    Contributing to a GitHub repository - a bit stuck
    9 Posts 3 Posters 1.2k Views 3 Watching
    • evroomE Offline
      evroom
      Trying to contribute to MMM-Hoymiles-Wifi, using GitHub.
      Sam gave me directions (thanks!), but of course this Noob cannot get it done.
      What I did so far:
      % git clone https://github.com/schris88/MMM-Hoymiles-Wifi
      % cd MMM-Hoymiles-Wifi
      % git branch
      * master
      % git checkout -b evroom
      Switched to a new branch 'evroom'
      % git branch
      * evroom
        master
      Updated README.md file.
      % git add README.md
      % git commit
      On branch evroom
      nothing to commit, working tree clean
      % git push
      fatal: The current branch evroom has no upstream branch.
      To push the current branch and set the remote as upstream, use
          git push --set-upstream origin evroom
      To have this happen automatically for branches without a tracking
      upstream, see 'push.autoSetupRemote' in 'git help config'.
      % git push --set-upstream origin evroom
      remote: Permission to schris88/MMM-Hoymiles-Wifi.git denied to evroom.
      fatal: unable to access 'https://github.com/schris88/MMM-Hoymiles-Wifi/': The requested URL returned error: 403
      Using an old Mac mini with macOS Sequoia Version 15.1.
      Develop with Visual Studio Code (that has Source Control too).
      Regards,
      E.J.
      MagicMirror version: 2.37.0
        sdetweil @evroom
        @evroom said in Contributing to a GitHub repository - a bit stuck:
        git add README.md
        % git commit
        On branch evroom
        can you do
        git status
        it should show one file ‘staged’ to commit after your git add
        git commit should have a message to indicate WHAT/WHY this commit , so later someone looking for/thru commits might understand the intended changes
        (sorry I didn’t add that on the prior instructions)
         git commit -m "text of the message"
        % git push
        yes, the branch name is HERE but not THERE… so it wants explicit info how to link the two
        fatal: unable to access ‘https://github.com/schris88/MMM-Hoymiles-Wifi/’: The requested URL returned error: 403
        yes, you are trying to push to HIS repo (and you don’t have write permission)
        this is why you use a fork so you can update as much as you want, cause YOU own it
        so you didn’t make a fork on github , and then clone THAT to your system
        easiest way to recover,
        • rename existing module folder name, with .orig
        • make fork on github (top right of his repo, push fork button)
        • clone yours in the MagicMirror/modules folder, go the folder, npm install if needed
        • git clone https://github.com/evroom/MMM-Hoymiles-Wifi
        • make a new branch (same name is ok)
        • copy files from the .orig to yours
        • then add/commit/push (to your fork) // same not found on github issue
        • then create a pull request to his repo, to PULL your changes from your fork into his repo
          (without having to give you write permission)
        once you are satisfied with the new repo (of fork) and copied files and retested
        then you can delete the clone of his repo (.orig)
        evroomE 1 Reply Last reply Reply Quote 0
        • evroomE Offline
          evroom @sdetweil
          Sam,
          I think I ‘pulled’ it off.
          Thanks a lot for that.
          Now I am here:
          On https://github.com/schris88/MMM-Hoymiles-Wifi I now see:
          Pull requests: 1
          Click on ‘Pull requests’
          1 Open
          Major edit of README file.
          #5 opened 2 minutes ago by evroom
          Now it is up to Christian to approve this request, right ?
          What does he need to do ?
          And if he will give me write access, I can do this myself, right ?
          Of course I now need to make my changes to my repository, but would be nice how one completes this procedure.
            sdetweil @evroom
            @evroom yes, as it sits this is up to him to MERGE your changes into his
            (this keeps people from stomping on others projects without warning)
            yes, if he makes you a collaborator on his project you can push directly,
            please try to use a separate branch still and merge when tested
            to make more changes, do the
            edit files on your system
            test
            add
            commit
            push
            now your repo is updated AND the PR is also updated (if he hasn’t merged yet)
            if he HAS merged, then you have sync your fork with his, (github button)
            git pull your fork to pc/pi, (already cloned, so just get updates)
            you can delete the old new branch
            git branch -D name
            git checkout -b new_branch_name
            use something different in this case, your REMOTE still have this old/prior branch
            (which you can delete on github)
            • evroomE Offline
              evroom @sdetweil
              Great!
              Then a final question:
              In short:
              I program using in VS Code and here is Source Control active.
              Can I use the GitHub CLI and the Visual Studio Code like together, or will they bite each other ?
              A bit longer, with an example:
              I have edited HoymilesWifi.sh in VS Code.
              On my machine, I see:
              % git status
              On branch evroom
              Your branch is up to date with 'origin/evroom'.
              Changes not staged for commit:
                (use "git add <file>..." to update what will be committed)
                (use "git restore <file>..." to discard changes in working directory)
              	modified:   HoymilesWifi.sh
              no changes added to commit (use "git add" and/or "git commit -a")
              On VS Code I see:
              V Commit
              Changes
              $ HoymilesWifi.sh
              Can I Commit it from within VS Code, or is it safer to use the GitHub CLI as I have done for the README.md file previously ?
              S mumblebajM 2 Replies Last reply Reply Quote 0
                sdetweil @evroom
                @evroom you can use VSCode to do the commit and push…
                I have not moved myself to that part of VSCode… (or let any IDE handle my commits etc)
                • mumblebajM Offline
                  mumblebaj Module Developer @evroom
                  @evroom Just launch a terminal in VsCode
                  Make sure it is set to bash.
                  Then you can run the same commands git add and git commit -m "your commit text" and git push from the terminal.
                  S evroomE 2 Replies Last reply Reply Quote 1
                    sdetweil @mumblebaj
                    @mumblebaj yes, was trying not to add too much extra as there is already a terminal window open for running MM with the modified module
                    • evroomE Offline
                      evroom @mumblebaj
                      @mumblebaj said in Contributing to a GitHub repository - a bit stuck:
                      It is set to zsh.
                      No issue to change it to bash, but is there a reasoning behind it ?
                      Stupidly enough I had this Terminal open the whole time.
                      I just did ‘Commit’ from within VS Code and then did ‘Sync Changes’.
                      Result:
                      % git status
                      On branch evroom
                      So that works just fine.
                      I also made a change using the Terminal and then did the add and commit from the Terminal.
                      In the Source Control pane you can see what you do on the command line in real time.
                      • evroomE evroom has marked this topic as solved on
