    MMM-PublicTransportHafas: Service Temporarily Unavailable
    29 Posts 8 Posters 9.5k Views 9 Watching
    • V Offline
      Volkae @KristjanESPERANTO
      @KristjanESPERANTO
      I deleted the modul folder and made a new install. Now it works.
      Thanks a lot!!
      • O Offline
        othomys
        @KristjanESPERANTO
        Thank you for your support. I hope to find some time this weekend to implement your suggestion.
        O 1 Reply Last reply Reply Quote 1
        • O Offline
          othomys @othomys
          @KristjanESPERANTO , it works. Thanks a lot. :-)
            rotorax
            Hi, thanks for your update.
            I installed your git version and I had to install undici additionally. Is that correct?
            The MM works but ended starting up again and agin:
            0|mm | <— Last few GCs —>
            0|mm | [17870:0x2a530000] 119266 ms: Mark-Compact (reduce) 126.9 (128.6) -> 126.4 (128.1) MB, pooled: 0 MB, 791.61 / 0.00 ms (+ 0.9 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 816 ms) (average mu = 0.190, current[17870:0x2a530000] 120521 ms: Mark-Compact 126.9 (128.1) -> 126.5 (128.6) MB, pooled: 0 MB, 1201.60 / 0.00 ms (average mu = 0.113, current mu = 0.043) allocation failure; scavenge might not succeed
            0|mm | <— JS stacktrace —>
            0|mm | FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
            0|mm | ----- Native stack trace -----
            0|mm | /home/mirror/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
            Im using a raspberry pi zero with 512 MB RAM which worked fine in the past.
            Also some system information:
            0|mm | [2025-02-03 08:57:53.254] [INFO] System information:
            0|mm | ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model A Plus Rev 1.0; virtual: false
            0|mm | ### OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v7+
            0|mm | ### VERSIONS: electron: 32.2.7; used node: 22.13.1; installed node: 22.13.1; npm: 10.9.2; pm2: 5.4.3
            0|mm | ### OTHER: timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
            Anyone have the same problem?
              sdetweil @rotorax
              @rotorax how big is the swap space?
              free -m
              Will list that
                rotorax @sdetweil
                while running and short time before crashing:
                user:~ $ free -m
                total used free shared buff/cache available
                Mem: 426 217 99 19 109 132
                Swap: 871 250 621
                  sdetweil @rotorax
                  @rotorax OK try this
                    export NODE_OPTIONS=--max-old-space-size=4096
                  before the npm start
                  if using pm2 then this goes in the script it launches,
                  using my setup
                  MagicMirror/installers/mm.sh
                  4096 may need to be adjusted
                    rotorax @sdetweil
                    @sdetweil thanks for the idea. I already had this code seen. But never implemented in my pm2 startup file.
                    I tried up to 512 (limit of the raspberry I have).
                    Thats the log I got:
                    0|mm | [22565:0x47124000] 127560 ms: Mark-Compact (reduce) 127.2 (128.1) -> 126.7 (128.3) MB, pooled: 0 MB, 731.03 / 0.01 ms (+ 36.3 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 896 ms) (average mu = 0.169, curren[22565:0x47124000] 128545 ms: Mark-Compact (reduce) 127.2 (128.3) -> 126.4 (127.8) MB, pooled: 0 MB, 832.78 / 0.00 ms (+ 1.0 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 860 ms) (average mu = 0.162, current
                    I rolled back to the old config before the change of the MMM-PublicTransprtHafas and it run hours (unfortunately I don’t get any live data anymore with the old version)…
                    More ideas? ;) Grateful for every hint :)
                      sdetweil @rotorax
                      @rotorax i am certain you have to have at LEAST 4096, not smaller, maybe 8192
                      1 Reply Last reply Reply Quote -1
