    PIR-Sensor - put your mirror to sleep if not used
    126 Posts 37 Posters 235.4k Views 20 Watching
    • paviroP Offline
      paviro @pugsly
      @pugsly I am busy this weekend but I will check next week, for the time being check your web inspector for any errors and make sure there is no mistake in your formatting of the config.js file!
      We're all stories in the end. Just make it a good one, eh?
      – The Doctor
      • P Offline
        PtrBld Module Developer
        @pugsly: Are you using Node v6? I had the same issue this weekend.
        • I Offline
          incubik
          Hi! Im having the same issue as @pugsly. I do already have the PIR sensor connected but once I launch the MagicMirror the screen goes white.
          This is what I have in the config.js:
          module: "MMM-PIR-Sensor',
          sensorPIN: '2'
          Any thoughts? Thx!
          • I Offline
            incubik
            There was a type on my message… sorry. This is what I have done:
            module: 'MMM-PIR-Sensor’,
            sensorPIN: ‘2’
            Note from admin: Please use Markdown on code snippets so it is easier to read!
            paviroP 1 Reply Last reply Reply Quote 0
            • paviroP Offline
              paviro @incubik
              @incubik have you checked your Web inspector?
              – The Doctor
              • I Offline
                incubik
                I have Raspbian install so Im using Epiphany. Does this browser has a web inspector? if so, where? Thx
                • pugslyP Offline
                  pugsly
                  I got my sensor and hooked it up, same problem.
                  Yes, I am using node version 6.0. When I did the install that’s the version that was installed, I think the install script now installs an older version?
                  • BangeeB Offline
                    Bangee Module Developer
                    I’ve tried to use PIN 26. In my electron errorlog, there was this msg:
                    [Error: digitalRead: IsInt32(arguments['pin']) === false]
                    So I went back to PIN 22 and now my mirror starts again. :-)
                    EDIT:
                    New idea -> Try without ’ ';
                    sensorPIN: 2 ,
                    • paviroP Offline
                      paviro @incubik
                      @incubik I don’t use that browser, Google it :)
                      @pugsly Node v6 is not supported at the moment.
                      @Bangee yes, the pin has to be an int :) @incubik you also made that mistake!
                      – The Doctor
                      • I Offline
                        incubik
                        Ok, I will!
                        Maybe it is a hardware problem? I’ve connected the PIR-sensor this way, is this correct?
                        https://www.raspberrypi.org/learning/physical-computing-guide/connect-pir/
                        • 9
                        • 10
                        • 11
                        • 12
                        • 13
                        • 12 / 13
