    MMM-MPlayer
    Scheduled Pinned Locked Moved Solved Entertainment
    5 Posts 2 Posters 2.2k Views 1 Watching
    • plainbrokeP
      plainbroke
      Anyone else having trouble with MMM-MPlayer?
      All the sudden I can not get it to see my camera’s, 7 of them and I have tested they all work in VLC on my laptop… I know its kind of like comparing apples to oranges.
      Any Ideas. Here are How i install it.
      In the home directory /home/pi
      sudo apt install -y mplayer
      Then I do in ~MagicMirror/modules
      git clone https://github.com/evroom/MMM-MPlayer.git
      Then in my Config.js
      				module: "MMM-MPlayer",
      //		        		disabled: true,
      				header: "",
      					useTwoWindows: false,  //true,
      					layout: "row",
      					monitorAspect: 0,
      					rotate: -1,
      					windowSize: { width: 1860, height: 920 },
      					windowPosition: { x: 5, y: 5 },
      					streamInterval: 20000,
      				streams: {
      						window1: [
      							"rtsp://admin1:admin1@192.168.1.40:554/stream1",
      							"rtsp://admin1:admin1@192.168.1.42:554/stream1",
      Help me I have fallen down a rabbit hole I think…
      Raspberry Pi 4 w 4gb ram
      Bookworm fully updated.
      MagicMirror latest version 2.32 I think.it is.
      PS:
      It was working on this exact setup 3 days ago, but after it came backup after pm2 stop @9pm and pm2 restart @7am, it did not work… It does it automatically, happens every day.
      evroomE 1 Reply Last reply Reply Quote 0
      • evroomE
        evroom @plainbroke
        @plainbroke
        Can you please provide me with the output of:
        $ grep Version /home/admin/MagicMirror/modules/MMM-MPlayer/node_helper.js
        And the commands found in this section of the README:
        https://github.com/evroom/MMM-MPlayer?tab=readme-ov-file#data-gathering
        I have a feeling you have placed the config from the old version into the ‘new’ version.
        Or in other words: you installed version 2…0.1, without changing the config accordingly, which has changed quite a bit.
        See https://github.com/evroom/MMM-MPlayer?tab=readme-ov-file#config-example
        MagicMirror version: 2.37.0
        plainbrokeP 2 Replies Last reply Reply Quote 0
        • plainbrokeP
          plainbroke @evroom
          @evroom
          Version 2
          I will reload it and try again.
          Thanks for the information.
          • plainbrokeP
            plainbroke @evroom
            @evroom
            You are correct sir,
            I had done a git pull and forgot about it on all modules.
            Yours updated me to 2.0 version and my config was from the 1.0 version.
            Fixed me right up.
            Thanks for your help.
            Really appreciated.
            • plainbrokeP plainbroke marked this topic as a question on
            • plainbrokeP plainbroke has marked this topic as solved on
            • evroomE
              evroom @plainbroke
              @plainbroke
              Happy to help.
