    installation of modules
    20 Posts 3 Posters 5.3k Views 3 Watching
    • P Offline
      pat59
      Good evening
      I installed the MMM-Linky module after startup, I got this error message, what should I do?
        sdetweil @pat59
        @pat59 yes, go to line 270, should say
        position
        as first thing
        look at the end of line 269
        does it have a trailing comma, means more to follow
          sdetweil @pat59
          @pat59 in the MagicMirror folder
          npm run config:check
          in 2.30 the config check function runs on every start and MagicMirror will fail to start now if there is a problem
          • BKeyportB Offline
            @sdetweil indeed it does that, but I believe this may be the wrong approach.
            No matter what, MM should start, IMO. In the case of config error, could we get an error screen like above, except for have it show the output of config checker?
            This would help in server/client environments like mine, or PM2 or any number of scenarios where the logs may not be in the right spot.
              sdetweil @BKeyport
              @BKeyport we decided that starting with the wrong config is not helpful,
              and best practice says you would use manual start, after making changes, to validate the change, before restarting w pm2
                @BKeyport unfortunately because the config is broken, we cannot use any ok it
                • P Offline
                  pat59
                  Good morning
                  I don’t really understand what I should do?
                    sdetweil @pat59
                    @pat59
                    cd ~/MagicMirror
                    find the line number and look at the lines of config.js
                    around there for the error
                    • P Offline
                      pat59
                      thank you, this is what it gives cordially
                        sdetweil @pat59
                        @pat59 youve got a space between config and check
                        config:check
                        in package.json script section are all the npm commands MagicMirror suppports
                        • P Offline
                          pat59
                          merci if I understand I have to look at line 270 and a syntax error20250211_163840.jpg image.jpg
                            sdetweil @pat59
                            @pat59 correct, if you do all this over ssh instead of vnc you can copy the text, instead of screen shot. very hard to read
                            • P Offline
                              pat59
                              pi@raspberrypi:~ $ cd ~MagicMirror
                              bash: cd: ~MagicMirror: Aucun fichier ou dossier de ce type
                              pi@raspberrypi:~ $ cd ~/MagicMirror
                              pi@raspberrypi:~/MagicMirror $ npm run config:check
                              magicmirror@2.27.0 config:check
                              node js/check_config.js
                              [2025-02-11 17:59:29.192] [INFO] Checking file… /home/pi/MagicMirror/config/config.js
                              [2025-02-11 17:59:29.324] [ERROR] Your configuration file contains syntax errors :(
                              [2025-02-11 17:59:29.329] [ERROR] Line 270 column 4: Parsing error: Unexpected token position
                                sdetweil @pat59
                                position
                                as first thing
                                  @pat59 have you tried my MMM-Config, so you dont have to edit config.js, after one last time
                                  https://github.com/sdetweil/MMM-Config
                                  • P Offline
                                    pat59
                                    non j ai pas essayé MMM-Config
                                    • P Offline
                                      pat59
                                      Bonsoir merci a vous ca fonctionne effectivement il manquait une virgule au module
                                      encore merci merci bonne soirée
                                        sdetweil @pat59
                                        @pat59 vous êtes les bienvenus. content que tu l’aies réparé
                                        • P Offline
                                          pat59
                                          Good morning .
                                          after having made my MagicMirror work again thanks to you.
                                          I get this error message after installing MMM-Linky. My mirror works but not the MMM
                                          unfortunately, this module is not compatible with your os try to update your os to the latest version raspbian .
                                          what is the risk of updating to the latest raspbian version?
                                          I definitely don’t want to break my mirror.
                                          Sincerely
                                            sdetweil @pat59
                                            @pat59
                                            there is no simple way to upgrade your os, or without impacts
                                            best method is to make a new sd card
                                            use my backup/restore scripts to save your MagicMirror environment, make sure you copy off the backup folder or use the github storage approach
                                            then create a new sd card, and install MagicMirror using my install script,
                                            Make sure it runs as basic install
                                            then use my restore script to put back your MagicMirror environment
                                            but this is not perfect as OS changes impact some modules
                                            • P Offline
                                              pat59
                                              Thank you again I will leave it like this
                                              thanking you too afraid of hurting
