    Not updating at midnight...
    24 Posts 3 Posters 4.1k Views 3 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      I’m having trouble with my module (multimonth) not updating at midnight as expected. It will update on notification as shown, however.
      This used to work - can someone please take a look and see what broke, or if something changed in MagicMirror core that I didn’t pick up on that’s affecting?
      Thanks.
          start: function () {
              date = new Date();
              month = date.getMonth();
              day = date.getDate();
              nextday = day + 1;
              year = date.getFullYear();
              reset = new Date(year, month, nextday, 0, 0, 0, 0).getTime() - date.getTime();
              var timer = setInterval(() => {
                  this.updateDom()
              }, reset)
              this.storedEvents = [];
              this.matchEvents = [];
          notificationReceived: function (notification, payload, sender) {
              if (notification === 'CALENDAR_EVENTS') {
                  this.storedEvents = JSON.parse(JSON.stringify(payload))
                  this.updateDom();
      • BKeyportB Offline
        @sdetweil yeah, doing it that way just throws headers with “Undefined” until it triggers. I’m not gonna go down that rabbit hole. It seems to work as is, so I’m gonna release for now.
          sdetweil @BKeyport
          @BKeyport the code sets the interval to midnight -now
          So unless this is started at midnight- it will update whenever
          So you need a set timeout for now til midnight, and then an interval for every midnight since this first midnight
          So updateDom
          Now
          Timeout Midnight tonight
          Start interval for next and following midnights
          • BKeyportB Offline
            I think you see it backwards.
            Look at the reset variable again.
            This line calculates the difference between the current time and midnight of the next day. It does this by creating a new Date object for the next day at 00:00:00.000 (midnight) and subtracting the current time from it.
            The variable timer is then set using the reset variable, so…
            Assuming it’s currently 6:30pm on August 8th, 2024.
            2024/8/9 0:0:0.0 - 2024/8/8 18:30:0.0
            1723186800 - 1723167000 (Dropping the milliseconds if used)
            = 19800
            then the timer is set using setInterval() to “reset” or 19800 - which would be the next midnight.
            After the first one, it should be calculating so close to midnight, it’s an non-issue.
              sdetweil @BKeyport
              @BKeyport setInterval creates a repeating timer with ONE elapsed time
              6:30pm to midnight the next day is 24+5.5
              So every 29.5 hours it will fire.
              1st correct for tomorrow night,
              it will miss tonight’s midnight
              And then be off from them on, shifting 5.5 hours later each time
              24 hours of seconds is 86400
              If you think of it as morning, then it will fire every 5.5 hours. Still not 24
              After the first one, it should be calculating so close to midnight, it’s an non-issuee
              This part is incorrect. setInterval only looks at the value ONE time.
              Sorry, computer is stupid. It has one time event setTimeout, or interval setInterval. Both use the elapsed time only once, at creation
              • BKeyportB Offline
                @sdetweil The problem is that it’s not firing at all - it was working as is… Now it’s not firing, first, last, middle, or any other time.
                  sdetweil @BKeyport
                  @BKeyport make your own routine to be called
                  this.update2()
                  Prove it fires
                  • BKeyportB Offline
                    @sdetweil It’s people like you that drive people out of coding. This isn’t fun anymore.
                    Is there anyone other than Sam that could explain why this don’t work anymore?
                      sdetweil @BKeyport
                      @BKeyport that’s very disappointing to hear.
                      I thought I was being helpful in giving ways to debug the problem.
                      I do not KNOW why it appears to be failing. None of the changes to the mm core appear to affect updateDom
                        MMRIZE
                        How about this? not tested.
                          this.dailyTimer = null
                          const moment = new Date()
                          const midnight = new Date(moment.getFullYear(), moment.getMonth(), moment.getDate() + 1, 0, 0, 0, 0)
                          const toMidnight = midnight - moment
                          setTimeout(() => {
                            this.doSomething()
                          }, toMidnight)
                        doSomething: function () {
                          clearTimeout(this.dailyTimer)
                          // Do your job here.
