    MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs
    43 Posts 7 Posters 10.8k Views 7 Watching
    • V Offline
      Vulan12354
      Hello together,
      i am new to MagicMirror and the coding.
      After i updated the module MMM-PublicTransportHafas i get the following error message when starting the mirror.
      The modules is not loading anymore.
      [ERROR] Error when loading MMM-PublicTransportHafas: require() of ES Module /home/Fred/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs not supported.
      Instead change the require of /home/Fred/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs to a dynamic import() which is available in all CommonJS modules.
      Maybe someone can help me.
      S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
        sdetweil @Vulan12354
        @KristjanESPERANTO can you help here?
        • KristjanESPERANTOK Offline
          KristjanESPERANTO Module Developer @Vulan12354
          @Vulan12354 I think it is probably because of the node version. Which version are you using? Run node -v to find out. And it would also be interesting to know which MagicMirror version you are using.
          • V Offline
            Volkae @KristjanESPERANTO
            @KristjanESPERANTO
            The same problem on my MM. I did all the updates without any problems but since the last update the module does not work.
            node is v20.19.1
            MM is 2.30.0
              KristjanESPERANTO Module Developer @Volkae
              @Volkae said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
              MM is 2.30.0
              Okay, I can see this when I downgrade to 2.30.0. With 2.31.0 the issue doesn’t appear. That was not the plan, but I’ll adjust requiresVersion accordingly.
              Please update MM and check whether this solves the issue for you 🙂
              S mumblebajM 2 Replies Last reply Reply Quote 0
                sdetweil @KristjanESPERANTO
                @Volkae note that you have to update nodejs again this release
                use my upgrade script it does all the work
                same place as the install script
                • mumblebajM Online
                  mumblebaj Module Developer @KristjanESPERANTO
                  @KristjanESPERANTO Not sure if it is advisable to update the modules requiresVersion to the latest MM version. With the issue of older PI’s not able to run the latest version of MM you run the risk of the modules no longer working even if they can still work on older versions of MM. I prefer to keep my version 2 versions behind as they worked on those. Unless your module has specifically been updated with dependencies of the latest MM.
                  • P Offline
                    p1lspeda
                    I can confirm: I have the same issue.
                    Updated to latest node and MM version.
                    Did a npm -install after updating MM and node. Unfortunately it did not have an effect.
                    Any tips ?
                    Error message:
                    [2025-05-04 20:17:43.557] [ERROR] Error when loading MMM-PublicTransportHafas: require() of ES Module /home/pi/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs not supported. Instead change the require of /home/pi/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs to a dynamic import() which is available in all CommonJS modules.
                    • V Offline
                      Volkae @sdetweil
                      I used your upgrade script, update is completed, made an new install from MMM-PublicTransportHafas but it does not work
                        sdetweil @Volkae
                        @Volkae ok, did you do the apply ?
                        do
                        node -v
                        cd ~/MagicMirror
                        grep version package.json
                        MagicMirror version should be 2.31.0
                        V 1 Reply Last reply Reply Quote 1
                          sdetweil @p1lspeda
                          @p1lspeda just fyi, if you use the upgrade script it will npm install all the modules that have a package.json with dependencies after completing the MagicMirror upgrade
                            sdetweil @Volkae
                            @Volkae @p1lspeda @KristjanESPERANTO will have to advise next steps
                              KristjanESPERANTO Module Developer @sdetweil
                              @sdetweil said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
                              I need the system information part from the logs. Like this:
                              [2025-01-14 20:05:03.529] [INFO]  System information:
                              ### SYSTEM:    manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false
                              ### OS:        platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.1.21-v8+
                              ### VERSIONS:  electron: 31.2.1; used node: 20.15.0; installed node: 22.4.1; npm: 10.8.1; pm2:
                              ### OTHER:     timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                              P V 2 Replies Last reply Reply Quote 0
                              • P Offline
                                @KristjanESPERANTO said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
                                Here you go
                                [2025-05-06 06:46:30.229] [INFO]  System information:
                                ### SYSTEM:   manufacturer: ; model: ; virtual: false
                                ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.20+rpt-rpi-v8
                                ### VERSIONS: electron: 32.2.7; used node: 22.14.0; installed node: 22.14.0; npm: 10.9.2; pm2: 5.4.3
                                • V Offline
                                  Volkae @sdetweil
                                  node -v
                                  cd ~/MagicMirror
                                  22.14.0
                                  “version”: “2.30.0”,
                                  KristjanESPERANTOK S 2 Replies Last reply Reply Quote 0
                                  • V Offline
                                    Sorry, but I am not sure how to see this informations
                                      You need to update MagicMirror. The module doesn’t work anymore with MagicMirror version 2.30.0.
                                        sdetweil @Volkae
                                        @Volkae that means the upgrade didn’t execute
                                        copy/paste and execute this in a terminal window on the MagicMirror system
                                        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"  apply
                                        • P Offline
                                          p1lspeda @p1lspeda
                                          @p1lspeda said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
                                          Here you go
                                          Although it is not listed, I am running a Raspberry Pi 4
                                          pi@magicmirror:~ $ lscpu
                                          Architecture:             aarch64
                                            CPU op-mode(s):         32-bit, 64-bit
                                            Byte Order:             Little Endian
                                          CPU(s):                   4
                                            On-line CPU(s) list:    0-3
                                          Vendor ID:                ARM
                                            Model name:             Cortex-A72
                                              Model:                3
                                              Thread(s) per core:   1
                                              Core(s) per cluster:  4
                                              Socket(s):            -
                                              Cluster(s):           1
                                              Stepping:             r0p3
                                              CPU(s) scaling MHz:   50%
                                              CPU max MHz:          1800.0000
                                              CPU min MHz:          600.0000
                                              BogoMIPS:             108.00
                                              Flags:                fp asimd evtstrm crc32 cpuid
                                          Caches (sum of all):
                                            L1d:                    128 KiB (4 instances)
                                            L1i:                    192 KiB (4 instances)
                                            L2:                     1 MiB (1 instance)
                                          NUMA:
                                            NUMA node(s):           1
                                            NUMA node0 CPU(s):      0-3
                                          Vulnerabilities:
                                            Gather data sampling:   Not affected
                                            Itlb multihit:          Not affected
                                            L1tf:                   Not affected
                                            Mds:                    Not affected
                                            Meltdown:               Not affected
                                            Mmio stale data:        Not affected
                                            Reg file data sampling: Not affected
                                            Retbleed:               Not affected
                                            Spec rstack overflow:   Not affected
                                            Spec store bypass:      Vulnerable
                                            Spectre v1:             Mitigation; __user pointer sanitization
                                            Spectre v2:             Vulnerable
                                            Srbds:                  Not affected
                                            Tsx async abort:        Not affected
                                            sdetweil @p1lspeda
                                            @p1lspeda have you tried the upgrade script?
                                            I believe the module requires 2.31.0 as a minimum MM version now
                                            • 1 / 3
