    MMM-MovieListings
    28 Posts 4 Posters 10.9k Views 4 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @BerkSmash1984
      @BerkSmash1984 Yeah, that would work.
        sdetweil @BerkSmash1984
        @BerkSmash1984 if you used my script it should upgrade mode too. it uses n, the nodejs version of nvm
          @sdetweil From the above it does seem like he used your script but it failed to update node to the required version which should be one of the following, right?
          >=20.9.0 <21 || 22
            sdetweil @mumblebaj
            @mumblebaj yes , id like to see the installers/upgrade.log
            maybe the test subversion failed
              sdetweil @mumblebaj
              @mumblebaj really >=20.9.0, not 21, or >= 22
                mumblebaj Module Developer @sdetweil
                @sdetweil From package.json
                BerkSmash1984B 1 Reply Last reply Reply Quote 1
                • BerkSmash1984B Offline
                  BerkSmash1984 @mumblebaj
                  @mumblebaj @sdetweil
                  I did the update using @sdetweil upgrade script
                    mumblebaj Module Developer @mumblebaj
                    UPDATES
                    V1.1.0
                    • Fixed issue with cast list appending cast members from different movies to the same list. Now only cast members of the displayed movie is displayed.
                    • Update and simplify the API calls to reduce the number of calls.
