Multiple "Mirrors" from a single device
Scheduled Pinned Locked Moved Solved General Discussion
20 Posts 3 Posters 1.4k Views 4 Watching
    DarrenO 0
    Is it possible to run multiple mirrors from a single device?
    My current MM utilises the default Calendar module to display family member calendars from Google in the top_left section and the MMM-CalendarWeek module in the bottom_bar section to display another Google calendar.
    I know I can display the MM via a web browser on any number of devices, but this is just a duplicate of what I see from the directly-connected host device.
    I want to output the family calendars on one display while the other calendar displays on another.
    This could be where one is displayed to a directly-connected output, while the other is viewed from a browser, or possibly, both are displayed via a browser if physically locating the host with either display isn’t possible.
    Is this sort of setup doable?
    I had read online that I would have to create a second config.js file, configured as required for the alternate view.
    Within that file, I would have to specify an alternate port (say 8081) and initiate a secondary instance of MM.
    However, the instructions never indicated or specified how the second config.js file would be referenced in order to display the appropriate output.
    S 1 Reply Last reply Nov 6, 2024, 12:29 PM Reply Quote 0
      sdetweil @DarrenO 0
      @DarrenO-0 how did you add it to pm2 . just doing mm2.sh doesn’t
      pm2 start xxxx
      xxx is the mm2.sh
      or the MagicMirror2.json
      it should run and you should see with status
      then pm2 save so that it will be saved to the bootup start list
      D 1 Reply Last reply Nov 8, 2024, 12:04 AM Reply Quote 0
        sdetweil @DarrenO 0
        @DarrenO-0 yes you can run multiple instances from the same folder with different configurations
        there is a section in the doc on doing this
        see
        https://docs.magicmirror.builders/configuration/introduction.html#advanced-configuration-and-frequently-asked-how-to-configure-examples
        D 1 Reply Last reply Nov 7, 2024, 12:39 PM Reply Quote 0
          DarrenO 0 @sdetweil
          Thanks. That has sort of help me out and pointed me in the right direction.
          Is it just as simple as copying the existing:
          • mm.sh file -->> mm2.sh
          • pm2_MagicMirror_new.json -->> pm2_MagicMirror2_new.json
          and editing the pm2_MagicMirror2_new.json file to reference:
          • the app name of MagicMirror2
          • the script of mm2.sh (is there anything to change in this?)
          • watching the config2.js file for changes
          and then executing pm2 start config2.js --name MagicMirror2
          S 1 Reply Last reply Nov 7, 2024, 12:45 PM Reply Quote 0
            sdetweil @DarrenO 0
            @DarrenO-0 the json file my installer script creates is just to give the app name in pm2 a meaningful mame,
            if you use
            pm2 start mmfoo.sh
            the the app name will be mmfoo
            the watch function is broken, pm2 now only supports watching a folder for changes, but file updates don’t count as a folder change
            can you change the name of the script, yes, anything you like
            once you update the json file , just
            pm2 start xxxx.json
            and it will take the info from there
            B D 2 Replies Last reply Nov 7, 2024, 7:28 PM Reply Quote 0
              As I rewrote that section in the docs - I’ll give a (semi) live example (My second mirror is down due to lack of space, I’m working on a solution) - this is what works for me at the moment. I do realize I’m doubling up on some things.
              In my Pi’s config, I also reverted to X11 desktop rather than wayland for reasons unrelated. I have not tested this on Wayland.
              mm.sh
              cd /home/bkey1970/MagicMirror
              DISPLAY=:0 npm start
              mm2.sh
              export MM_CONFIG_FILE=config/config2.js
              export MM_PORT=8081
              the start of config.js:
              var config = {
              	address: "0.0.0.0",
              	port: 8080,
              	ipWhitelist: [],
              	language: "en",
              	timeFormat: 12,
              	units: "imperial",
              	//logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"],
              The start of config2.js:
              var config = {
              	address: "0.0.0.0",
              	port: 8081,
              	electronOptions: {
              		x: 1920
              	ipWhitelist: [],
              	language: "en",
              	timeFormat: 12,
              	units: "imperial",
              	customCss: "css/custom2.css",
              PM2 commands to tie it all together:
              pm2 start /home/<username>/<path>/mm.sh --name "MM Main"
              pm2 start /home/<username>/<path>/mm2.sh --name "MM 2nd"
              pm2 save
              D 1 Reply Last reply Nov 7, 2024, 11:11 PM Reply Quote 0
                DarrenO 0 @sdetweil
                OK, so no requirement to update the “name” and “watch” values in the .json file, but it doesn’t hurt to do so from an fyi perspective, right???
