    Mirror Redesign and update
    8 Posts 3 Posters 5.8k Views 4 Watching
    • W Offline
      wswenson
      Spent a bunch of time updating and cleaning up the MagicMirror (really Kitchen Dashboard) and creating some modules. More screen captures of the various pages below. I need to work on the frame as I just made it (not a carpenter so happy with it so far).
      Hardware:
      • Beelink Mini PC, Mini S12 Pro Intel 12th N100
      • Portable Touchscreen Monitor 18.5 Inch, HDR, 350cd/m², 1920x1080 Touch Display with HDMI USB C, 99% sRGB, Built-in Speakers, Kickstand & VESA,Travel Second Monitor for Laptop PC Phone (Amazon)
      OS:
      • Linux Mint 22
      Modules:
      calendar
      clock
      newsfeed
      weather
      MMM-AVStock
      MMM-CalendarExt3
      MMM-EarthquakeMonitor
      MMM-EyeCandy
      MMM-Flights
      MMM-FoxNews
      MMM-Fuel
      MMM-Jast
      MMM-JsonTable
      MMM-MktIndex
      MMM-Multimonth
      MMM-MyScoreboard
      MMM-page-indicator
      MMM-pages
      MMM-TigoEnergySolar
      MMM-Tools
      MMM-TouchButton
      MMM-Wallpaper
      MMM-WeatherGraph
      Configuration File: (Using a template/env file)
      /* Config.js.template
       *   Date     Version       Initials       Comments
       *  09JAN25    0.9            WKS        Updated file to a template format and config.env file created
       *  09JAN25    0.9a           WKS        Tested with Millbury location - passes check
       *  09JAN25    1.0            WKS        Tested with Davenport location - passes check
       * see https://docs.magicmirror.builders/configuration/introduction.html
       * and https://docs.magicmirror.builders/modules/configuration.html
       * You can use environment variables using a `config.js.template` file instead of `config.js`
       * which will be converted to `config.js` while starting. For more information
       * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
      let config = {
          address: "${CONFIG_ADDRESS}",   // Address to listen on, can be:
          port: ${CONFIG_PORT},
          basePath: "/",  // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
          ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/120"],
          useHttps: ${USEHTTPS},  // Support HTTPS or not, default "false" will use HTTP
          httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
          httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
          language: "en",
          locale: "en-US",
          timeFormat: 12,
          units: "${STANDARD_UNITS}",
          // Setup the pages and sequences for display
          // Location: https://github.com/edward-shen/MMM-pages
              module: "MMM-pages",
                      ['calendar', "clock", "currentweather", "MMM-EyeCandy", 'MMM-Jast'],        // Page 1: Dashboard display
                      ["MMM-CalendarExt3", 'MMM-Multimonth'],                                     // Page 2: Calendar displays
                      ["currentweather", "weather", "MMM-EyeCandy", "MMM-WeatherGraph"],          // Page 3: Weather page
                      ["newsfeed", 'MMM-MyScoreboard', "MMM-MktIndex", 'MMM-FoxNews', 'MMM-AVStock', 'MMM-EarthquakeMonitor'],            // Page 4: News and Information
                      ["MMM-Tools", "MMM-TigoEnergySolar", 'MMM-Fuel', 'MMM-JsonTable'],          // Page 5: Tools and other data
                      ["MMM-Flights"]                                                             // Page 6: Flight data
                  fixed: ["MMM-TouchButton", "MMM-Wallpaper", "MMM-page-indicator"],              // Fixed modules on all pages
                  animationTime: 1000,                                                            // Transition time in milliseconds
                  rotationHomePage: 20000,
                  rotationDelay: 10000,
                  homePage: 0,
          // Base home page modules on page 1
          // Display clock module
          // Pages: 1
          // Location: Magic Mirror module
              module: "clock",
                  clockBold: true,
                  timeZone: "${TIMEZONE}",
