    V2.31.0 unable to start
    29 Posts 3 Posters 8.2k Views 3 Watching
    • htilburgsH Offline
      htilburgs @sdetweil
      @sdetweil Maybe I don’t understand.
      WAYLAND_DISPLAY=wayland-0 still gives wayland-1 in npm run start:wayland.
      wlr_randr gives
      pi@MagicMirror:~/MagicMirror $ wlr_randr
      -bash: wlr_randr: command not found
      By the way, my PIR command do work
      onCommand: "WAYLAND_DISPLAY='wayland-1' wlr-randr --output HDMI-A-1 --on --transform 270 --mode='1920x1080'",
      offCommand: "WAYLAND_DISPLAY='wayland-1' wlr-randr --output HDMI-A-1 --off",
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
      htilburgsH R 2 Replies Last reply Reply Quote 0
        htilburgs @htilburgs
        When I give command
        pi@MagicMirror:~ $ WAYLAND_DISPLAY='wayland-1' wlr-randr --output HDMI-A-1
        HDMI-A-1 "Samsung Electric Company SyncMaster 0x00000001 (HDMI-A-1)"
          Physical size: 700x390 mm
          Enabled: yes
          Modes:
            720x400 px, 70.082001 Hz
            640x480 px, 59.939999 Hz
            640x480 px, 60.000000 Hz
            640x480 px, 66.667000 Hz
            640x480 px, 72.808998 Hz
            640x480 px, 75.000000 Hz
            720x480 px, 59.939999 Hz
            720x480 px, 60.000000 Hz
            720x576 px, 50.000000 Hz
            800x600 px, 60.317001 Hz
            800x600 px, 72.188004 Hz
            800x600 px, 75.000000 Hz
            832x624 px, 74.551003 Hz
            1024x768 px, 60.004002 Hz
            1024x768 px, 70.069000 Hz
            1024x768 px, 75.028999 Hz
            1280x720 px, 50.000000 Hz
            1280x720 px, 59.939999 Hz
            1280x720 px, 60.000000 Hz
            1152x864 px, 75.000000 Hz
            1280x800 px, 59.910000 Hz
            1440x900 px, 59.901001 Hz
            1280x1024 px, 60.020000 Hz
            1280x1024 px, 75.025002 Hz
            1600x900 px, 60.000000 Hz
            1680x1050 px, 59.882999 Hz
            1920x1080 px, 23.976000 Hz
            1920x1080 px, 24.000000 Hz
            1920x1080 px, 25.000000 Hz
            1920x1080 px, 29.969999 Hz
            1920x1080 px, 30.000000 Hz
            1920x1080 px, 50.000000 Hz
            1920x1080 px, 59.939999 Hz
            1920x1080 px, 60.000000 Hz
            1920x1080 px, 60.000000 Hz (preferred, current)
          Position: 0,0
          Transform: 270
          Scale: 1.000000
          sdetweil @htilburgs
          @htilburgs so wayland-1 seems to be correct
            rkorell Module Developer @htilburgs
            @htilburgs said in V2.31.0 unable to start:
            shouldn’t it be wlr-randr ?
            Regards,
            Ralf
            htilburgsH S 2 Replies Last reply Reply Quote 0
              htilburgs @rkorell
              @rkorell
              You’re correct, but then I get
                @htilburgs :-)
                this is correct on console window.
                console didn’t know about display unless you’re telling him what display to use.
                As far as I know you can use
                DISPLAY=:0.0
                as a hint upfront your terminal command.
                At least for xrandr this works and is necessary.
                DISPLAY=:0.0 xrandr --output HDMI-1 --off
                is my xrandr console equivalent for the “normal” command
                I’m not THAT sure if this is true for wlr-randr .
                (Because wlr-randr do have this environment variable “WAYLAND_DISPLAY” which is not the case for xrandr…)
                HTH & regards,
                Ralf
                  sdetweil @rkorell
                  @rkorell xrandr needs DISPLAY
                    @sdetweil yes :-)
                      sdetweil @rkorell
                      @rkorell oops, never can remember when i need to use underscore vs dash! thanks for the catch!
