    Calendar shows late day events on next day but at correct time
    35 Posts 4 Posters 11.4k Views 6 Watching
    • N Offline
      natmash
      I am using multiple Apple shared calendars, and all of my events that happen after a certain point at night show up on the next day. They show up with the correct time on the next day, but just on the next day.
      I have tried using multiple calendar modules but they are all the same, so I think it is something I am doing wrong either in my shared calendar itself of in the calendar module.
      I am in the central timezone, and it looks like anything after about 7:00pm will show up on the next day.
      It looks like it only occurs for recurring events.
      Recurring event
      One instance of this event for example shows up on 9/11 at 8:15pm.
      Single event
      This event shows on 9/13 at 9:00pm.
        sdetweil @natmash
        @natmash can you check the system time zone?
        i think its set to utc time
        • N Offline
          natmash @sdetweil
          timedatectl returns America/Chicago. On my pi I run via a docker container, but I have also tested locally with just npm start and the same thing happens.
            sdetweil @natmash
            @natmash the docker container is another system, it needs a timezone property, defaults to utc
            like this
            • N Offline
              natmash
              Just coming back to this after a few weeks unable to get to it.
              No luck. In addition, it still is only related to recurring events, whereas single events are set correctly. Even in a series of events the first event is fine but events after are wrong.
                sdetweil @natmash
                @natmash can you turn on debug
                add
                 ,"DEBUG"
                to the logLevel list in config.js
                redirect the output of npm start to a file
                npm start >somefile.txt
                  @natmash
                  and maybe post one event from your cal ics file which demonstrates the issue
                    MMRIZE @natmash
                    @natmash @sdetweil
                    It seems a bug on the default calendar module. One of my CX3 user also reported it so I looked inside.
                    https://github.com/MMRIZE/MMM-CalendarExt3/discussions/146#discussioncomment-9380307
                      sdetweil @MMRIZE
                      @MMRIZE i expect so, I’d like to see the event from the ics to see what we can do
                      • N Offline
                        natmash
                        BEGIN:VEVENT
                        CREATED:20240904T053053Z
                        DTEND;TZID=America/Chicago:20240910T211500
                        DTSTAMP:20240925T005517Z
                        DTSTART;TZID=America/Chicago:20240910T201500
                        LAST-MODIFIED:20240925T005515Z
                        RELATED-TO;RELTYPE=X-CALENDARSERVER-RECURRENCE-SET:2D48CA37-FCE5-4E16-871
                        9-1F47160BDBA3
                        RRULE:FREQ=WEEKLY;UNTIL=20250601T011500Z
                        SEQUENCE:3
                        SUMMARY:Wife Barre Class
                        UID:39669340-7AFD-4685-9BD6-6CE4B715486E
                        X-APPLE-CREATOR-IDENTITY:com.apple.mobilecal
                        END:VEVENT
                        S 2 Replies Last reply Reply Quote 1
                          sdetweil @natmash
                          @natmash thanks
                          • N Offline
                            natmash
                            Barre Class, with dates: ["2024-09-11T01:15:00.000Z","2024-09-18T01:15:00.000Z","2024-09-25T01:15:00.000Z","2024-10-02T01:15:00.000Z","2024-10-09T01:15:00.000Z","2024-10-16T01:15:00.000Z","2024-10-23T01:15:00.000Z","2024-10-30T01:15:00.000Z","2024-11-06T01:15:00.000Z","2024-11-13T01:15:00.000Z","2024-11-20T01:15:00.000Z","2024-11-27T01:15:00.000Z","2024-12-04T01:15:00.000Z","2024-12-11T01:15:00.000Z","2024-12-18T01:15:00.000Z","2024-12-25T01:15:00.000Z","2025-01-01T01:15:00.000Z","2025-01-08T01:15:00.000Z","2025-01-15T01:15:00.000Z","2025-01-22T01:15:00.000Z","2025-01-29T01:15:00.000Z","2025-02-05T01:15:00.000Z","2025-02-12T01:15:00.000Z","2025-02-19T01:15:00.000Z","2025-02-26T01:15:00.000Z","2025-03-05T01:15:00.000Z","2025-03-12T01:15:00.000Z","2025-03-19T01:15:00.000Z","2025-03-26T01:15:00.000Z","2025-04-02T01:15:00.000Z","2025-04-09T01:15:00.000Z","2025-04-16T01:15:00.000Z","2025-04-23T01:15:00.000Z","2025-04-30T01:15:00.000Z","2025-05-07T01:15:00.000Z","2025-05-14T01:15:00.000Z","2025-05-21T01:15:00.000Z","2025-05-28T01:15:00.000Z"]
                            [2024-09-28 11:26:06.920] [DEBUG] Rule has byweekday, checking for correction