                  showSunTimes: true,
                  showMoonTimes: true,
                  lat: ${LATTITUDE},
                  lon: ${LONGITUDE},
                  displayType: "digital"
          // Stock listings
          // Pages: 1
          // Location: https://github.com/jalibu/MMM-Jast
              module: 'MMM-Jast',
              position: 'upper_third',
                  currencyStyle: "symbol", // One of ["code", "symbol", "name"]
                  fadeSpeedInSeconds: 3.5,
                  lastUpdateFormat: "HH:mm",
                  maxChangeAge: 1 * 24 * 60 * 60 * 1000,
                  maxWidth: "100%",
                  numberDecimalsPercentages: 1,
                  numberDecimalsValues: 2,
                  displayMode: "static", // One of ["none", "vertical", "horizontal", "table"]
                  showColors: true,
                  showCurrency: true,
                  showChangePercent: true,
                  showChangeValue: true,
                  showChangeValueCurrency: false,
                  showHiddenStocks: false,
                  showLastUpdate: false,
                  showPortfolioValue: false,
                  showPortfolioGrowthPercent: false,
                  showPortfolioGrowth: false,
                  showPortfolioPerformanceValue: false,
                  showPortfolioPerformancePercent: false,
                  showStockPerformanceValue: false,
                  showStockPerformanceValueSum: false,
                  showStockPerformancePercent: false,
                  stocksPerPage: 3, // Only relevant for display mode "table"
                  updateIntervalInSeconds: 300,
                  useGrouping: false,
                  virtualHorizontalMultiplier: 2,
                  stocks: [
                      { name: 'APPLE', symbol: 'AAPL'},
                      { name: 'Dell', symbol: 'DELL'},
                      { name: 'Google', symbol: 'GOOGL'},
          // News modules on page 3
          // MMM-MyScoreBoard to display sports scores for major leagues
          // Pages: 4 - News
          // Location: https://github.com/jclarke0000/MMM-MyScoreboard
              module: "MMM-MyScoreboard",
              position: "bottom_right",
              classes: "default everyone",
              header: "My Scoreboard",
                  showLeagueSeparators: true,
                  colored: true,
                  viewStyle: "mediumLogos",
                  sports: [
                      league: "NHL",
                      teams: ["BOS"],
                      teams: ["Atlantic"],
                      league: "NBA",
                      teams: ["BOS"],
                      groups: ["East"],
                          league: "MLB",
                          teams: ["BOS"]
                          league: "NFL",
                          teams: ["NE"]
          // MMM-EarthquakeMonitor
          // Pages: 4 - News
          // Location: https://github.com/rcollie/MMM-EarthquakeMonitor
              module: "MMM-EarthquakeMonitor",
              position: "bottom_left",
                  updateInterval: 600000,
                  maxNumberOfQuakes: 5,
                  apiUrl: "https://earthquake.usgs.gov/earthquakes/feed/v1.0/summary/4.5_day.geojson"
          // My FoxNews module to display the FoxNews headlines with URL
          // Pages: 4
          // Location: TBD - Still in development
              module: 'MMM-FoxNews',
              header: 'FoxNews Headlines',
                      updateInterval: 600000,     // Update every 10 minutes
                      maxItems: 3,                // Show top 3 stories
                      debugFlag: false,           // Development flag
          // Stock listings
          // Pages: 4
          // Location: https://github.com/lavolp3/MMM-AVStock
              module: 'MMM-AVStock',
              header: "Market",
                  symbols : ['AAPL', 'DELL', 'GOOGL'],
                  alias: ['Apple', 'Dell', 'Google'],
          // Display market indexes on the news page
          // Pages: 4
          // Location: https://github.com/thess/MMM-MktIndex