                When I run “pm2 start config2.js”, I can then access the second instance via browser on another device with no issue, but it also takes over the display directly connected to the MM host device.
                I can view both MM instances via a browser on different devices (great, as that was one of my original questions), but what if i want to view instance #1 via the display directly connected to the MM host device and instance #2 via a remote browser (or vice versa?
                My .sh files to start each MM instance are as follows:
                mm.sh
                #!/bin/bash
                mm2.sh
                #!/bin/bash
                export MM_PORT=8081
                npm start
                #DISPLAY=:0 npm start
                Should I change anything, or what would I need to change, to have the desired outcome described above?
                S 1 Reply Last reply Nov 7, 2024, 9:25 PM Reply Quote 0
                  sdetweil @DarrenO 0
                  @DarrenO-0 npm start run the ui locally and the server for remotes
                  npm run server starts the server for remote and browsers locally
                  both cases remotes need the server config to allow outside connection
                  pm2 start xxxx
                  where xxxx is the script name ( end in . sh)
                  OR
                  the json file where it can get the info
                  the different config is set thru an environment variable
                  MM_CONFIG_FILE=
                  in linux by default env variables are NOT passed to children processes
                  so you have to use export to
                  make it passed on
                  on Windows env variables ARE passed to children processes by default
                  the port number is used on the remote system to access the appropriate instance
                  http://mm-server-address:mm-instance-port-number
                  D 1 Reply Last reply Nov 7, 2024, 10:37 PM Reply Quote 0
                    DarrenO 0 @sdetweil
                    so mm2.sh should/would be:
                    #!/bin/bash
                    export MM_PORT=8081
                    npm run server
                    while mm.sh remains untouched
                    When I have this in place:
                    • instance #1 correctly displays on the screen attached to the MM host… tick
                    • i can also view instance #1 on a browser (on port 8080)… tick
                    • can view instance #2 in a browser (on port 8081)… tick
                    However, when I run mm2.sh while I am SSH’d to the MM, I am not returned to the command line so I can save the pm2 setup.
                    I just have a prompt saying “Ready to go! Please point your browser to http://ipaddress:8081”
                    I have to Ctrl-C to cancel out, which then stops the server function and the #2 instance is no longer displayed
                    S 1 Reply Last reply Nov 7, 2024, 10:46 PM Reply Quote 0
                      sdetweil @DarrenO 0
                      @DarrenO-0 in Windows when you want an app to run when started from the command prompt you do
                      detach command…
                      in linux you add and & as the last character
                      comand… &
                      now… STOPPING those detached/background things are tough…
                      here is one value for pm2… it EXPECTS the script to block
                      and so you can kill it thru pm2 stop xxxx
                      BUT
                      pm2’s JOB is to start and app AND KEEP IT RUNNING…
                      so you kill it (ctrl-q) or it fails, pm2 will restart it
                      SO, if you want both to run and want to do it manually, open a second ssh session
                      until you are happy and then let pm2 run them both
                      D 1 Reply Last reply Nov 7, 2024, 11:06 PM Reply Quote 0
                        DarrenO 0 @sdetweil
                        OK, so I launched the second instance of MM via mm2.sh with the “npm run server” command.
                        I then launched a second SSH session to the MM device and issued a “pm2 save” command.
                        Rebooted the MM device from the second SSH session but the second MM instance didn’t come up.
                        S 1 Reply Last reply Nov 7, 2024, 11:25 PM Reply Quote 0