                            [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Sep 10 2024 20:15:00 GMT-0500 (Central Daylight Time)
                            [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Sep 17 2024 20:15:00 GMT-0500 (Central Daylight Time)
                            [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Sep 24 2024 20:15:00 GMT-0500 (Central Daylight Time)
                            [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Oct 01 2024 20:15:00 GMT-0500 (Central Daylight Time)
                            [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Oct 08 2024 20:15:00 GMT-0500 (Central Daylight Time)
                            [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Oct 15 2024 20:15:00 GMT-0500 (Central Daylight Time)
                            [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Oct 22 2024 20:15:00 GMT-0500 (Central Daylight Time)
                            [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Oct 29 2024 20:15:00 GMT-0500 (Central Daylight Time)
                            [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 6) and hour=19 >= 24-6, Adding 1 day to Tue Nov 05 2024 19:15:00 GMT-0600 (Central Standard Time)
                              sdetweil @natmash
                              @natmash yes… code I put in to fix another bug, in the repeating rule parser… it used to return the day prior UTC date and right time… so I adjusted it.
                              now in this one case it returns the correct UTC date…
                              if I fix this it breaks other testcases…
                              looking for another option
                                sdetweil @natmash
                                @natmash so, I think I finally have a fix for this.
                                Would you like to try it?
                                Which MagicMirror version are you using?
                                  MarcLandis Module Developer @sdetweil
                                  @sdetweil I am going to test your fix with my calendar too, as it was the cause for the initial fix.
                                    sdetweil @MarcLandis
                                    @MarcLandis you want it on 2.28 or 2.29?
                                      @sdetweil 2.29 please
                                      (2.28 is too old :) )
                                        @MarcLandis understood, but I don’t want to force upgrade to test
                                          @MarcLandis @natmash
                                          here is a test version of the fixes for all kinds of calendar date problems.
                                          best to make a new folder and git clone there
                                          git  clone https://github.com/sdetweil/MagicMirror
                                          cd MagicMirror
                                          git checkout fixcaldates
                                          npm run install-mm
                                          copy your config.js and custom.css from the prior folder
                                          and the non-default modules you have installed…
                                          this ONLY changes the default calendar
                                          but DOES ship an updated node-ical library too
                                          if you need to fall back, just rename the folders around again so that
                                          your original is called MagicMirror
                                          all the testcases for node-ical and MagicMirror execute successfully.
                                          the ‘BIG’ change here is to get the local NON-TZ dates for the
                                          rrule.between()
                                          all the checking and conversion code is commented out or not used
                                          the node-ical fixes are for excluded dates (exdate) values being adjusted for DST/STD time… waiting to submit that PR
                                          one fix in calendar.js for checking if a past date was too far back,
                                          but it never checked to see IF the event date was in the past… (before today) so it chopped off too many
                                          and one change in calendarfetcher.js to put out a better diagnostic message of the parsed data… (exdate was excluded cause JSON stringify couldn’t convert the complex structure)
                                            @sdetweil I testet your branch and so far it looks good with my test calendar and also with my real ones.
