    mm-pir-hide-all
    14 Posts 10 Posters 11.6k Views 10 Watching
    • L
      lolobyte @Nususu
      @Nususu
      I think this is not a software problem.
      On your Sensor are two variable resistors.
      One for the sensitivity and one for the delay time.
      Take a screwdriver and adjust the delay time.
      N 1 Reply Last reply
      • N
        Nususu @lolobyte
        @lolobyte thanks for your reply. I am actually not using a PIR sensor, but a microwave radar sensor as I wanted to put the sensor behind the glass. After looking into it, I found that I can install a resistor on the sensor to set delay to 30 seconds.
        https://www.amazon.com/gp/aw/d/B01JA7K2EM/ref=mp_s_a_1_7?ie=UTF8&qid=1485446060&sr=8-7&pi=AC_SX236_SY340_QL65&keywords=microwave+sensor&dpPl=1&dpID=51f4ntKudYL&ref=plSrch
        If I want more than 30 seconds, would placing a higher resistance resistor on it work?
        L 1 Reply Last reply
        • L
          lolobyte @Nususu
          @Nususu
          Wow, nice.
          Please send me all your information what you have because i want to build and test it by my mirror.
            phrazelle
            Agreed, I think altering the delay on the sensor would fix the issue.
            That being said, the microwave radar sensor sounds awesome! I’d like to see it in action as well.
            • O
              Oliver_Tooth
              I’m struggling to get this working, i’m just receiving a black screen that doesn’t want to exit. I’ve tested the PIR sensor with a simple python script and it works fine, i’m just having trouble getting it to integrate with the mirror. Any advice?
                magicR
                I did some changes because of the fading-effect.
                All Modules fades now In and Out correctly.
                Here is my repo: https://github.com/s72817/MMM-PIR-Fade-HIDE
                Greetings
                C M 2 Replies Last reply
                  coltography @magicR
                  @magicr how do I implement your repo to get the fade working? Do I add it in as another module or merge your files within the mm-pir-hide-all module? I can’t get it working
                  M S 2 Replies Last reply
                    magicR @coltography
                    @coltography sorry for the late answer :/
                    You need the MMM-PIR-Sensor Module.
                    A config example:
                    module: “MMM-PIR-Sensor”,
                    sensorPin: 23,
                    powerSaving: false
                    module: “MMM-PIR-Fade-HIDE”,
                    position: “fullscreen_below”,
                    fadeInTime: 1000,
                    fadeOutTime: 3000,
                    cheers Richard
                      sdetweil @coltography
                      @coltography the hide() api, takes an optional amount of time
                      search ‘hide’ in the development doc
                      https://github.com/MichMich/MagicMirror/tree/master/modules
                      this.hide(speed, callback, options)
                        dvbit @Nususu
                        @Nususu hi i have a microwave sensor too is the resistance mod needed? I do not want to reopen the mirror…
                          majik655 @magicR
                          @magicR Wondering if you can help me…
                          I have implemented your module on my magic mirror with PIR sensor.
                          The issue I seem to have with ALL hiding modules is it seems the PIR is initiating BOTH hiding AND unhiding.
                          I just can not seem to figure out what is going on. I can adjust the delay and sensitivity if I need to on the sensor but I dont think I need to mess with that at this moment…
                          I really just want the mirror to be on… say for 20 minutes… then if no trigger … hide.
                          Then turn on when triggered and stay on for 20 minutes… rinse and repeat.
                          Can you help me ?
                          My config is below:
                                                  module: 'MMM-PIR-Sensor',
                                                  sensorPin: '22',
                                                  powerSaving: false,
                                          module: "mm-pir-hide-all",
                                          position: "fullscreen_below",
                                                  fadeInTime: '1000',
                                                  fadeOutTime: '300000',