              module: "MMM-MktIndex",
                  config:{
                  timeFormat: "YYYY-MM-DD HH:mm:ss",
                  updateInterval: 180,
          // Display newsfeed - default module
          // Pages: 4
          // Location: MagicMirror
              module: "newsfeed",
              position: "bottom_bar",
                  feeds: [
                      title: "New York Times",
                      url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                  showSourceTitle: true,
                  showPublishDate: true
              // Flights page 6
          // Show local flights on the map
          // Pages: 6
          // Location: https://gitlab.com/khassel/MMM-Flights
              module: 'MMM-Flights',
              provider: "${FLIGHT_PROVIDER}",
                  laMin: ${FLIGHT_LAMIN},
                  laMax: ${FLIGHT_LAMAX},
                  loMax: ${FLIGHT_LOMIN},
                  loMin: ${FLIGHT_LOMAX},
                  showGrounded: false,
                  showMap: 'ifTraffic',
                  mapHeight: "400px",
                  mapFixedArea: false,
                  mapFont: '900 12px "Font Awesome 6 Free"',
                  mapGetPlaneText(flight) {
                      let txt = flight.flight;
                      if (!txt) txt = flight.radar;
                      txt = txt + "\n" + flight.altitude;
                      if (flight.rateOfClimb < 0) {
                          txt = txt + " \uf5af";
                      } else if (flight.rateOfClimb > 0) {
                          txt = txt + " \uf5b0";
                      return txt;
          // Tools & Settings page 5
          // Tools display for settings
          // Pages: 5
          // Location: https://github.com/eouia/MMM-Tools
              module: 'MMM-Tools',
              position: 'top_right',
              header: "System Statistics",
                  refresh: 500 * 5,
                  containerSize: null,
                  itemSize: null
          // My module created for FL Solar - Tigo Energy API
          // Pages: 5
          // Location: TBD in development
              module: "MMM-TigoEnergySolar",
              position: "bottom_left", // The position where you want to display the module
              header: "Tigo Energy Solar Dashboard",
                  apiUrl: "${TIGOENERGY_API}",
                  username: "${TIGOENERGY_USERNAME}",
                  password: "${TIGOENERGY_PASSWORD}",
                  systemId: "${TIGOENERGY_SYSTEMID}",
                  debugFlag: false,
          // Fuel prices module
          // Pages: 5
          // Location: https://github.com/fewieden/MMM-Fuel
              module: "MMM-Fuel",
                  provider: "${MMM_FUEL_PROVIDER}",
                  zip: "${ZIP_CODE}",
                  types: ["regular", "midgrade", "premium"],
                  open: true,
                  showDistance: false,
                  showBrand: true,
          // JSON Table - used to display SmartOil output
          // Pages: 5
          // Location: https://github.com/timdows/MMM-JsonTable
              module: 'MMM-JsonTable',
                  position: 'top_left',
                  header: '${LOCATION_NAME} Smart Oil Sensor',
                      url: '${SMARTOIL_URL}',
                      arrayName: '${SMARTOIL_ARRAYNAME}',
          // Background wallpaper from bing
          // Pages: All
          // Location: https://github.com/kolbyjack/MMM-Wallpaper
              module: "MMM-Wallpaper",
              position: "fullscreen_below",
                  source: "bing",
                  slideInterval: 60 * 1000, // Change slides every minute
                  crossfade: true,
                  fadeEdges: true,
                  filter: "brightness(0.2)",
                  maximumEntries: 25,
                  caption: true,
          // Weather Graph
          // Pages: 3
          // Location: https://github.com/FlatPepsi17/MMM-WeatherGraph
              module: 'MMM-WeatherGraph',
              header: '${LOCATION_FULL_NAME}',
              position: 'top_right',  // This can be any of the regions.
