    Bugsounet and MMM-Pir
    68 Posts 10 Posters 26.3k Views 11 Watching
      @sdetweil :-).
      I like it very much because it offers a lot nice and fancy stuff as the others don’t …
      (progress bar, dimming, cron-steering for sleeping times)
      Ralf
        sdetweil @lif
        @lif can you talk about this python after …
        MagicMirror upgrades? if so , did you use my upgrade script?
        this highlights a problem. some modules need a refresh install when nodejs and MagicMirror change
        so the upgrade script does that. but that wipes the node_modules folder for the module. and the dependencies are also not available anymore.
        so, if i DO try the npm install it breaks, if i dont try the npm install it might break. fun times.
        i will add a check for the authors url and skip the install action
        R L 2 Replies Last reply Reply Quote 0
          sdetweil @rkorell
          @rkorell i hear yah.
            @sdetweil said in Bugsounet and MMM-Pir:
            at least in bugsounet’s README.md there is a hint in this direction …
              sdetweil @rkorell
              @rkorell yes, but there is nothing I can do… the dependencies no longer exist
              he had some integrated update mechanism, I added code to launch that once…
              now its dead too…
                @sdetweil OK.
                really unfortunate.
                I do not understand these dependencies - so I was hopeful that an update will not destroy module’s ability to work …
                So I have to stay with the old mirror version to keep module running?
                Regards,
                Ralf
                • L Offline
                  lif @sdetweil
                  I was trying to upgrade Nodejs and if failed with lots of errors.
                  my mm and the whole system had got messy, so I’m using this as an opportunity to clean things up (it didn’t help insofar as a restore from the most recent backup didn’t work.
                    sdetweil @rkorell
                    @rkorell said in Bugsounet and MMM-Pir:
                    i do not know…
                    rather than put all the code in the module, there are libraries of things
                    that can be called…
                    so you make those libraries as separate packages and list them in the dependencies section of package.json and npm install goes and gets them
                    he might have decided that multiple components needs the same functions and packaged as library, to be loaded by all that needed it, code once, ship multiple times…
                    except that breaks now as the dependencies also are no longer available
                    as I said in my initial warning post, plan for them all to fail to work
                      sdetweil @lif
                      @lif yeh, my upgrade script does the nodejs upgrade too…
                      use the n command
                      sudo npm install n -g
                      sudo n xxx
                      where xxx is the version you want to use
                      how backup? use my backup/restore
                      yes that is broken too, as the authors repos no longer exist and binary backup may not work on different OS level/nodejs level
                      • L Offline
                        lif @sdetweil
                        IMG file on my (new) linux desktop
                        • L Offline
                          lif @sdetweil
                          use the n command
                          sudo n xxx
                          Thanks, added to my install notes
                            sdetweil @lif
                            @lif n is the nodejs version of nvm
                              yes - as stated -really unfortunate!
                              Thanks for your clarification!
                              Ralf
                              • L Offline
                                lif @sdetweil
                                I’ve reinstalled MagicMirror with your script, it worked wonderfully, than you very much for doing this.
                                Best regards from France.
                                  rkorell Module Developer @rkorell
                                  @sdetweil @lif
                                  For your information:
                                  I was successful with installing MMM-Pir on my brand new Pi5/bookworm:
                                  pi@MagicMirrorPi5:~ $ cd MagicMirror/modules
                                  pi@MagicMirrorPi5:~/MagicMirror/modules $ tar -xf MMM-Pir.tar.gz
                                  pi@MagicMirrorPi5:~/MagicMirror/modules $ cd MMM-Pir/
                                  pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-Pir $ npm install
                                  > MMM-Pir@2.4.4 preinstall
                                  > echo ⚠ npm install will be deprecated on next release!.
                                  > MMM-Pir@2.4.4 install
                                  > npm run setup
                                  > MMM-Pir@2.4.4 presetup
                                  > npm run dependencies && installer/preinstall.sh
                                  > MMM-Pir@2.4.4 dependencies
                                  > installer/dependencies.sh -d 'unclutter ddcutil cec-utils python3 python-is-python3 python3-gpiozero gpiod libgpiod2 libgpiod-dev'
                                  Welcome to MMM-Pir v2.4.4
                                  ① ➤ dependencies installer
                                  Checking OS...
                                  OS Detected: linux-gnu (debian 12 aarch64)
                                  Checking all dependencies...
                                  All Dependencies needed are installed !
                                  ② ➤ Preinstall
                                  No root checking...
                                  Checking MMM-Pir: pi/pi
                                  Checking MagicMirror: pi/pi
                                  Installing @sdetweil sandbox fix...
                                  fixing sandbox permissions
                                  ③ ➤ Install npm dependencies
                                  > MMM-Pir@2.4.4 setup
                                  > npm prune
                                  up to date in 990ms
                                  124 packages are looking for funding
                                    run `npm fund` for details
                                  > MMM-Pir@2.4.4 postsetup
                                  > installer/postinstall.sh -m -r
                                  ④ ➤ Postinstall
                                  Minify Main code...
                                  Found: 10 files to install and minify
                                  Process File: MMM-Pir/MMM-Pir.js
                                  Process File: MMM-Pir/node_helper.js
                                  Process File: MMM-Pir/components/cronJob.js
                                  Process File: MMM-Pir/components/governorLib.js
                                  Process File: MMM-Pir/components/motion.js
                                  Process File: MMM-Pir/components/motionLib.js
                                  Process File: MMM-Pir/components/pirLib.js
                                  Process File: MMM-Pir/components/screenDisplayer.js
                                  Process File: MMM-Pir/components/screenLib.js
                                  Process File: MMM-Pir/components/screenTouch.js
                                  Done
                                  Try to Disable screen saver...
