    Docker install on synology nas
    18 Posts 4 Posters 3.6k Views 4 Watching
    • P Offline
      pauabaer @sdetweil
      I tried it in the Synology gui. I have added puid and pgid as I did in other containers.
      But I got the same message: access denied.
      So what would be the difference when I change the entry whithin the compose?
      And how do I find this file at my synology? :)
        sdetweil @pauabaer
        @pauabaer i do not know how to do it with the gui,
        there is a place where you can paste in the compose file . i have not tried that
        i ssh’d into the nas and did the manual install steps via commandline
        • P Offline
          pauabaer @sdetweil
          I startet the container with a compose file where I added the user 1026 and group ID 100 but there is no success.
            sdetweil @pauabaer
            @pauabaer typically the group id is the same as the user id
              @pauabaer
              id -u will get this users id number
              id -g will get this users group number
              • P Offline
                pauabaer @sdetweil
                That’s what i checked before. Id -u > 1026 / id -g > 100.
                These parameters i inserted in the compose file.
                • P Offline
                  pauabaer @karsten13
                  @karsten13
                  I tried to start via command line
                  paua@NAS:~$ docker run  -d \
                  >         --user root \
                  > --name magicmirror \
                  >     --publish 8036:8080 \
                  >     --restart unless-stopped \
                  >     -e TZ=Europe/Berlin \
                  >     --volume /volume2/docker/MagicMirror/config:/opt/magic_mirror/config \
                  >     --volume /volume2/docker/MagicMirror/modules:/opt/magic_mirror/modules \
                  >     --volume /volume2/docker/MagicMirror/css:/opt/magic_mirror/css \
                  >     karsten13/magicmirror:latest
                  docker: permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post "http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/create?name=magicmirror": dial unix /var/run/docker.sock: connect: permission denied.
                  See 'docker run --help'.
                  But again I got the permission error.
                  • P Offline
                    pauabaer @pauabaer
                    I fixed it and now MM is running in docker on my synology diskstation.
                    I had to insert
                    user: root
                    in the compose file. It is working fine.