                  apiKey: "${OPENWEATHER_APIKEY}",
                  showForecast: true,            // 7 day forecast list
                  showForecastPrecip: true,      // show precip totals in 7 day list
                  showGraph: true,               // enable all graphing of weather
                  precipitationGraphWidth: 400,  // width in pixels. Default=400
                  precipitationGraphHeight: 150, // height in pixels. 0=auto-scales
                  graphHourRange: 48,            // how many hours in the graph? Max 48
                  showWind: true,                // current wind speed at top
                  showGraphPrecip: true,         // on graph, show rain and snowfall
                  showGraphTemp: true,           // on graph, show temp
                  graphTempColor: 'white',       // on graph, color of temp line
                  showGraphWind: true,           // on graph, show wind
                  graphWindColor: 'grey',        // on graph, color of temp line
                  showGraphHumid: true,          // on graph, show humidity
                  humidWindColor: '#88CC88',     // on graph, color of humid line
                  showGraphCloud: true,          // on graph, show cloud cover %
                  graphCloudColor: '#dedb49',    // on graph, color of cloud line
                  showSunrise: true,             // next sunrise or sunset at top
                  showSummary: true,             // text of next hour's conditions
                  showHotColdLines: true,        // blue line at freezing, red line at 80 F
                  showGraphLegend: true,         // legend on bottom right of graph
                  language: 'en',
                  units: '${STANDARD_UNITS}',             // or 'metric'
                  time24hr: false,               // false for 12hr times, true for 24hr times
                  updateInterval: 1900000,        // 15 minutes ( 15 * 60 * 1000 )
                  animationSpeed: 2000,          // 2 seconds (2*1000)
                  initialLoadDelay: 0,           // 0 seconds (0*1000)
                  retryDelay: 2500,              // 2.5 seconds (2*1000)
                  latitude: ${LATTITUDE},
                  longitude: ${LONGITUDE}
          // EyeCandy used to display the local radar images
          // Pages: 3
          // Location: https://github.com/mykle1/MMM-EyeCandy
              module: "MMM-EyeCandy",
                  header: "${LOCATION_NAME} Radar",
                  position: "bottom_center",
                      maxWidth: "100%",       // Sizes the images. Retains aspect ratio.
                      style: '1',            // Style number or use ownImagePath to override style
                      ownImagePath: "${EYECANDY_RADAR_URL}",
          // Display Weather Module
          // Pages: 1, 3
          // Locations: Standard MagicMirror module
              module: "weather",
              classes: "currentweather",
                  weatherProvider: "${WEATHER_PROVIDER}",
                  tempUnits: "${STANDARD_UNITS}",
                  roundTemp: true,
                  type: "current",
                  lat: ${LATTITUDE},
                  lon: ${LONGITUDE}
          // Pages: 3
              module: "weather",
              header: "${OPPOSITE_LOCATION} Weather",
                  roundTemp: true,
                  type: "forecast",
                  tableClass: 'medium',
                  lat: ${OPPOSITE_LATTITUDE},
                  lon: ${OPPOSITE_LONGITUDE}
          // Display multi-month calendar
          // Pages: 2
          // Locations: https://github.com/BKeyport/MMM-Multimonth
              module: "MMM-Multimonth",
                  bigCalendar: false,
                  monthCount: 2,
                  monthsVertical: false,
                  startMonth: 0,
          // Calendar module for the list of calendars
          // Pages:
          // Locations: MagicMirror default module
              header: "Family Events",
              hiddenOnStartup: true,
                  broadcastPastEvents: true,
                          symbol: "calendar-check",
                          color: "blue",
                          url: "${FAMILYEVENTS_CALENDAR_URL}",
                          color: "red",
                          url: "${WINDMILLVILLAGE_CALENDAR_URL}",
                          color: "gray",
                          url: "${DATESTOREMEMBER_CALENDAR_URL}",
                          color: "red",
                          url: "${HOLIDAY_CALENDAR_URL}"
          // Display the big ole calendar
          // Pages: 2
          // Locations: https://github.com/MMRIZE/MMM-CalendarExt3
