    v2.30.0
    Scheduled Pinned Locked Moved MagicMirror
    1 Posts 1 Posters 2.5k Views 1 Watching
      sdetweil
      [2.30.0] - 2025-01-01
      Thanks to: @xsorifc28, @HeikoGr, @bugsounet, @khassel, @KristjanESPERANTO, @rejas, @sdetweil.
      ⚠️ This release needs nodejs version v20 or v22 or higher, minimum version is v20.18.1
      Added
      • [core] Add wayland and windows start options to package.json (#3594)
      • [docs] Add step for npm publishing in release process (#3595)
      • [core] Add GitHub workflow to run spellcheck a few days before each release (#3623)
      • [core] Add test flag to index.html to pass to module js for test mode detection (needed by #3630)
      • [core] Add export on animation names (#3644)
      • [compliments] Add support for refreshing remote compliments file, and test cases (#3630)
      • [linter] Re-add eslint-plugin-importnow that it supports ESLint v9 (#3586)
      • [linter] Re-activate eslint-plugin-package-json to lint package.json (#3643)
      • [linter] Add linting for markdown files (#3646)
      • [linter] Add some handy ESLint rules.
      • [calendar] Add ability to display end date for full date events, where end is not same day (showEnd=true) (#3650)
      • [core] Add text to the config.js.sample file about the locale variable (#3654, #3655)
      • [core] Add fetch timeout for all node_helpers (thru undici, forces node 20.18.1 minimum) to help on slower systems. (#3660) (3661)
      Changed
      • [core] Run code style checks in workflow only once (#3648)
      • [core] Fix animations export #3644 only on server side (#3649)
      • [core] Use project URL in fallback config (#3656)
      • [core] Fix Access Denied crash writing js/positions.js (on synology nas) #3651. new message, MM starts, but no modules showing (#3652)
      • [linter] Switch to ‘npx’ for lint-staged in pre-commit hook (#3658)
      Removed
      • [tests] Remove node-pty and drivelist from rebuilded test (#3575)
      • [deps] Remove @eslint/js dependency. Already installed with eslint in deep (#3636)
      Updated
      • [repo] Reactivate stale.yaml as GitHub action to mark issues as stale after 60 days and close them 7 days later (if no activity) (#3577, #3580, #3581)
      • [core] Update electron dependency to v32 (test electron rebuild) and all other dependencies too (#3657)
      • [tests] All test configs have been updated to allow full external access, allowing for easier debugging (especially when running as a container)
      • [core] Run and test with node 23 (#3588)
      • [workflow] delete exception allow-ghsas: GHSA-8hc4-vh64-cxmj in dep-review.yaml (#3659)
      Fixed
      • [updatenotification] Fix pm2 using detection when pm2 script is inside or outside MagicMirror root folder (#3576) (#3605) (#3626) (#3628)
      • [core] Fix loading node_helper of modules: avoid black screen, display errors and continue loading with next module (#3578)
      • [weather] Change default value for weatherEndpoint of provider openweathermap to “/onecall” (#3574)
      • [tests] Fix electron tests with mock dates, the mock on server side was missing (#3597)
      • [tests] Fix testcases with hard coded Date.now (#3597)
      • [core] Fix missing basePath where location.host is used (#3613)
      • [compliments] croner library changed filenames used in latest version (#3624)
      • [linter] Fix ESLint ignore pattern which caused that default modules not to be linted (#3632)
      • [core] Fix module path in case of sub/sub folder is used and use path.resolve for resolve moduleFolder and defaultModuleFolder in app.js (#3653)
      • [calendar] Update to resolve issues #3098 #3144 #3351 #3422 #3443 #3467 #3537 related to timezone changes
      • [calendar] Fix #3267 (styles array), also fixes event with both exdate AND recurrence(and testcase)
      • [calendar] Fix showEndsOnlyWithDuration not working, #3598, applies ONLY to full day events
      • [calendar] Fix showEnd for Full Day events (#3602)
      • [tests] Suppress “module is not defined” in e2e tests (#3647)
      • [calendar] Fix #3267 (styles array, really this time!)
      • [core] Fix #3662 js/positions.js created incorrectly
      https://github.com/MagicMirrorOrg/MagicMirror/releases/tag/v2.30.0
      1 Reply Last reply Reply Quote 4
      • S sdetweil locked this topic on
      • S sdetweil pinned this topic on
      • System unpinned this topic on
