    PIR-Sensor - put your mirror to sleep if not used
    126 Posts 37 Posters 250.8k Views 20 Watching
      phrazelle
      Thanks for the module - this is fantastic!
      I have a PIR sensor attached and it works as desired, but when the HDMI signal is cut to the TV, I get a “No Signal” message on the screen from the TV itself because the RPi isn’t sending signal anymore.
      I’m wondering what the best solution would be. My head goes to hiding all modules instead of turning the monitor off so MM is still on but a completely black screen, or somehow send the RPi into a sleep state but keep the HDMI active.
      Has anyone else tackled this issue?
        McSorley @phrazelle
        @phrazelle The idea behind it is so that when the HDMI is disabled you would get the no signal. You then set up the TV/Monitor to go to sleep if no signal is found.
        Check your TV manual for power saving settings.
          phrazelle @McSorley
          @McSorley Thanks for the response!
          Unfortunately my TV doesn’t have a sleep mode option. It automatically displays the No Signal message and turns off after a few minutes of no signal. To make that more difficult, if the TV is turned back on with the remote, it loses the resolution settings and blows everything up until the RPi is rebooted.
          I’m not sure how to address this, but I think it would be ideal in my circumstance to have this module, but triggered by the PIR sensor. Idk if I can finagle that, but I suppose I can give it a shot.
          • N Offline
            nem1
            Do we still have this problem with the node version? (v5 works, 6 not)
              bibi
              @phrazelle hi! did you find a way to disable this message? i have the same annoying one :)
                phrazelle @bibi
                @bibi Yes! Here is the post I submitted around the new module. Remember that you still need the MMM-PIR-Sensor module by paviro installed for this to work.
                  bibi @phrazelle
                  @phrazelle interesting! thx a lot will check this :)
                    AlessandroRa @DirkS
                    Yay! I’ve finally solved my blank screen issue, now I’ve the same problem as @DirkS… After a while the screensaver activates, the screen becomes dark and even if I wave in front of the sensor the mirror doesn’t go on again…
                    @paviro any idea why?
                      AlessandroRa
                      Nevermind, I’m back on the white page problem… It keeps saying “Error: Module version mismatch. Expected 50, got 51”
                      I tried either: npm rebuild --runtime=electron --target=1.4.0 --disturl=https://atom.io/download/atom-shell --build-from-source
                      and: npm rebuild --runtime=electron --target=1.4.5 --disturl=https://atom.io/download/atom-shell --abi=50
                      but it doesn’t change…
                      • Y Offline
                        yawns Moderator @AlessandroRa
                        @AlessandroRa
                        Please run npm list and check for your electron version. Then rerun the command you already tried with the right version number
                          AlessandroRa @yawns
                          @yawns thank you, that solved it! Now I need to understand why nothing happens even if I wave in front of the sensor…
                          I’m starting to think that the PIR sensor doesn’t work
                          • T Offline
                            Them Russians
                            Hey all,
                            I am a relative novice when it comes to the Pi, and have been trying to identify why I am unable to install the dependencies via “npm install”.
                            I cloned the repository into my “modules” folder via the “git clone…” command (Step 1).
                            I then navigated into the new “MMM-PIR-Sensor” folder and ran “npm install”.
                            However, I got an error during the install suggesting I have an issue with electron-rebuild. Is anyone familiar with what could cause this error to be thrown, and what I could do to resolve it?
                            Here is the error:
                            Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /home/pi/MagicMirror/modules/MMM-PIR-Sensor
                            electron-rebuild -e …/…/node_modules/electron-prebuilt
                            An unhandled error occurred inside electron-rebuild
                            Unable to find electron-prebuilt’s version number, either install it or specify an explicit version
                            Error: Unable to find electron-prebuilt’s version number, either install it or specify an explicit version
                            at _callee$ (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:74:17)
                            at tryCatch (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/regenerator-runtime/runtime.js:63:40)
                            at GeneratorFunctionPrototype.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/regenerator-runtime/runtime.js:337:22)
                            at GeneratorFunctionPrototype.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/regenerator-runtime/runtime.js:96:21)
                            at GeneratorFunctionPrototype.tryCatcher (/home/pi/node_modules/bluebird/js/release/util.js:16:23)
                            at PromiseSpawn._promiseFulfilled (/home/pi/node_modules/bluebird/js/release/generators.js:97:49)
                            at /home/pi/node_modules/bluebird/js/release/generators.js:201:15
                            at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:197:4)
                            at Module._compile (module.js:570:32)
                            at Object.Module._extensions…js (module.js:579:10)
                            at Module.load (module.js:487:32)
                            at tryModuleLoad (module.js:446:12)
                            at Function.Module._load (module.js:438:3)
                            at Module.runMain (module.js:604:10)
                            at run (bootstrap_node.js:394:7)
                            at startup (bootstrap_node.js:149:9)
                            npm ERR! Linux 4.4.38-v7+
                            npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “install”
                            npm ERR! node v6.9.2
                            npm ERR! npm v3.10.9
                            npm ERR! code ELIFECYCLE
                            npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: electron-rebuild -e ../../node_modules/electron-prebuilt
                            npm ERR! Exit status 255
                            npm ERR!
                            npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script ‘electron-rebuild -e …/…/node_modules/electron-prebuilt’.
                            npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-PIR-Sensor package,
                            npm ERR! not with npm itself.
                            npm ERR! electron-rebuild -e …/…/node_modules/electron-prebuilt
                            npm ERR! npm bugs Magic-Mirror-Module-PIR-Sensor
                            npm ERR! Or if that isn’t available, you can get their info via:
                            npm ERR! npm owner ls Magic-Mirror-Module-PIR-Sensor
                            npm ERR! /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
                            • E Offline
                              elmerito25 @cpramhofer
                              @cpramhofer Were you able to fix your problem?
                              • N Offline
                                Nususu @jrleeman
                                @jrleeman Hi I have the same issue that you do with the on signal only being put out for about a second after motion detection. Did you ever find a way to make the mirror stay awake for longer with the timer being reset by any motion signal?
                                • T Offline
                                  Them Russians @Nususu
                                  @Nususu Did you have any issues with the npm install of this module? I am still unable to install the module :(
                                    Jopyth Moderator
                                    Please continue discussion about install issues here. There is already info on how it can be solved. For other problems with the PIR-Sensor Module please open a new thread in the troubleshooting section.
                                    • 6 / 7
