    Version 2.30.0 weather module, stuck loading, worked fine before upgrade
    52 Posts 6 Posters 33.7k Views 7 Watching
    • R
      Richard238 @sdetweil
      openweathermap.js is unchanged
      WeatherProvider.register("openweathermap", {
      	providerName: "OpenWeatherMap",
      	// Set the default config properties that is specific to this provider
      	defaults: {
      		apiVersion: "3.0",
      		apiBase: "https://api.openweathermap.org/data/",
      		// weatherEndpoint is "/onecall" since API 3.0
      		// "/onecall", "/forecast" or "/weather" only for pro customers
      		weatherEndpoint: "/onecall",
      		locationID: false,
      		// the /onecall endpoint needs lat / lon values, it doesn't support the locationId
      		lat: 0,
      		lon: 0,
      		apiKey: ""
      config.js shows
      		module: 'weather',
      		header: 'Current zzzzzzzzzzzzzzzz  weather: ',
      		position: 'top_right',
      			//weatherProvider: "openweathermap",
      			type: "current",
      			lat: nnnnnnnnnnn,
      			lon: -nnnnnnnnnnnnn,
      			apiKey: "aaaaaaaaaaaaaaaaaaaaaaaaaaa"
      			//type: 'current',
      			//location: 'xxxxxxxxxxxxxx',
      			//locationID: 'zzzzzzzz',  //ID from https://www.openweathermap.org
      			//apiKey: 'aaaaaaaaaaaaaaaaaaaaaaaaaaa'
        sdetweil @Richard238
        @Richard238
        providerName: “OpenWeatherMap”
        That is not the correct property name
        From the doc
        https://docs.magicmirror.builders/modules/weather.html#usage
        • R
          With no caps? Still doesn’t work.
            @Richard238 again show the whole config, xxx out the api key
            Start w
            position
            and config
            provider
            type ( default is current)
            apikey
            lat
            lon
            the 3.0 apikey requires a credit card backing, right?
            • R
              			module: 'weather',
              			header: 'Current zzzzzzzzzzzzz  weather: ',
              				lat: 111111111111111,
              				lon: 1111111111111111111111,
              				apiKey: "aaaaaaaaaaaaaaaaaaaaaaaaaaaaaa",
              				type: 'current',
              				units: 'config.units'
              				//location: 'zzzzzzzzzzzzzzz',
              I must have had that API key for aeons, don’t ever remember it having a c/card behind it.
              Maybe it’s out-of-date.
                @Richard238 yes they told us the old free api was being terminated. only the new api exists, so we changed the defaults
                but other users have reported the 2.5 apikey still works
                see the 1st post on this topic
                • R
                  Rberry91 @sdetweil
                  @sdetweil hi Sam,
                  I have added a credit card and added the extra codes from the article and it doesn’t load.20250308_055711.jpg
                    sdetweil @Rberry91
                    @Rberry91 if you have the 3.0 apikey you dont add any extra parms
                    just type, apikey, lat and lon
                    • R
                      Rberry91 @sdetweil
                      It still says invalid date
                      Sorry so many questions
                        sdetweil @Rberry91
                        @Rberry91 open the developers window, ctrl-shift-i,
                        select the console tab,
                        and enter weath in the filter field
                        do you see errors? like 401, 403
                        • R
                          Rberry91 @sdetweil
                            sdetweil @Rberry91
                            @Rberry91 401 means the apikey is invalid
                            • R
                              Rberry91 @sdetweil
                              Hi Sam,
                              So I got it to work however the header is Australia/Brisbane, which is not correct. But the weather details are correct, how do I change the name of the header. I have added location and locationID
                                sdetweil @Rberry91
                                @Rberry91 v3 does not return the right location,
                                location/id are not used in v3, only lat/lon
                                use the module header property
                                module:…
                                header:“…”
                                the set the weather config option
                                appendLocationToHeader:false,
                                • R
                                  Rberry91 @sdetweil
                                  Hi Sam,
                                  Now I have an message to update the MMM-GooglePhotos module. How do I do that without causing problems like before. I did try your code and it didn’t seem to work but I am most likely doing something incorrect
                                    sdetweil @Rberry91
                                    @Rberry91 didnt try my code? i do not supply anything that will update modules.
                                    my upgrade script is only for base MagicMirror
                                    every module upgrade is the same
                                    cd ~/MagicMirror/modules/modulename
                                    git pull
                                    xxx see the module doc on what to do after
                                    sometimes you need an npm install, sometimes not
                                    • R
                                      Rberry91 @sdetweil
                                      Hi again,
                                      The MMM- GoohlePhotos was not updating so I re installed and am know getting a error of missing creditionals please help20250313_050643.jpg
                                        sdetweil @Rberry91
                                        @Rberry91 now you have to follow the module instructions to get authorization again
                                        • R
                                          Rberry91 @sdetweil
                                          I reverted to the older version and I have tried updating using your command and other ones and still doesn’t update tell me that “pulling without specifying how to reconcile divergent branches is etc”
                                          The other problem I am having is the weather, the forecast works but the current Weather doesn’t and they are the same code.20250313_055015.jpg 20250313_055058.jpg
                                            sdetweil @Rberry91
                                            @Rberry91 divergent branches sounds like you have both modules trying to merge to the same folder
                                            delete then git clone again
                                            the nan says the apikey is wrong
                                            and you have a typo, MagicMirror is case sensitive
                                            • 2 / 3