                                  Found: screen saver in gsettings
                                  disable screensaver via gsettings was true and uint32 300
                                  Found: screen saver in lightdm
                                  disable screensaver via lightdm.conf
                                  Found: screen saver in lxsession
                                  disable screensaver via lxsession
                                  Found: wayfire.ini
                                  [WARN] There is some change for disable screen saver
                                  [WARN] Please, don't forget to reboot your OS for apply the new configuration!
                                  Done
                                  Rebuild MagicMirror...
                                  ✔ Rebuild Complete
                                  Done
                                  MMM-Pir is now installed !
                                  > MMM-Pir@2.4.4 postinstall
                                  > echo ⚠ On next release, Please use: npm run setup
                                  added 1 package in 31s
                                  I will have to play with the screen options (caused for sure by bookworm) because right now I get an error notification from MMM-Pir (screen error detected: dpms command error(mode 1) ) but there are several other modes to try …
                                  Regards,
                                  Ralf
                                    sdetweil @rkorell
                                    @rkorell yeh, fun times
                                      @sdetweil yes! :-)
                                      • F Offline
                                        FrostByte Module Developer
                                        Hi everyone,
                                        I didn’t quite get it right. Are there still problems with MMM-Pir?
                                        I see that there are already two pull requests on https://github.com/Coernel82/MMM-Pir/pulls (one is from me). I would be willing to maintain the module, if no one else does.
                                        Happy to hear from you @coernel
                                          rkorell Module Developer @FrostByte
                                          @FrostByte .
                                          Yes there are still “problems”.
                                          @coernel has prepared a re-upload of bugsounet’s MMM-Pir.
                                          But for some reasons this has failed.
                                          Several entities are missing in his upload (including e.g. the core MMM-Pi.js and several other linked and necessary sub-programs (Described in more detail in this post).
                                          I’ve copied a tar.gz file of my own local repository-copy here.
                                          This copy is installable with npm install in the respective MMM-Pir directory in mirror Version 2.30 (NOT tested in brand new 2.31!).
                                          It works without problems on a Pi4 with bullseye.
                                          It does NOT work on a Raspi5/bookworm “out of the box”.
                                          In the meantime I’ve identified and corrected the root cause for this (wrong parameter for the xrandr-call).
                                          This correction is NOT reflected in the URL above because I’ve done this correction after the upload.
                                          I can share this with you if you are interested in - only a very minor adoption and only for MY use-case (working without wayland and with x11).
                                          From my side it would be really highly appreciated if somebody can take the responsibility for maintenance of this pretty module because I really like it very much.
                                          I definitely NOT able to do this but I’m definitely willing to give any additional support in the course of my (tiny) abilities…
                                          Let me know what you’re thinking about.
                                          Warm regards,
                                          Ralf
                                          • F Offline
                                            FrostByte Module Developer @rkorell
                                            Okay, let’s go into detail. @rkorell
                                            As already written by @sdetweil , the node_modules directory is created when npm run setup (or npm install as it should be called).
                                            In addition, the ‘missing files’ are also created dynamically when this command is called. See:
                                            lukas@smartmirror:~/MagicMirror/modules$ git clone https://github.com/Coernel82/MMM-Pir.git MMM-Pir-test
                                            lukas@smartmirror:~/MagicMirror/modules$ cd MMM-Pir-test
                                            lukas@smartmirror:~/MagicMirror/modules/MMM-Pir-test$ npm run setup
                                            lukas@smartmirror:~/MagicMirror/modules/MMM-Pir-test$ ls -al components/
                                            total 68
                                            drwxr-xr-x  2 lukas lukas  4096 Apr  1 19:06 .
                                            drwxr-xr-x 10 lukas lukas  4096 Apr  1 19:53 ..
                                            -rw-r--r--  1 lukas lukas  4101 Apr  2 11:23 cronJob.js
                                            -rw-r--r--  1 lukas lukas  2241 Apr  2 11:23 governorLib.js
                                            -rw-r--r--  1 lukas lukas  3894 Apr  2 11:23 motion.js
                                            -rw-r--r--  1 lukas lukas  1563 Apr  2 11:23 motionLib.js
                                            -rw-r--r--  1 lukas lukas   757 Mar  3 19:09 MotionSensor.py
                                            -rw-r--r--  1 lukas lukas  3755 Apr  2 11:23 pirLib.js
                                            -rw-r--r--  1 lukas lukas  6068 Apr  2 11:23 screenDisplayer.js
                                            -rw-r--r--  1 lukas lukas 19159 Apr  2 11:23 screenLib.js
                                            -rw-r--r--  1 lukas lukas  1763 Apr  2 11:23 screenTouch.js
                                            I use Wayland/labwc (Debian GNU/Linux 12 bookworm) on aarch64 Raspberry Pi 3B and everything is working for my Pir configuration. I did not use your copy.
                                            So i am asking again, are there some runtime errrors? So please send me errrors logs.
                                            The ‘build’ step in package.json is really very confusing. That’s why I’ve started to organise it: https://github.com/Coernel82/MMM-Pir/compare/main...LukasWestholt:MMM-Pir:main#diff-7ae45ad102eab3b6d7e7896acd08c427a9b25b346470d7bc6507b6481575d519
                                            Best regards,
                                            Lukas
                                            • 3 / 4
