    I cant get my Calender or my MMMBitcoin to work, any help please?
    19 Posts 3 Posters 3.0k Views 3 Watching
    • C Offline
      clarkcrew32
      I havent been able to get anything on my calender to show, i think its cuz its not a .ical? Im trying to get the color full weeks view but got nothing but what defualt top left looks like when installed.
      I tried to install MMMBitcoin as well but nothing. Do i need to do more than just type in the nano.config.js?
        sdetweil @clarkcrew32
        @clarkcrew32 the calendar module ONLY processes ics files…
        there is no embedded view support.
        you can use one of the modules that does iframe and view the calendar that way
        or use the default with ICS and use something like MMM-CalendarExt3 or MMM-MiniMonth to see a wall calendar view
        on bitcoin
        can you show the message output from npm start
        if you are using pm2 to autolaunch MM, then
        pm2 logs --lines=xxxx
        where xxx is some number of the most recent lines, default 15 (may need 100 or more to view that far back_
        • C Offline
          clarkcrew32 @sdetweil
          @sdetweil how do i clear my config.js and start from default?
            @clarkcrew32
            cd ~/MagicMirror/config
            cp config.js.sample config.js
            that copies the sample we provide
            C 2 Replies Last reply Reply Quote 0
            • C Offline
              @sdetweil awesome thakn you, anyway for me to check for errors before i leave nano config.js screen?
              • C Offline
                @sdetweil you are like gold lol
                still cant get this to work tho as i found a way to do .ics file calender
                  @clarkcrew32 that fetch us on every 7 days
                  during dev i would change it to a few minutes 5*60*1000
                  another thing to test
                  from a terminal window try to download the ics
                  curl -sL  the_cal_url >somefile.txt
                  then examine the contents of somefile.txt
                  for BEGIN:VEVENT…
                    @clarkcrew32 check for errors
                    not in nano
                    but you can run the checker
                    npm run config:check
                    we do that on every startup now and fail if there is some problem.
                      raymondjspigot @sdetweil
                      @clarkcrew32 hiya I’m not familiar with the MMM-Bitcoin module, but just taking a look at the github page for it at https://github.com/valmassoi/MMM-bitcoin it doesn’t look like the install instructions are complete (it only suggests adding the module config to your config.js)
                      AFAIK to install a module to your mirror, you’re going to need to clone the repository to your modules directory, as well as add its config.
                      (apologies, you might know to do this all already, but just to make sure …)
                      try going
                      cd ~/MagicMirror/modules
                      git clone https://github.com/valmassoi/MMM-bitcoin
                      and the module should be cloned to your modules directory
                      then add the config entry into your config.js file, save the changes and try running your MagicMirror again.
                      (I don’t see any obvious typos for the MMM-Bitcoin entry in your config.js screenshot at the top, it looks like you edited it with nano just fine the first time).
                        @clarkcrew32 the bitcoin module has a problem.
                        it uses s library we stopped shipping 3 years ago.
                        but the author didn’t document its use.
                        so, in the module folder do
                        npm install request
                        • C Offline
                          im geting an error at the very last line here
                            @clarkcrew32 that last },
                            should not have a comma
                            the collapsed structure looks like this (for example, ignore individual values)
                              var config = {
                                address: "0.0.0.0",
                                 port: 8090,
                                basePath: "/",
                                language: "en",
                                serverOnly: "local",
                                locale: "en-US",
                                logLevel: [
                                  "INFO",
                                  "LOG",
                                  "WARN",
                                  "ERROR"
                                timeFormat: 24,
                                units: "metric",
                                electronOptions: {
                                  x: "2560",
                                  y: "0"
                                useHttps: false,
                                ipWhitelist: [],
                                ]  // <--- end of modules
                              }  // <--- end of confg:
                            ;  //<<------- note this is not a comma
                            • C Offline
                              @sdetweil i cant figure this out, what should that section be
                                @clarkcrew32 that should work,
                                if not show the error
                                • C Offline
                                  ok i figured that out so i have a nice start here but i noticed allthese errors wheni go to run it, any idea what the errors are?
                                    @clarkcrew32 no idea, another weird electron useless warning
                                    • C Offline
                                      Well im very appreciative of your help, i got everything kinda running. I think my screen is too small as some things are blended in. My next goal here is to get some color and to add some sports schedules. Any idea for those? I either have to add multiple calenders or put it into one calender but google isnt working like that for some reason.
                                        @clarkcrew32 the MM calendar cal can process multiple urls at once and merge them
                                        calendars[
                                        {url: cal1},
                                        {url: cal2},
                                        or you can run multiple instances of the calendar module and put them where ever
                                        if you use the color enabling options you can have colored text and symbols
                                        we only process ICS files… not embedding the google wall cal view
                                        sports, see the 3rd party module list in the top banner here
                                          @clarkcrew32 can this be marked resolved?
