    mm-pir-hide-all
    14 Posts 10 Posters 10.4k Views 10 Watching
    • lolobyteL Offline
      lolobyte @Nususu
      @Nususu
      Wow, nice.
      Please send me all your information what you have because i want to build and test it by my mirror.
        phrazelle
        Agreed, I think altering the delay on the sensor would fix the issue.
        That being said, the microwave radar sensor sounds awesome! I’d like to see it in action as well.
        • O Offline
          Oliver_Tooth
          I’m struggling to get this working, i’m just receiving a black screen that doesn’t want to exit. I’ve tested the PIR sensor with a simple python script and it works fine, i’m just having trouble getting it to integrate with the mirror. Any advice?
            magicR
            I did some changes because of the fading-effect.
            All Modules fades now In and Out correctly.
            Here is my repo: https://github.com/s72817/MMM-PIR-Fade-HIDE
            Greetings
            C M 2 Replies Last reply Reply Quote 1
              coltography @magicR
              @magicr how do I implement your repo to get the fade working? Do I add it in as another module or merge your files within the mm-pir-hide-all module? I can’t get it working
              M S 2 Replies Last reply Reply Quote 0
                magicR @coltography
                @coltography sorry for the late answer :/
                You need the MMM-PIR-Sensor Module.
                A config example:
                module: “MMM-PIR-Sensor”,
                sensorPin: 23,
                powerSaving: false
                module: “MMM-PIR-Fade-HIDE”,
                position: “fullscreen_below”,
                fadeInTime: 1000,
                fadeOutTime: 3000,
                cheers Richard
                  sdetweil @coltography
                  @coltography the hide() api, takes an optional amount of time
                  search ‘hide’ in the development doc
                  https://github.com/MichMich/MagicMirror/tree/master/modules
                  this.hide(speed, callback, options)
                    dvbit @Nususu
                    @Nususu hi i have a microwave sensor too is the resistance mod needed? I do not want to reopen the mirror…
                      majik655 @magicR
                      @magicR Wondering if you can help me…
                      I have implemented your module on my magic mirror with PIR sensor.
                      The issue I seem to have with ALL hiding modules is it seems the PIR is initiating BOTH hiding AND unhiding.
                      I just can not seem to figure out what is going on. I can adjust the delay and sensitivity if I need to on the sensor but I dont think I need to mess with that at this moment…
                      I really just want the mirror to be on… say for 20 minutes… then if no trigger … hide.
                      Then turn on when triggered and stay on for 20 minutes… rinse and repeat.
                      Can you help me ?
                      My config is below:
                                              module: 'MMM-PIR-Sensor',
                                              sensorPin: '22',
                                              powerSaving: false,
                                      module: "mm-pir-hide-all",
                                      position: "fullscreen_below",
                                              fadeInTime: '1000',
                                              fadeOutTime: '300000',