              module: "MMM-CalendarExt3",
              position: "middle_center",
              title: "",
                  mode: "week",
                  instanceId: "basicCalendar",
                  locale: 'en-US',
                  weeksInView: 4,
                  maxEventLines: 5,
                  firstDayOfWeek: 0,
                  calendarSet: ['family_events', "us_holidays", "wind_mill" , "dates_to_remember"],
          // Touch buttons on the top of the screen
          // Pages: All
          // Locations: https://github.com/Tom-Hirschberger/MMM-TouchButton
              module: "MMM-TouchButton",
              position: "top_bar",
                  buttons: [
                          label: "Page1",                // Label for Page 1 button
                          imgIcon: "${BUTTON1_IMAGE}",
                          action: "notification",         // Trigger notification action
                          notification: "PAGE_CHANGED",   // Predefined notification in MMM-Pages
                          payload: 0                      // Page index (starts at 0)
                          label: "Page2",                // Label for Page 2 button
                          imgIcon: "${BUTTON2_IMAGE}",
                          payload: 1                      // Page index for Page 2
                          label: "Page3",                // Label for Page 3 button
                          imgIcon: "${BUTTON3_IMAGE}",
                          payload: 2                      // Page index for Page 3
                          label: "Page4",                // Label for Page 4 button
                          imgIcon: "${BUTTON4_IMAGE}",
                          payload: 3                      // Page index for Page 4
                          label: "Page5",                // Label for Page 5 button
                          imgIcon: "${BUTTON5_IMAGE}",
                          payload: 4                      // Page index for Page 5
                          label: "Page6",                // Label for Page 5 button
                          imgIcon: "${BUTTON6_IMAGE}",
                          payload: 5                      // Page index for Page 5
                  buttonStyle: {
                      color: "#ffffff",
                      backgroundColor: "#0000ff"
                  panelStyle: {
                      borderRadius: "10px",
                      padding: "10px"
          // Page indicators on the bottom of the screen
          // Pages: All
          // Locations: https://github.com/edward-shen/MMM-page-indicator
              module: "MMM-page-indicator",
              position: 'bottom_bar',
                  pages: 6,
      24c850aa-5b8e-49d5-ab7c-42fa55a9da34-Screenshot from 2025-01-09 15-55-00.png
      ffbdb3f5-b8db-4245-9db3-1ec32496f5f1-Screenshot from 2025-01-09 15-55-09.png
      eab8a02a-b667-473a-abc0-ec1153befd25-Screenshot from 2025-01-09 17-02-33.png
      29c81554-aab6-4e03-8dbd-5ecdc6a567eb-Screenshot from 2025-01-09 15-55-37.png
      a38abf59-4142-4426-b280-29166f635772-Screenshot from 2025-01-09 15-55-28.png
      1 Reply Last reply Reply Quote 6
      • C Offline
        cyberphox
        Super clean looking! thanks for including the configuration file!
        • plainbrokeP Offline
          plainbroke
          @wswenson
          could I possibly get your full config for the MMM-Fuel module ???
          I had it running for a few years and then all the sudden it quit working.
          Mainly what are you using for provider: “${MMM_FUEL_PROVIDER}”,
          // Pages: 5
          module: “MMM-Fuel”,
          position: “bottom_bar”,
          zip: “${ZIP_CODE}”,
          types: [“regular”, “midgrade”, “premium”],
          open: true,
          showBrand: true,
          • W Offline
            wswenson @plainbroke
            @plainbroke
            ZIP_CODE=“01527”
            MMM_FUEL_PROVIDER=“gasbuddy”
            I see good fuel prices when I look at my FL mirror (outside of Orlando) but I just deployed this update on my MA mirror (snow birds) and it is not yet showing fuel prices in the area. It shows the correct fuel stations in the area but prices are all set to NaN at this point. Looking through logs to see if there are any errors.
            Walter
            plainbrokeP 1 Reply Last reply Reply Quote 0
              plainbroke @wswenson
              @wswenson
              Thanks, I was wondering if you where using something new I will retry fuel and see what I get…
              • W Offline
                @plainbroke Just confirmed in gasbuddy - no stations in my immediate area have prices posted right now in gasbuddy.
