    Multiple "Mirrors" from a single device
    Scheduled Pinned Locked Moved Solved General Discussion
    20 Posts 3 Posters 4.5k Views 4 Watching
    • D
      DarrenO 0
      Is it possible to run multiple mirrors from a single device?
      My current MM utilises the default Calendar module to display family member calendars from Google in the top_left section and the MMM-CalendarWeek module in the bottom_bar section to display another Google calendar.
      I know I can display the MM via a web browser on any number of devices, but this is just a duplicate of what I see from the directly-connected host device.
      I want to output the family calendars on one display while the other calendar displays on another.
      This could be where one is displayed to a directly-connected output, while the other is viewed from a browser, or possibly, both are displayed via a browser if physically locating the host with either display isn’t possible.
      Is this sort of setup doable?
      I had read online that I would have to create a second config.js file, configured as required for the alternate view.
      Within that file, I would have to specify an alternate port (say 8081) and initiate a secondary instance of MM.
      However, the instructions never indicated or specified how the second config.js file would be referenced in order to display the appropriate output.
        sdetweil @DarrenO 0
        @DarrenO-0 how did you add it to pm2 . just doing mm2.sh doesn’t
        pm2 start xxxx
        xxx is the mm2.sh
        or the MagicMirror2.json
        it should run and you should see with status
        then pm2 save so that it will be saved to the bootup start list
          sdetweil @DarrenO 0
          @DarrenO-0 yes you can run multiple instances from the same folder with different configurations
          there is a section in the doc on doing this
          see
          https://docs.magicmirror.builders/configuration/introduction.html#advanced-configuration-and-frequently-asked-how-to-configure-examples
          • D
            DarrenO 0 @sdetweil
            Thanks. That has sort of help me out and pointed me in the right direction.
            Is it just as simple as copying the existing:
            • mm.sh file -->> mm2.sh
            • pm2_MagicMirror_new.json -->> pm2_MagicMirror2_new.json
            and editing the pm2_MagicMirror2_new.json file to reference:
            • the app name of MagicMirror2
            • the script of mm2.sh (is there anything to change in this?)
            • watching the config2.js file for changes
            and then executing pm2 start config2.js --name MagicMirror2
              sdetweil @DarrenO 0
              @DarrenO-0 the json file my installer script creates is just to give the app name in pm2 a meaningful mame,
              if you use
              pm2 start mmfoo.sh
              the the app name will be mmfoo
              the watch function is broken, pm2 now only supports watching a folder for changes, but file updates don’t count as a folder change
              can you change the name of the script, yes, anything you like
              once you update the json file , just
              pm2 start xxxx.json
              and it will take the info from there
              BKeyportB D 2 Replies Last reply Reply Quote 0
              • BKeyportB
                As I rewrote that section in the docs - I’ll give a (semi) live example (My second mirror is down due to lack of space, I’m working on a solution) - this is what works for me at the moment. I do realize I’m doubling up on some things.
                In my Pi’s config, I also reverted to X11 desktop rather than wayland for reasons unrelated. I have not tested this on Wayland.
                mm.sh
                cd /home/bkey1970/MagicMirror
                DISPLAY=:0 npm start
                mm2.sh
                export MM_CONFIG_FILE=config/config2.js
                export MM_PORT=8081
                the start of config.js:
                var config = {
                	address: "0.0.0.0",
                	port: 8080,
                	ipWhitelist: [],
                	language: "en",
                	timeFormat: 12,
                	units: "imperial",
                	//logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"],
                The start of config2.js:
                var config = {
                	address: "0.0.0.0",
                	port: 8081,
                	electronOptions: {
                		x: 1920
                	ipWhitelist: [],
                	language: "en",
                	timeFormat: 12,
                	units: "imperial",
                	customCss: "css/custom2.css",
                PM2 commands to tie it all together:
                pm2 start /home/<username>/<path>/mm.sh --name "MM Main"
                pm2 start /home/<username>/<path>/mm2.sh --name "MM 2nd"
                pm2 save
                • D
                  DarrenO 0 @sdetweil
                  OK, so no requirement to update the “name” and “watch” values in the .json file, but it doesn’t hurt to do so from an fyi perspective, right???
                  When I run “pm2 start config2.js”, I can then access the second instance via browser on another device with no issue, but it also takes over the display directly connected to the MM host device.
                  I can view both MM instances via a browser on different devices (great, as that was one of my original questions), but what if i want to view instance #1 via the display directly connected to the MM host device and instance #2 via a remote browser (or vice versa?
                  My .sh files to start each MM instance are as follows:
                  mm.sh
                  #!/bin/bash
                  cd ~/MagicMirror
                  mm2.sh
                  #!/bin/bash
                  cd ~/MagicMirror
                  export MM_PORT=8081
                  npm start
                  #DISPLAY=:0 npm start
                  Should I change anything, or what would I need to change, to have the desired outcome described above?
                    sdetweil @DarrenO 0
                    @DarrenO-0 npm start run the ui locally and the server for remotes
                    npm run server starts the server for remote and browsers locally
                    both cases remotes need the server config to allow outside connection
                    pm2 start xxxx
                    where xxxx is the script name ( end in . sh)
                    OR
                    the json file where it can get the info
                    the different config is set thru an environment variable
                    MM_CONFIG_FILE=
                    in linux by default env variables are NOT passed to children processes
                    so you have to use export to
                    make it passed on
                    on Windows env variables ARE passed to children processes by default
                    the port number is used on the remote system to access the appropriate instance
                    http://mm-server-address:mm-instance-port-number
                    • D
                      DarrenO 0 @sdetweil
                      so mm2.sh should/would be:
                      #!/bin/bash
                      cd ~/MagicMirror
                      export MM_PORT=8081
                      npm run server
                      while mm.sh remains untouched
                      When I have this in place:
                      • instance #1 correctly displays on the screen attached to the MM host… tick
                      • i can also view instance #1 on a browser (on port 8080)… tick
                      • can view instance #2 in a browser (on port 8081)… tick
                      However, when I run mm2.sh while I am SSH’d to the MM, I am not returned to the command line so I can save the pm2 setup.
