    PIR-Sensor - put your mirror to sleep if not used
    126 Posts 37 Posters 257.5k Views 20 Watching
      desq @cowboysdude
      @cowboysdude
      I got it. I installed the latest node. (6.2.1) Pull MMM-PIR from the git Repository und did all the steps Paviro explains on the module page.
      And suddenly no more the white screen and the “USER_PRESENCE” notification is send every 5-6 sec.
      @paviro
      could implement a parameter to set the duration for a monitor shutdown as no USER_PRESENCE is detected?
        Jaghova
        A stupid question, where “USER_PRESENCE” notification must appear? in ‘PM2 logs mm’ ??
        If so, It doesn’t appear in my logs, which means I don’t have the module correctly installed right?
        But if i check on ‘GPIO readall’ I can see how the IN is activated and also the OUT relay when it detects presence
        • cowboysdudeC
          cowboysdude Module Developer @desq
          @desq I’m not using the mmm-PIR I’m using something else… BUT I do know from reading that it wasn’t working with node V6… you had to roll back to V5.
          I still had trouble with v5 so I went with something else…
          D 1 Reply Last reply
            desq @cowboysdude
            @cowboysdude mh… I really would like to stick with paviros module.
            “USER_PRESENCE” (PIR Sensor) seems to work, but my Relay does not change it´s state.
            @paviro can you confirm, that your PIR module doesn´t work with node 6.22?
            If so I must switch to that python-script-hell.
              paviro
              @desq sorry no idea :D haven’t touched it in a while since I am pretty busy at the moment (finished school, now moving to a new city at the other side of the country). Could be possible that my dependencies work with v6 now but I still need to update it and change some stuff once I have the time :)
              What exactly do you mean by duration? A delay? My PIR-Sensor can do that in hardware thats why I haven’t implemented it.
              – The Doctor
              W 1 Reply Last reply
              • X
                xdker
                • W
                  Wilco89 @paviro
                  @paviro got a complete White screen and no posibility to use vnc. Got there the Same White screen and no option to open terminal anybody a solution so i can disable the module?
                  K 1 Reply Last reply
                  • K
                    KirAsh4 Moderator @Wilco89
                    @Wilco89, use SSH to log into it, user 'pi', password 'raspberry' unless you changed it to something else. Edit the config file, reboot the rpi.
                    • W
                      Wilco89 @KirAsh4
                      @KirAsh4 didn’t think about that. Oops
                        murattyilmaz
                        I’ve installed this module and sensor to my pi but I’m facing an issue.
                        When I start the app, its loading as expected and show everything normally.
                        After 5 sec. my monitor goes to sleep and says me “no signal” even if I shake may hand front of it.
                        Then monitor blink a few times and seems like open but nothing to show or said.
                        After this situation, never comes to live back and can’t close or shut down the app (can’t go back to OS screen). I have to shut the power to reset my pi.
                        Do you have any idea why this happens?
                          McSorley
                          Any ETA on when the update will occur for removing the wiring-pi dependency? I wouldn’t like going down to a lower version of Node.js for this to work encase I break the whole thing.
                            paviro
                            Sorry no :/ I just started a new job/school and I do not currently have a mirror setup :( but it should really not be that hard to do so feel free to just try! You can use onoff there is an example which would not need to be changed much to replace wiring Pi in my code :)
                            If you succeed please send a pull request!
                            Edit: If I find some time this evening I will try to do it but you will have to test as again I don’t have a mirror currently.
                            – The Doctor
                              paviro
                              Double post so you get notified: Done feel free to try :) don’t forget to reinstall the module with npm install!
                              – The Doctor
                              M 1 Reply Last reply
                                Mitchfarino Module Developer @paviro
                                @paviro So it works with node 6 now?
                                P 1 Reply Last reply
                                  paviro @Mitchfarino
                                  @Mitchfarino if it still works at all yes :)
                                  – The Doctor
                                    paviro
                                    Now it should definitely work :)
                                    – The Doctor
                                    Reply Quote 3
                                      shgmongohh @murattyilmaz
                                      @murattyilmaz
                                      I have the same issue. Does anybody have a solution for this problem?
                                        cpramhofer
                                        I´m playing around with PIR and after reinstalling npm it seems to work.
                                        the only problem is that my monitor is switching on and off every couple of seconds.
                                        do you guys have a picture of how your sensor is setup (Poti, Trigger Jumper)?
                                        thanks a lot!
                                        E 1 Reply Last reply
                                          DirkS
                                          i have some issue with the PIR Module. It worked for testing a couple of month but now under productive operation it doesn’t :(
                                          The Screen is switched off and on correctly but after a unspecified time it doesn’t switch it on anymore, it stays black. Sometimes after an hour sometimes after a couple of minutes.
                                          The PIR itself is working correctly as i discovered, i’m also getting it’s state under FHEM and there i can see the relaible functionality of it. I connected it to the GPIO 21.
                                          As i can see on the screen it doesn’t get any video input anymore. Only rebooting the PI2 will fix it.
                                          I’m not sure where to search :(
                                          Some startup log entrie doesn’t show anything.
                                          > magicmirror@2.0.0 start /home/pi/MagicMirror
                                          > electron js/electron.js
                                          Loading config ...
                                          Loading module helpers ...
                                          All module helpers loaded.
                                          Starting server op port 8080 ...
                                          Server started ...
                                          Connecting socket for: MMM-FHEM
                                          Connecting socket for: MMM-PIR-Sensor
                                          Starting module: newsfeed
                                          Launching application.
                                          A 1 Reply Last reply
                                            phrazelle
                                            Thanks for the module - this is fantastic!
                                            I have a PIR sensor attached and it works as desired, but when the HDMI signal is cut to the TV, I get a “No Signal” message on the screen from the TV itself because the RPi isn’t sending signal anymore.
                                            I’m wondering what the best solution would be. My head goes to hiding all modules instead of turning the monitor off so MM is still on but a completely black screen, or somehow send the RPi into a sleep state but keep the HDMI active.
                                            Has anyone else tackled this issue?
                                            • 6 / 7
