror mirror   4096  4. Aug 20:28 .git/
                      -rw-r--r--   1 mirror mirror   1034  2. Okt 2023  .gitattributes
                      drwxr-xr-x   3 mirror mirror   4096  3. Apr 17:11 .github/
                      -rw-r--r--   1 mirror mirror   1140  3. Apr 17:11 .gitignore
                      drwxr-xr-x   3 mirror mirror   4096  3. Apr 17:11 .husky/
                      -rw-r--r--   1 mirror mirror   3103  2. Okt 2023  index.html
                      drwxr-xr-x   2 mirror mirror   4096  4. Aug 19:18 installers/
                      -rw-r--r--   1 mirror mirror   1096  2. Okt 2023  jest.config.js
                      drwxr-xr-x   2 mirror mirror   4096  4. Aug 17:48 js/
                      -rw-r--r--   1 mirror mirror    264  2. Okt 2023  jsconfig.json
                      -rw-r--r--   1 mirror mirror   1098  3. Apr 17:11 LICENSE.md
                      -rw-r--r--   1 mirror mirror   6947  3. Apr 17:11 mm2.png
                      drwxr-xr-x  13 mirror mirror   4096  3. M?r 11:49 modules/
                      -rw-r--r--   1 mirror mirror   1130  2. Okt 2023  module-types.ts
                      drwxr-xr-x 414 root   root    28672  3. Apr 17:16 node_modules/
                      -rw-r--r--   1 mirror mirror     48  3. Apr 17:11 .npmrc
                      -rw-r--r--   1 mirror mirror   3694  4. Aug 17:48 package.json
                      -rw-r--r--   1 mirror mirror 414176  4. Aug 17:48 package-lock.json
                      -rw-r--r--   1 mirror mirror     96  3. Apr 17:11 .prettierignore
                      -rw-r--r--   1 mirror mirror     29  2. Okt 2023  .prettierrc.json
                      -rw-r--r--   1 mirror mirror   3279  3. Apr 17:11 README.md
                      drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 serveronly/
                      drwxr-xr-x   2 mirror mirror   4096  2. Okt 2023  splashscreen/
                      -rw-r--r--   1 mirror mirror    126  2. Okt 2023  .stylelintrc.json
                      drwxr-xr-x   8 mirror mirror   4096  4. Jan 2024  tests/
                      drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 translations/
                      drwxr-xr-x   4 mirror mirror   4096  4. Aug 17:48 vendor/
                        sdetweil @Ix
                        my only guess
                        SO, lets try
                        cd ~/MagicMirror
                        # using sudo here only to remove the root owned folder
                        sudo rm -rf node_modules
                        npm run install-mm
                        • I
                          Ix @sdetweil
                          I deleted node_modules directory as recommended and after that, this is what happened:
                          npm error notsup Actual:   {"npm":"10.8.2","node":"v18.18.0"}
                          npm error A complete log of this run can be found in: /home/mirror/.npm/_logs/2024-08-04T20_08_34_045Z-debug-0.log
                          Now it says it’s running on node v18.18.0 instead of v18.17.1 but still not v20.16 which is installed. I don’t get it at all…
                            sdetweil @Ix
                            @Ix wild… never seen this.
                            SO, i would use nvm and n to remove all the added node versions…
                            get back to whatever before…
                            exit the shell window and open again
                            verify still on the prior nodejs
                            then use n version_number
                            sudo n 20.9
                            verify that is correct node -v
                            the close shell and open again,
                            verify node
                            then try the npm run install-mm again
                            • I
                              Ix @sdetweil
                              done
                              done
                              sudo n 20.9
                              verify node
                              well, now there’s another problem:
                              mirror@raspberrypi:~ $ sudo n 20.9
                                   copying : node/20.9.0
                                 installed :  (with npm 10.1.0)
                              -bash: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
                              Sry for German: it’s “no such file or directory”
                                sdetweil @Ix
                                @Ix do
                                which node
                                Then
                                sudo rm $(which node)
                                Then
                                hash -r
                                which node
                                and again
                                Then node -v
                                • I
                                  Ix @sdetweil
                                  okay done all that, node is completely gone from my machine. I guess, reinstalling it would be the next step?
                                    sdetweil @Ix
                                    @Ix rename the MagicMirror folder and run my install script
                                    S I 2 Replies Last reply
                                      @Ix then rename new out and old back in and do the npm run install-mm
                                      • I
                                        Ix @sdetweil
                                        Tried that, but the script failed. I have attached the install.log
                                        install starting  - Mon Aug  5 18:37:16 CEST 2024
                                        installing on aarch64 processor system
                                        the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
                                                       total        used        free      shared  buff/cache   available
                                        Mem:            1849         228        1116          30         504        1527
                                        Swap:           2047           0        2047
                                        Updating packages ...
                                        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease Reading package lists...
                                        apt-get update  completed ok
                                        Building dependency tree...
                                        Reading state information...
                                        pv is already the newest version (1.6.6-1).
                                        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                        apt-get upgrade  started
                                        apt-get upgrade result =rc=0 Reading package lists...
                                        Calculating upgrade...
                                        Installing helper tools ...
                                        build-essential is already the newest version (12.9).
                                        curl is already the newest version (7.74.0-1.3+deb11u12).
                                        git is already the newest version (1:2.30.2-1+deb11u2).
                                        unzip is already the newest version (6.0-26+deb11u1).
                                        wget is already the newest version (1.21-1+deb11u1).
                                        node not installed, trying via apt-get
                                        Reading package lists... Building dependency tree... Reading state information... E: Unable to locate package nodejs:armv7l E: Unable to locate package npm:armv7l
                                        npm not installed, trying via apt-get
                                        npm installed now, install n
                                        Reading package lists... Building dependency tree... Reading state information... Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: libnode72 : Conflicts: nodejs-legacy nodejs : Conflicts: npm E: Unable to correct problems, you have held broken packages.
                                        installing on bullseye
                                        node failed to execute, please check the error message and resolve before trying again
                                        install aborted - Mon Aug  5 18:37:59 CEST 2024
                                          sdetweil @Ix
                                          @Ix do node -v
                                          • I
                                            Ix @sdetweil
                                            @Ix do node -v
                                            bash: node: command not found
