    Include from /modules/node_modules/
    7 Posts 2 Posters 3.3k Views 2 Watching
      mortenbirkelund
      I have a js script that I would like to include into my module. I have installed it into the modules/node_modules/ folder by running “npm install swiper”.
      How do i include this script into my module, so I can start using it?
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @mortenbirkelund
        @mortenbirkelund you should install that in your module directory
        cd ~/MagicMirror/modules/MYMODULE then npm install swiper, but I suggest to do npm init first and then ````npm install --save swiper``` if you intend to publish your module
          mortenbirkelund
          I am pretty sure that I did install it in my modules directory but I will try your suggestion. Thanks for a quick reply. Awesome forum 👍
            mortenbirkelund @strawberry 3.141
            @strawberry-3.141 Perfect. I now have the module in a node_module folder located inside the module folder.
            But how do i include this module into my code?
            	getScripts: function() {
            		return [
            			"moment.js","package.js"
            this is not wokring as i get an 404 error
              @mortenbirkelund you have to give the path starting from your module directory something like this "node_modules/swiper/.../.../package.js"
                @strawberry-3.141 Thanks. I thought that MM would automatically look in the node_module folder. It is working now.
                  @mortenbirkelund that happens only in the node_helper
