    PIR-Sensor - put your mirror to sleep if not used
    126 Posts 37 Posters 257.5k Views 20 Watching
      paviro @Mitchfarino
      @Mitchfarino if it still works at all yes :)
      – The Doctor
        paviro
        Now it should definitely work :)
        – The Doctor
        Reply Quote 3
          shgmongohh @murattyilmaz
          @murattyilmaz
          I have the same issue. Does anybody have a solution for this problem?
            cpramhofer
            I´m playing around with PIR and after reinstalling npm it seems to work.
            the only problem is that my monitor is switching on and off every couple of seconds.
            do you guys have a picture of how your sensor is setup (Poti, Trigger Jumper)?
            thanks a lot!
            E 1 Reply Last reply
              DirkS
              i have some issue with the PIR Module. It worked for testing a couple of month but now under productive operation it doesn’t :(
              The Screen is switched off and on correctly but after a unspecified time it doesn’t switch it on anymore, it stays black. Sometimes after an hour sometimes after a couple of minutes.
              The PIR itself is working correctly as i discovered, i’m also getting it’s state under FHEM and there i can see the relaible functionality of it. I connected it to the GPIO 21.
              As i can see on the screen it doesn’t get any video input anymore. Only rebooting the PI2 will fix it.
              I’m not sure where to search :(
              Some startup log entrie doesn’t show anything.
              > magicmirror@2.0.0 start /home/pi/MagicMirror
              > electron js/electron.js
              Loading config ...
              Loading module helpers ...
              All module helpers loaded.
              Starting server op port 8080 ...
              Server started ...
              Connecting socket for: MMM-FHEM
              Connecting socket for: MMM-PIR-Sensor
              Starting module: newsfeed
              Launching application.
              A 1 Reply Last reply
                phrazelle
                Thanks for the module - this is fantastic!
                I have a PIR sensor attached and it works as desired, but when the HDMI signal is cut to the TV, I get a “No Signal” message on the screen from the TV itself because the RPi isn’t sending signal anymore.
                I’m wondering what the best solution would be. My head goes to hiding all modules instead of turning the monitor off so MM is still on but a completely black screen, or somehow send the RPi into a sleep state but keep the HDMI active.
                Has anyone else tackled this issue?
                M 1 Reply Last reply
                  McSorley @phrazelle
                  @phrazelle The idea behind it is so that when the HDMI is disabled you would get the no signal. You then set up the TV/Monitor to go to sleep if no signal is found.
                  Check your TV manual for power saving settings.
                  P 1 Reply Last reply
                    phrazelle @McSorley
                    @McSorley Thanks for the response!
                    Unfortunately my TV doesn’t have a sleep mode option. It automatically displays the No Signal message and turns off after a few minutes of no signal. To make that more difficult, if the TV is turned back on with the remote, it loses the resolution settings and blows everything up until the RPi is rebooted.
                    I’m not sure how to address this, but I think it would be ideal in my circumstance to have this module, but triggered by the PIR sensor. Idk if I can finagle that, but I suppose I can give it a shot.
                    • N
                      nem1
                      Do we still have this problem with the node version? (v5 works, 6 not)
                        bibi
                        @phrazelle hi! did you find a way to disable this message? i have the same annoying one :)
                          phrazelle @bibi
                          @bibi Yes! Here is the post I submitted around the new module. Remember that you still need the MMM-PIR-Sensor module by paviro installed for this to work.
                          B 1 Reply Last reply
                            bibi @phrazelle
                            @phrazelle interesting! thx a lot will check this :)
                            • A
                              AlessandroRa @DirkS
                              Yay! I’ve finally solved my blank screen issue, now I’ve the same problem as @DirkS… After a while the screensaver activates, the screen becomes dark and even if I wave in front of the sensor the mirror doesn’t go on again…
                              @paviro any idea why?