                          this.dailyTimer = setTimeout(() => {
                            this.doSomething()
                          }, 24 * 60 * 60 * 1000)
                          sdetweil @MMRIZE
                          @MMRIZE right, thats a way without interval timer
                          I added this to compliments with the cron entries to get the interval synched to the minute
                           let minute_sync_delay = 1;
                          		// loop thru all the configured when events
                          		for (let m of Object.keys(this.config.compliments)) {
                          			// if it is a cron entry
                          			if (this.isCronEntry(m)) {
                          				// we need to synch our interval cycle to the minute
                          				minute_sync_delay = (60 - (moment().second())) * 1000;
                          				break;
                          		// Schedule update timer. sync to the minute start (if needed), so minute based events happen on the minute start
                          		setTimeout(() => {
                          			setInterval(() => {
                          				this.updateDom(this.config.fadeSpeed);
                          			}, this.config.updateInterval);
                          		minute_sync_delay);
                            sdetweil @MMRIZE
                            @MMRIZE one thing
                            You can’t clear the timer if it has triggered, as the timer has expired. The handle is no longer valid
                            • BKeyportB Offline
                              @MMRIZE @sdetweil
                              the reporter posted this to my github:
                              I am not a javascript expert, but have some experience in C++ and
                              microcontroller programming.
                              I have had some problems with other MagicMirror calendar modules not
                              updating the day properly and they also seem to implement workarounds and
                              have issues with the DOM updating.
                              I did a little looking into this and it seems there must be some generic
                              issue with the MagicMirror software allowing modules to implement timers
                              and date/time functions in realtime.
                              And Sam - I was telling you that it previously was working and works outside of the MM ecosystem - or at least sets it up to work. that’s what got me pissed off - I had done a slew of debugging and it got down to “have you turned off and on again”
                              There’s lots of issues I’ve been having - most of them being internal MM functions, that I tend to work around by native JS code and using remote access via the Web server.
                              For example: Logging. Don’t seem to work for me. Gotta log via console, so I pull up the web server and Edge’s dev tools.
                                sdetweil @BKeyport
                                @BKeyport logging
                                There are two logs
                                Node_helper goes to npm start console
                                Modulename.js goes to the browser log
                                There are a couple modules that will send the browser log records to the console
                                MMM-Logging, mmrize has an updated version, so do I.
                                I don’t know why it worked before, or why it’s not working now.
                                We added some checking for valid position names, instead of crashing
                                We added async to some mm functions, but
                                Timeout and interval are js functions.
                                Only way to debug the browser side is to use the developer window debugger (sources tab)
                                  sdetweil @BKeyport
                                  @BKeyport I’d be interested in the functions that you are having trouble with, as there are very few.
                                  • BKeyportB Offline
                                    I think I got it figured out - Based on research elsewhere - if I’m correct: start: function() is only called upon load, correct?
                                    ASSUMING that’s the case, this seems to work better:
                                        function scheduleMidnightUpdate() {
                                            const now = new Date();
                                            const nextMidnight = new Date(now);
                                            // Set the time to midnight
                                            nextMidnight.setHours(24, 0, 0, 0);
                                            // Calculate the time remaining until the next midnight
                                            const timeUntilMidnight = nextMidnight - now;
                                            // Schedule the updateDom method to be called at midnight
                                            setTimeout(() => {
                                                this.updateDom();
                                                // Reschedule the update for the next midnight
                                                scheduleMidnightUpdate.call(this);
                                            }, timeUntilMidnight);
                                        // Call the function to start the first schedule
                                    Now, This seems to work on testing - but it will fail in testing if I change the clock after starting MM.
                                    Is there anyway y’all can see to improve this, or am I good?
                                      MMRIZE @BKeyport
                                      @BKeyport
                                      Your DOM might not be rendered yet on “start” imo. I think manipulating DOM after “DOM_OBJECT_CREATED” notification would be safer.
                                        sdetweil @MMRIZE
                                        @MMRIZE
                                        Yes the documented flow is, as I recall on my phone,
                                        Init
                                        Getstyles
                                        Getscripts
                                        GetTemplates
                                        Start
                                        Notification received
                                        AllModulesStarted
                                        DOMobjectsCreated
                                        getDOM
                                        • BKeyportB Offline
                                          @sdetweil @MMRIZE so, should I move the initial call somewhere else?
                                            sdetweil @BKeyport
                                            @BKeyport after the notification
                                            From the doc
                                            DOM_OBJECTS_CREATED - All dom objects are created. The system is now ready to perform visual changes.
                                            • BKeyportB Offline
                                              @sdetweil said in Not updating at midnight...:
                                                      setTimeout(() => {
                                                          this.updateDom();
                                                          this.updateDom();
                                                      } else if (notification === 'DOM_OBJECTS_CREATED') {
                                              This is the only source I see in the docs of that - a notification. Is that correct?
                                              Thanks for the patience after the double misunderstanding.
