    • Search
    SOLVED adjusting reloadInterval
    Troubleshooting
    • R
      Richard238 last edited by
      If a realoadInterval of 60*1000 = one minute, how do I change it to reload at different intervals?
      I’ve tried various combinations of 3/10/30*1000, even change 1000 to 100.
      Save the .js and then ‘npm start’, but the refresh is still one minute.
      Is refresh controlled from elsewhere?
      Thank you.
      broberg 1 Reply Last reply Reply Quote 0
      • R
        Richard238 @Richard238 last edited by
        Resolved.
        Changed setting in config.js, module now updating at the frequency required.
        Thank you.
        • Cato
          Cato Module Developer last edited by
          Have you configured to start mirror with pm2? If so you have to restart with pm2 restart mm
          • R
            Richard238 @Cato last edited by
            @Cato No, I’m not using PM2
            • broberg
              broberg Project Sponsor @Richard238 last edited by
              @Richard238 many modules have set a minimum reloadinterval to 10seconds and that can’t be changed unless you change the if statement that controls it.
              And if you are working directly on the pi you can just reload the page by pressing ctrl+r
              The only time I have needed to restart it completly is when messing with the code of the node_helper file
              • R
                It’s in a bespoke module, created by Gordon(izanbard)
                Module.register("MMM-MyTemps", {
                    defaults: {
                        host: "192.168.1.41",
                        path: "/temp2mcf.php?format=json",
                        reloadInterval: 60 * 1000 //1 min
                Module works fine, but I’d like it to reload more frequently.
                • R
                  Resolved.
                  Thank you.
