MMM-MovieListings
@BerkSmash1984 Yeah, that would work.
@BerkSmash1984 if you used my script it should upgrade mode too. it uses n, the nodejs version of nvm
@sdetweil From the above it does seem like he used your script but it failed to update node to the required version which should be one of the following, right?
>=20.9.0 <21 || 22 -
@mumblebaj yes , id like to see the installers/upgrade.log
maybe the test subversion failed -
@mumblebaj really >=20.9.0, not 21, or >= 22
@sdetweil From package.json
I did the update using @sdetweil upgrade script
UPDATES
V1.1.0
- Fixed issue with cast list appending cast members from different movies to the same list. Now only cast members of the displayed movie is displayed.
- Update and simplify the API calls to reduce the number of calls.