                      I just have a prompt saying “Ready to go! Please point your browser to http://ipaddress:8081”
                      I have to Ctrl-C to cancel out, which then stops the server function and the #2 instance is no longer displayed
                        sdetweil @DarrenO 0
                        @DarrenO-0 in Windows when you want an app to run when started from the command prompt you do
                        detach command…
                        in linux you add and & as the last character
                        comand… &
                        now… STOPPING those detached/background things are tough…
                        here is one value for pm2… it EXPECTS the script to block
                        and so you can kill it thru pm2 stop xxxx
                        BUT
                        pm2’s JOB is to start and app AND KEEP IT RUNNING…
                        so you kill it (ctrl-q) or it fails, pm2 will restart it
                        SO, if you want both to run and want to do it manually, open a second ssh session
                        until you are happy and then let pm2 run them both
                        • D
                          DarrenO 0 @sdetweil
                          OK, so I launched the second instance of MM via mm2.sh with the “npm run server” command.
                          I then launched a second SSH session to the MM device and issued a “pm2 save” command.
                          Rebooted the MM device from the second SSH session but the second MM instance didn’t come up.
                          • D
                            DarrenO 0 @BKeyport
                            @BKeyport
                            isn’t this to run two MM’s on a single display and have the second MM displayed from the 1920th pixel on the x axis?
                            I’m wanting to run two MM’s, each instance on isolated displays - one on the display connected to the host in the traditional method and the other on a remote display like another computer, or TV with an in-built browser.
                            S BKeyportB 3 Replies Last reply Reply Quote 0
                              sdetweil @DarrenO 0
                              @DarrenO-0 and what does the status say?
                              pm2 status
                              pm2 logs 1 (or whatever the number is of the line for the second ) --lines=xxxx
                              where xxxx is the number of the most recent lines in the log for that app
                              I have lots of apps on my desktop pm2
                              pm2 status output
                              | id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                              │ 1  │ MagicMirror        │ fork     │ 27   │ stopped   │ 0%       │ 0b       │
                              │ 7  │ MagicMirror1       │ fork     │ 279… │ stopped   │ 0%       │ 0b       │
                              │ 0  │ Smart Mirror       │ fork     │ 31   │ stopped   │ 0%       │ 0b       │
                              │ 3  │ checkarec          │ fork     │ 0    │ online    │ 0%       │ 3.5mb    │
                              │ 6  │ smart-mirror       │ fork     │ 9    │ online    │ 0%       │ 3.5mb    │
                              │ 5  │ smart-mirror ttt   │ fork     │ 10   │ stopped   │ 0%       │ 0b       │
                              │ 4  │ start_alexa_bk     │ fork     │ 0    │ online    │ 0%       │ 3.5mb    │
                              │ 2  │ startspot          │ fork     │ 328  │ stopped   │ 0%       │ 0b       │
                              the count under the circle coloum is restarts of that app
                                sdetweil @DarrenO 0
                                @DarrenO-0 the server side still provides access regardless of where the local display output is configured
                                AND if you run server mode, then the config for the local electron isn’t used
                                  sdetweil @DarrenO 0
                                  @DarrenO-0 said in Multiple "Mirrors" from a single device:
                                  just heads up…
                                  we use the latest Javascript language options
                                  most/many/all TV’s do NOT have this browser version available and cannot be upgraded.
                                  so the MM screen will be black (browser crashed)
                                  when I got here in 2017, I could run MM on my Samsung TV browser
                                  not anymore
                                  • D
                                    DarrenO 0 @sdetweil
                                    after running the mm2.sh script (runs as “npm run server”) and then I initiate a new SSH to the MM, I still only see a single instance (the original instance from mm.sh) of MM running when I issue a pm2 status command.
                                    Although I can physically see the second MM displayed as desired in my browser, I’m not seeing the second instance via the pm2 status command.
                                    • D
                                      DarrenO 0 @sdetweil
                                      Fair enough.
                                      So i’ll have to have a physical computer like a Pi, NUC or MiniPC attached to the TV via HDMI to display the MM via that computer’s browser.
                                      Not a big deal as the TV would be used for viewing TV channels and online streaming content anyway.
                                        sdetweil @DarrenO 0
                                        pm2 start xxxx
                                        xxx is the mm2.sh
                                        • D
                                          DarrenO 0 @sdetweil
                                          yeah, I started it via the mm2.sh script that had the “npm run server” command
                                          I’ve now started the second instance as “pm2 start pm2_MagicMirror2_new.json” and “pm2 status” does show both instances running.
                                          Ran “pm2 save”, rebooted the host and both instances are showing as expected - MM#1 on the display connected to the host device, with MM#1 and MM#2 via a browser on a remote device/devices.
                                            sdetweil @DarrenO 0
                                            @DarrenO-0 awesome!!..
                                            now select which post is the one that you think ‘solved’ this
                                            hit the 3 dots (bottom right of the post) and click on Mark this post as the correct answer
                                            • D DarrenO 0 has marked this topic as solved on
                                            • BKeyportB
                                              BKeyport Module Developer @DarrenO 0
                                              @DarrenO-0 Ahh, gotcha. Yes, this is for two on the same system, which linux treats as one huge monitor.
