    mm-pir-hide-all
    14 Posts 10 Posters 10.5k Views 10 Watching
    • N Offline
      Nususu @lolobyte
      @lolobyte thanks for your reply. I am actually not using a PIR sensor, but a microwave radar sensor as I wanted to put the sensor behind the glass. After looking into it, I found that I can install a resistor on the sensor to set delay to 30 seconds.
      https://www.amazon.com/gp/aw/d/B01JA7K2EM/ref=mp_s_a_1_7?ie=UTF8&qid=1485446060&sr=8-7&pi=AC_SX236_SY340_QL65&keywords=microwave+sensor&dpPl=1&dpID=51f4ntKudYL&ref=plSrch
      If I want more than 30 seconds, would placing a higher resistance resistor on it work?
      lolobyteL 1 Reply Last reply Reply Quote 0
      • lolobyteL Offline
        lolobyte @Nususu
        @Nususu
        Wow, nice.
        Please send me all your information what you have because i want to build and test it by my mirror.
          phrazelle
          Agreed, I think altering the delay on the sensor would fix the issue.
          That being said, the microwave radar sensor sounds awesome! I’d like to see it in action as well.
          • O Offline
            Oliver_Tooth
            I’m struggling to get this working, i’m just receiving a black screen that doesn’t want to exit. I’ve tested the PIR sensor with a simple python script and it works fine, i’m just having trouble getting it to integrate with the mirror. Any advice?
              magicR
              I did some changes because of the fading-effect.
              All Modules fades now In and Out correctly.
              Here is my repo: https://github.com/s72817/MMM-PIR-Fade-HIDE
              Greetings
              C M 2 Replies Last reply Reply Quote 1
                coltography @magicR
                @magicr how do I implement your repo to get the fade working? Do I add it in as another module or merge your files within the mm-pir-hide-all module? I can’t get it working
                M S 2 Replies Last reply Reply Quote 0
                  magicR @coltography
                  @coltography sorry for the late answer :/
                  You need the MMM-PIR-Sensor Module.
                  A config example:
                  module: “MMM-PIR-Sensor”,
                  sensorPin: 23,
                  powerSaving: false
                  module: “MMM-PIR-Fade-HIDE”,
                  position: “fullscreen_below”,
                  fadeInTime: 1000,
                  fadeOutTime: 3000,
                  cheers Richard
                    sdetweil @coltography
                    @coltography the hide() api, takes an optional amount of time
                    search ‘hide’ in the development doc
                    https://github.com/MichMich/MagicMirror/tree/master/modules
                    this.hide(speed, callback, options)
                      dvbit @Nususu
                      @Nususu hi i have a microwave sensor too is the resistance mod needed? I do not want to reopen the mirror…
                        majik655 @magicR
                        @magicR Wondering if you can help me…
                        I have implemented your module on my magic mirror with PIR sensor.
                        The issue I seem to have with ALL hiding modules is it seems the PIR is initiating BOTH hiding AND unhiding.
                        I just can not seem to figure out what is going on. I can adjust the delay and sensitivity if I need to on the sensor but I dont think I need to mess with that at this moment…
                        I really just want the mirror to be on… say for 20 minutes… then if no trigger … hide.
                        Then turn on when triggered and stay on for 20 minutes… rinse and repeat.
                        Can you help me ?
                        My config is below:
                                                module: 'MMM-PIR-Sensor',
                                                sensorPin: '22',
                                                powerSaving: false,
                                        module: "mm-pir-hide-all",
                                        position: "fullscreen_below",
                                                fadeInTime: '1000',
                                                fadeOutTime: '300000',
