Navigation
    • Search
    MagicMirror² v2.15.0 is available! For more information about this release, check out this topic.
    Nodemailer, kind of related to MM
    General Discussion
    • Mykle1
      Mykle1 Project Sponsor Module Developer last edited by
      This may not be directly related to MM but it is required to use the camera module, so kinda, sorta, you know . . .
      I’m not really sure how to proceed with installing this. Every module that I’ve cloned from github came with instructions on WHERE (the directory) to clone it to. Nodemailer does not. So, if anyone knows, or has experience with installing this, please advise me how to continue. Does it go in MM folder, the modules folder, somewhere else?
      Many thanks ahead of time 👍🏻
      strawberry 3.141 1 Reply Last reply Reply Quote 0
      • strawberry 3.141
        strawberry 3.141 Project Sponsor Module Developer @Mykle1 last edited by
        @Mykle1 https://github.com/alexyak/camera#setup
        npm install in your module directory ~/MagicMirror/modules/camera
        Mykle1 1 Reply Last reply Reply Quote 1
        • Mykle1
          Mykle1 Project Sponsor Module Developer @strawberry 3.141 last edited by
          @strawberry-3.141 said in Nodemailer, kind of related to MM:
          Yes, I had already done that. I did not realize that nodemailer was installed as a dependency at that time into the node_modules folder of the camera module. I thought it was a separate installation. I must have misread the guide. So, thank you for pointing me in the right direction. Now I just have to figure out why it’s not mailing the “selfie” picture that the camera module is taking
