    MMM-Fuel
    12 Posts 4 Posters 2.0k Views 4 Watching
      Ray
      Does anyone know what’s going on with MMM-Fuel
      I have been using this for years and now all of a sudden
      it’s only displaying the header names and not the service stations
      and prices
      I am in the United States so therefore I don’t need a key
      Is anyone else having this problem
        MarcLandis Module Developer @Ray
        @Ray what provider are you using?
          Ray @MarcLandis
          @MarcLandis
          https://github.com/fewieden/MMM-Fuel
            @Ray What I meant is the provider you use in the modules config.
              Ray @MarcLandis
              @MarcLandis
              okay here you go this is what I’ve been using for several years now
              			module: "MMM-Fuel",
              				provider: "autoblog",
              				zip: "94596",
              				types: ["regular", "mid-grade"],
              				sortBy: "mid-grade",
              				max: 4,
              				shortenText: 29,
              				showDistance: false,
              				fade: false,
              				rotateInterval: 600000,             // every 10 minutes
              				updateInterval: 15 * 60 * 1000      // every 15 minutes
              				// all your config options, which are different than their default values
              M S plainbrokeP 3 Replies Last reply Reply Quote 0
                @Ray looks like that https://www.autoblog.com no longer provides the data. You should open an issue at the modules github page.
                  sdetweil @Ray
                  @Ray please always put config stuff in code block
                  paste text, blank line above and below,
                  select text pasted
                  hit the button </>
                    Ray @sdetweil
                    thank you for the heads up I apologize for that
                      Ray @MarcLandis
                      @MarcLandis
                      thanks for the help I will open up an issue with them
                        sdetweil @Ray
                        @Ray no problem. as you see it helps w readability, which could get you a better answer sooner
                        • plainbrokeP Offline
                          plainbroke @Ray
                          @Ray
                          You can try changing from autoblog to gasbuddy. Works for me…
                            Ray @plainbroke
                            @plainbroke
                            sorry it took so long to reply back I’ve been kinda busy
                            and I did contact the owner and he said just that I did try it and it worked perfectly
                            • R Ray has marked this topic as solved on
