    I am looking for a working PIR Modul/function
    9 Posts 6 Posters 1.5k Views 5 Watching
    • K Offline
      Klinge
      Hello,
      I am looking for a working PIR module / function to turn off/on my monitor.
      Every PIR module I have tried is either deprecated, abandoned or an error appears during installation.
      I have tried the following modules
      MMM-Pir
      MMM-PIR
      MMM-PIR-Sensor-Lite
      MMM-PIR-Sensor
      MMM-SimplePIR
      and this
      https://www.putorius.net/using-pir-sensor-for-motion-detection.html
      The one from putorius.net got me the furthest. But unfortunately the command to switch the monitor on/off works
      vcgencmd display_power 0 > /dev/null
      vcgencmd display_power 1 > /dev/null
      doesn´t work for me.
      I would be really grateful if you could recommend a working PIR module or maybe you have an advice to turn on/off my monitor instead of the both commands.
      Thank you very much.
      Klinge
      KristjanESPERANTOK S 2 Replies Last reply Reply Quote 0
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @Klinge
        @Klinge MMM-Universal-Pir seems to be the newest. Have you checked that?
          sdetweil @Klinge
          @Klinge see https://forum.magicmirror.builders/post/123892
          K 1 Reply Last reply Reply Quote 1
          • K Offline
            Klinge @sdetweil
            @sdetweil @KristjanESPERANTO Now I finally had time to look into this problem further.
            Thank you very much for your tips. The module works great.
            But… I have installed the monitor vertically. This means that the MMM has to be displayed rotated by 90 degrees. When I start the MMM, it is displayed as intended. But as soon as the monitor is switched off and on again by the module, the display is no longer rotated. In other words, the MMM is then displayed as if the monitor is installed horizontally.
            Incidentally, I set the rotated display via the Raspberry OS menu.
            Do any of you have a tip on how to keep the display vertical even after movement has been recognised?
            Many thanks in advance.
            S htilburgsH 2 Replies Last reply Reply Quote 0
              sdetweil @Klinge
              @Klinge yes, the commands used will need to be told about the rotated screen. i don’t remember what those are
              if you are running the first release of bookworm with the wayland compositor
              wl-randr
              might be the command to sleep/wake up
              see wl-randr --help
                myfingersarecold
                what about SimplePIR doesnt work? did you add any issues to the github?
                i wrote it so interested to know what doesn’t work, since its currently running on my mirror.
                • htilburgsH Offline
                  htilburgs @Klinge
                  @Klinge
                  I had the same issue with MMM-Universal-Pir.
                  The maker had made a comment ABOUT It in the readme, with the correct commands after mine e-mail.
                  Read the readme and you are How to do.
                  (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
                  • K Offline
                    Klinge @htilburgs
                    Thank you all for your tips.
                    Now I could realize it with the parameter
                    --transform 90
                    My complete configuration is
                                                module: "MMM-Universal-Pir",
                                                  gpioCommand: "gpiomon -r -b gpiochip0 17",
                                                  onCommand: "wlr-randr --output HDMI-A-1 --on --transform 90",
                                                  offCommand: "wlr-randr --output HDMI-A-1 --off",
                                                  deactivateDelay: 180 * 1000,
                    and it works.
                    G 1 Reply Last reply Reply Quote 1
                    • K Klinge has marked this topic as solved on
                    • G Offline
                      gonzonia @Klinge
                      @Klinge If you find you need an alterantive- https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications/blob/master/examples/HC-SR501/HC-SR501-GPIO4-README-EN.md