                              • A
                                AlessandroRa
                                Nevermind, I’m back on the white page problem… It keeps saying “Error: Module version mismatch. Expected 50, got 51”
                                I tried either: npm rebuild --runtime=electron --target=1.4.0 --disturl=https://atom.io/download/atom-shell --build-from-source
                                and: npm rebuild --runtime=electron --target=1.4.5 --disturl=https://atom.io/download/atom-shell --abi=50
                                but it doesn’t change…
                                Y 1 Reply Last reply
                                • Y
                                  yawns Moderator @AlessandroRa
                                  @AlessandroRa
                                  Please run npm list and check for your electron version. Then rerun the command you already tried with the right version number
                                  • A
                                    AlessandroRa @yawns
                                    @yawns thank you, that solved it! Now I need to understand why nothing happens even if I wave in front of the sensor…
                                    I’m starting to think that the PIR sensor doesn’t work
                                    • T
                                      Them Russians
                                      Hey all,
                                      I am a relative novice when it comes to the Pi, and have been trying to identify why I am unable to install the dependencies via “npm install”.
                                      I cloned the repository into my “modules” folder via the “git clone…” command (Step 1).
                                      I then navigated into the new “MMM-PIR-Sensor” folder and ran “npm install”.
                                      However, I got an error during the install suggesting I have an issue with electron-rebuild. Is anyone familiar with what could cause this error to be thrown, and what I could do to resolve it?
                                      Here is the error:
                                      Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /home/pi/MagicMirror/modules/MMM-PIR-Sensor
                                      electron-rebuild -e …/…/node_modules/electron-prebuilt
                                      An unhandled error occurred inside electron-rebuild
                                      Unable to find electron-prebuilt’s version number, either install it or specify an explicit version
                                      Error: Unable to find electron-prebuilt’s version number, either install it or specify an explicit version
                                      at _callee$ (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:74:17)
                                      at tryCatch (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/regenerator-runtime/runtime.js:63:40)
                                      at GeneratorFunctionPrototype.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/regenerator-runtime/runtime.js:337:22)
                                      at GeneratorFunctionPrototype.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/regenerator-runtime/runtime.js:96:21)
                                      at GeneratorFunctionPrototype.tryCatcher (/home/pi/node_modules/bluebird/js/release/util.js:16:23)
                                      at PromiseSpawn._promiseFulfilled (/home/pi/node_modules/bluebird/js/release/generators.js:97:49)
                                      at /home/pi/node_modules/bluebird/js/release/generators.js:201:15
                                      at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:197:4)
                                      at Module._compile (module.js:570:32)
                                      at Object.Module._extensions…js (module.js:579:10)
                                      at Module.load (module.js:487:32)
                                      at tryModuleLoad (module.js:446:12)
                                      at Function.Module._load (module.js:438:3)
                                      at Module.runMain (module.js:604:10)
                                      at run (bootstrap_node.js:394:7)
                                      at startup (bootstrap_node.js:149:9)
                                      npm ERR! Linux 4.4.38-v7+
                                      npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “install”
                                      npm ERR! node v6.9.2
                                      npm ERR! npm v3.10.9
                                      npm ERR! code ELIFECYCLE
                                      npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: electron-rebuild -e ../../node_modules/electron-prebuilt
                                      npm ERR! Exit status 255
                                      npm ERR!
                                      npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script ‘electron-rebuild -e …/…/node_modules/electron-prebuilt’.
                                      npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-PIR-Sensor package,
                                      npm ERR! not with npm itself.
                                      npm ERR! electron-rebuild -e …/…/node_modules/electron-prebuilt
                                      npm ERR! npm bugs Magic-Mirror-Module-PIR-Sensor
                                      npm ERR! Or if that isn’t available, you can get their info via:
                                      npm ERR! npm owner ls Magic-Mirror-Module-PIR-Sensor
                                      npm ERR! /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
                                      • E
                                        elmerito25 @cpramhofer
                                        @cpramhofer Were you able to fix your problem?
                                        • N
                                          Nususu @jrleeman
                                          @jrleeman Hi I have the same issue that you do with the on signal only being put out for about a second after motion detection. Did you ever find a way to make the mirror stay awake for longer with the timer being reset by any motion signal?
                                          T 1 Reply Last reply
                                          • T
                                            Them Russians @Nususu
                                            @Nususu Did you have any issues with the npm install of this module? I am still unable to install the module :(
                                            • 6 / 7