                • W Offline
                  wswenson
                  Challenged by my son to add “swipe”
                  Adding MMM-Touch to the configuration.
                  let config = {
                  	language: "en",
                  	locale: "en-US",
                  	timeFormat: 12,
                  		 		["MMM-Tools", "MMM-TigoEnergySolar", 'MMM-Fuel', 'MMM-JsonTable', 'MMM-SmartOil'],			// Page 5: Tools and other data
                              fixed: ["MMM-TouchButton", "MMM-Wallpaper", "MMM-page-indicator", 'MMM-Touch'],    			// Fixed modules on all pages
                  			homePage: 0,
                      	module: 'MMM-SmartOil',
                  	// Pages: 1
                  		module: "clock",
                  			clockBold: true,
                  			showSunTimes: true,
                  			lat: ${LATTITUDE},
                  			lon: ${LONGITUDE},
                  	// Stock listings
                  	// Pages: 1
                  		module: 'MMM-Jast',
                  			maxWidth: "100%",
                  			showColors: true,
                  			showCurrency: true,
                  			useGrouping: false,
                  			stocks: [
                  	// Pages: 4 - News
                  			colored: true,
                  			sports: [
                  				league: "NHL",
                  				teams: ["BOS"],
                  				league: "NBA",
                  				teams: ["BOS"],
                   				groups: ["East"],
                          			league: "MLB",
                          			teams: ["BOS"]
                  			        league: "NFL",
                  			        teams: ["NE"]
                  	// Pages: 4 - News
                  	// Pages: 4
                  	// Stock listings
                  	// Pages: 4
                  		header: "Market",
                  	// Pages: 4
                          	config:{
                  	// Pages: 4
                  		module: "newsfeed",
                          	feeds: [
                      	// Flights page 6
                  	// Pages: 6
                  			mapHeight: "400px",
                  				return txt;
                  	// Pages: 5
                  			refresh: 500 * 5,
                  			itemSize: null
                      // Pages: 5
                  			debugFlag: false,
                      // Pages: 5
                  		module: "MMM-Fuel",
                              zip: "${ZIP_CODE}",
                              open: true,
                              showBrand: true,
                      // Pages: 5
                  	// Pages: All
                  			source: "bing",
                  			crossfade: true,
                  			fadeEdges: true,
                  			maximumEntries: 25,
                  			caption: true,
                  	// Weather Graph
                  	// Pages: 3
                  			language: 'en',
                  	// Pages: 3
                  	// Pages: 1, 3
                  		module: "weather",
                  			roundTemp: true,
                  			type: "current",
                  			lat: ${LATTITUDE},
                  			lon: ${LONGITUDE}
                  	// Pages: 3
                  		module: "weather",
                  			roundTemp: true,
                  			type: "forecast",
                  	// Pages: 2
                          	bigCalendar: false,
                          	monthCount: 2,
                          	startMonth: 0,
                  	// Pages:
                  					color: "blue",
                  					color: "red",
                  					color: "gray",
                  					color: "red",
                  	// Pages: 2
                  		title: "",
                  			mode: "week",
                  			locale: 'en-US',
                  			weeksInView: 4,
                  			maxEventLines: 5,
                  			firstDayOfWeek: 0,
                  	// Pages: All
                  			buttons: [
                              buttonStyle: {
                                  color: "#ffffff",
                              panelStyle: {
                                  padding: "10px"
                  	// Pages: All
                         		pages: 6,
                   	// Enable gesture commands on the mirror
                  	// Pages: All
                  	// Locations: https://github.com/gfischershaw/MMM-Touch
                  		module: "MMM-Touch",
                  	    disabled: false,
                  			debug: false,
                  			useDisplay: false,
                  			autoMode: false,
                  			defaultMode: "default",
                  			gestureCommands: {
                  				"default":{
                  					"TAP_1": (commander) => {commander.sendNotification("USER_PRESENCE", true);},
                  					"SWIPE_LEFT_1": (commander) => {commander.sendNotification("PAGE_INCREMENT", null);},
                  					"SWIPE_RIGHT_1": (commander) => {commander.sendNotification("PAGE_DECREMENT", null);},
                  • W Offline
                    wswenson
                    Added Smart Oil Gauge module I built - uses the Smart Oil API ($) - still some fine tuning to work on and building up a dataset but the overall module seems to be working well.
