    mm-pir-hide-all
    14 Posts 10 Posters 11.7k Views 10 Watching
    • P
      phrazelle
      https://github.com/phrazelle/mm-pir-hide-all
      This is a modification of the MM-Hide-All module (https://github.com/masters1222/mm-hide-all) by masters1222. It requires the MMM-PIR-Sensor module (https://github.com/paviro/MMM-PIR-Sensor) by paviro to be installed as well, as the hiding/unhiding is triggered by the “USER_PRESENCE” notification sent.
      This was created by Josh Mclaughlin to circumvent an issue with the MMM-PIR-Sensor module where a TV doesn’t have power saving settings and killing the HDMI signal from the RPi forces the TV to shut off automatically.
      This essentially brings up a black box to cover the screen after a set amount of time that disappears upon a USER_PRESENCE notification from the MMM-PIR-Sensor module.
      A 1 Reply Last reply
      Reply Quote 1
      • A
        Atheose @phrazelle
        @phrazelle As someone who is having trouble with the MMM-PIR-Sensor module, this is a lifesaver! Going to give it a try today.
        Thanks @phrazelle!
        • N
          Nususu
          Great addition to the PIR-Sensor module. I’ve got it working on my mirror, but the only issue is that when the sensor detects movement, the screen only stays active for about a second, then goes to sleep again. Is there a line in your code that I could modify so that when movement is detected, the mirror stays on for a set duration (maybe 4 minutes)? I’ve been looking at the code but I’m new to this so I don’t really know where to start.
          lolobyteL D 2 Replies Last reply
          • lolobyteL
            lolobyte @Nususu
            @Nususu
            I think this is not a software problem.
            On your Sensor are two variable resistors.
            One for the sensitivity and one for the delay time.
            Take a screwdriver and adjust the delay time.
            N 1 Reply Last reply
            • N
              Nususu @lolobyte
              @lolobyte thanks for your reply. I am actually not using a PIR sensor, but a microwave radar sensor as I wanted to put the sensor behind the glass. After looking into it, I found that I can install a resistor on the sensor to set delay to 30 seconds.
              https://www.amazon.com/gp/aw/d/B01JA7K2EM/ref=mp_s_a_1_7?ie=UTF8&qid=1485446060&sr=8-7&pi=AC_SX236_SY340_QL65&keywords=microwave+sensor&dpPl=1&dpID=51f4ntKudYL&ref=plSrch
              If I want more than 30 seconds, would placing a higher resistance resistor on it work?
              lolobyteL 1 Reply Last reply
              • lolobyteL
                lolobyte @Nususu
                @Nususu
                Wow, nice.
                Please send me all your information what you have because i want to build and test it by my mirror.
                • P
                  phrazelle
                  Agreed, I think altering the delay on the sensor would fix the issue.
                  That being said, the microwave radar sensor sounds awesome! I’d like to see it in action as well.
                  • O
                    Oliver_Tooth
                    I’m struggling to get this working, i’m just receiving a black screen that doesn’t want to exit. I’ve tested the PIR sensor with a simple python script and it works fine, i’m just having trouble getting it to integrate with the mirror. Any advice?
                    • M
                      magicR
                      I did some changes because of the fading-effect.
                      All Modules fades now In and Out correctly.
                      Here is my repo: https://github.com/s72817/MMM-PIR-Fade-HIDE
                      Greetings
                      C M 2 Replies Last reply
                      Reply Quote 1
                      • C
                        coltography @magicR
                        @magicr how do I implement your repo to get the fade working? Do I add it in as another module or merge your files within the mm-pir-hide-all module? I can’t get it working
                        M S 2 Replies Last reply
                        • M
                          magicR @coltography
                          @coltography sorry for the late answer :/
                          You need the MMM-PIR-Sensor Module.
                          A config example:
                          module: “MMM-PIR-Sensor”,
                          sensorPin: 23,
                          powerSaving: false
                          module: “MMM-PIR-Fade-HIDE”,
                          position: “fullscreen_below”,
                          fadeInTime: 1000,
                          fadeOutTime: 3000,
                          cheers Richard
                            sdetweil @coltography
                            @coltography the hide() api, takes an optional amount of time
                            search ‘hide’ in the development doc
                            https://github.com/MichMich/MagicMirror/tree/master/modules
                            this.hide(speed, callback, options)
                            • D
                              dvbit @Nususu
                              @Nususu hi i have a microwave sensor too is the resistance mod needed? I do not want to reopen the mirror…
                              • M
                                majik655 @magicR
                                @magicR Wondering if you can help me…
                                I have implemented your module on my magic mirror with PIR sensor.
                                The issue I seem to have with ALL hiding modules is it seems the PIR is initiating BOTH hiding AND unhiding.
                                I just can not seem to figure out what is going on. I can adjust the delay and sensitivity if I need to on the sensor but I dont think I need to mess with that at this moment…
                                I really just want the mirror to be on… say for 20 minutes… then if no trigger … hide.
                                Then turn on when triggered and stay on for 20 minutes… rinse and repeat.
                                Can you help me ?
                                My config is below:
                                                        module: 'MMM-PIR-Sensor',
                                                        sensorPin: '22',
                                                        powerSaving: false,
                                                module: "mm-pir-hide-all",
                                                position: "fullscreen_below",
                                                        fadeInTime: '1000',
                                                        fadeOutTime: '300000',
